[PATCH 4/6] cmdline: Add cmdline support
Thu Aug 3 05:14:20 UTC 2017
On 02/08/17 21:07, Andreas Kölbl wrote:
> Am 02.08.2017 um 15:54 schrieb Sebastian Huber:
>> On 01/08/17 22:14, Andreas Kölbl wrote:
>>> At the moment I didn't implement smp functionality. I will implement it
>>> directly after implementing SMP.
>> You can use arm_cortex_a9_get_multiprocessor_cpu_id() in all
>> configurations.
>> Please try to use the functions in <libcpu/arm-cp15.h> in your BSP. If
>> missing, then add them.
> I've tried this approach. The cortex-a15 manual states:
> "CPU ID
> Indicates the processor number in a Cortex-A15 multiprocessor system. For:
> one processor, the CPU ID is 0x0 [1]."
> In the Jailhouse single processor configuration this method does not work.
Why does it not work?
If you have a single processor, then why do you need this anyway?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
