/dev/urandom issue
Sichen Zhao zsc19940506 at outlook.com
Wed Aug 2 14:01:02 UTC 2017
> On 02/08/17 10:46, Sichen Zhao wrote:
>> Hi all,
>> When i use wpa_supplicant to configure WPA, there are an error:
>> Could not open /dev/urandom.
>> wlan0: WPA: Failed to get random data for SNonce
> /dev/urandom should not be used. Use getentropy() instead.
The getentropy() function seems in the contrib/unbound/compat, which is
not imported too. So i still need import something, right?
>> It seems we need /dev/urandom to generate the random data. So how do
>> we deal with it? Should import it?
>> Best Regards
>> Sichen Zhao
>> devel mailing list
>> devel at rtems.org
