[PATCH 4/6] cmdline: Add cmdline support
Wed Aug 2 13:54:17 UTC 2017
On 01/08/17 22:14, Andreas Kölbl wrote:
> At the moment I didn't implement smp functionality. I will implement it
> directly after implementing SMP.
You can use arm_cortex_a9_get_multiprocessor_cpu_id() in all configurations.
Please try to use the functions in <libcpu/arm-cp15.h> in your BSP. If
missing, then add them.
> Am 01.08.2017 um 13:08 schrieb Sebastian Huber:
>> Why can't you use_CPU_SMP_Get_current_processor() instead of
>> bsp_get_boot_cpu().
>> Why do you have to use the linker command file to allocate memory for
>> the command line?
> I thought, it would be a good idea to reserve memory for it on a defined
> place. This should ensure that a misconfiguration leads to an error.
Who defines the memory location for the command line? Is this read-only
memory?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
