Optimization issue in RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Wed Aug 2 08:54:33 UTC 2017
> > + Special registers
> Yes, this might be the issue, specifically if the port is using
> interrupts. For example, mstatus/mcause/mepc might need to be saved
> and/or reset.
> What I'm suspicious of is that the trap_entry code is the problem,
> since it didn't have a chance to get executed/tested on my Spike
> (dummy clock simulated) BSP/Spike, especially after updating the port
> from 2015 to 2017 (RISC-V ABI has changed).
> > If it is not preserved across a subroutine call, then it does not have
> to be
> > in the context switch but is in the ISR context.
> > If it is preserved across subroutine calls, then it is in the context
> > switch.
> > Special registers have to be analyzed. Some may have a magic value across
> > the entire system life. Others will require special handling.
> > Every register needs to be logically places in a class for management
> > purposes.
> >> As for now, I am getting an error on mret instruction, I will try to
> >> figure
> >> out tomorrow, why it happens.
> >> Also, in my debugger 'display /i $pc' suddenly started to work properly.
> >> So, now I can debug a bit more efficient.
> >> Regards, Denis Obrezkov
> > Hesham
> Hesham
Hello, interrupt-driven clock driver works to some extent!
*** LOW MEMORY CLOCK TICK TEST ***
TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:04 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:09 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:10 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:14 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:15 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:19 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:20 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:24 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:29 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:30 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:30 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:34 12/31/1988
*** END OF LOW MEMORY CLOCK TICK TEST ***
Fatal Error 5.0 Halted
I've started to save and restore mepc and mcause registers, though, they
are handled differently in the
provided example.
Also, the optimized version doesn't work.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170802/4c6a7a1b/attachment-0001.html>
