[PATCH] Optional Clock_driver_support_shutdown_hardware()
Thu Aug 3 18:05:51 UTC 2017
This will need to be documented properly as optional in the BSP
development guide, and also that it has to be implemented as a macro
if it is provided.
On Thu, Aug 3, 2017 at 8:49 AM, Sebastian Huber
> Make Clock_driver_support_shutdown_hardware() optional.  This avoids
> the atexit() support on memory constrained targets.
>  c/src/lib/libbsp/lm32/shared/clock/ckinit.c           | 13 ++++++-------
>  c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c | 10 +++++-----
>  c/src/lib/libbsp/m68k/mcf52235/clock/clock.c          |  8 ++++----
>  c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c          |  8 ++++----
>  c/src/lib/libbsp/m68k/mcf5329/clock/clock.c           |  8 ++++----
>  c/src/lib/libbsp/shared/clockdrv_shell.h              |  6 ++++++
>  c/src/lib/libcpu/arm/at91rm9200/clock/clock.c         |  8 ++++----
>  c/src/lib/libcpu/arm/pxa255/clock/clock.c             |  8 ++++----
>  8 files changed, 37 insertions(+), 32 deletions(-)
> diff --git a/c/src/lib/libbsp/lm32/shared/clock/ckinit.c b/c/src/lib/libbsp/lm32/shared/clock/ckinit.c
> index fd2cae81dc..6a30583853 100644
> --- a/c/src/lib/libbsp/lm32/shared/clock/ckinit.c
> +++ b/c/src/lib/libbsp/lm32/shared/clock/ckinit.c
> @@ -67,13 +67,12 @@ static void Clock_driver_support_initialize_hardware(void)
>    lm32_interrupt_unmask(CLOCK_IRQMASK);
> -static void Clock_driver_support_shutdown_hardware(void)
> -  /* Disable clock interrupts and stop */
> -  lm32_interrupt_unmask(CLOCK_IRQMASK);
> -  clockwrite(LM32_CLOCK_CR, LM32_CLOCK_CR_STOP);
> +#define Clock_driver_support_shutdown_hardware() \
> +  do { \
> +    /* Disable clock interrupts and stop */ \
> +    lm32_interrupt_unmask(CLOCK_IRQMASK); \
> +    clockwrite(LM32_CLOCK_CR, LM32_CLOCK_CR_STOP); \
> +  } while (0)
>  #define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
> diff --git a/c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c b/c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c
> index 3230d83325..35b4b818e6 100644
> --- a/c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c
> +++ b/c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c
> @@ -40,11 +40,11 @@ static void Clock_driver_support_initialize_hardware(void)
>    bsp_interrupt_vector_enable(MM_IRQ_TIMER0);
> -  bsp_interrupt_vector_disable(MM_IRQ_TIMER0);
> -  MM_WRITE(MM_TIMER0_CONTROL, 0);
> +  do { \
> +    bsp_interrupt_vector_disable(MM_IRQ_TIMER0); \
> +    MM_WRITE(MM_TIMER0_CONTROL, 0); \
> +  } while (0)
> diff --git a/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c b/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
> index 4b5f4afc51..aa0d0b7945 100644
> --- a/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
> +++ b/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
> @@ -57,10 +57,10 @@ static void mcf52235_tc_tick(void)
>   * Turn off the clock
> -  MCF_PIT1_PCSR &= ~MCF_PIT_PCSR_EN;
> +  do { \
> +    MCF_PIT1_PCSR &= ~MCF_PIT_PCSR_EN; \
> +  } while (0)
>   * Set up the clock hardware
> diff --git a/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c b/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
> index ee97e5035c..cc2f7d11fa 100644
> --- a/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
> +++ b/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
> @@ -57,10 +57,10 @@ static void mcf5225x_tc_tick(void)
> +  do { \
> +  } while (0)
> diff --git a/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c b/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
> index 5741b3081d..5f6006e717 100644
> --- a/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
> +++ b/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
> @@ -57,10 +57,10 @@ static void mcf5329_tc_tick(void)
> -  MCF_PIT3_PCSR &= ~MCF_PIT_PCSR_EN;
> +  do { \
> +    MCF_PIT3_PCSR &= ~MCF_PIT_PCSR_EN; \
> +  } while (0)
> diff --git a/c/src/lib/libbsp/shared/clockdrv_shell.h b/c/src/lib/libbsp/shared/clockdrv_shell.h
> index a4d1b2df91..0d40c84d91 100644
> --- a/c/src/lib/libbsp/shared/clockdrv_shell.h
> +++ b/c/src/lib/libbsp/shared/clockdrv_shell.h
> @@ -102,7 +102,9 @@ static void Clock_driver_timecounter_tick( void )
>  volatile uint32_t    Clock_driver_ticks;
> +#ifdef Clock_driver_support_shutdown_hardware
>  void Clock_exit( void );
> +#endif
>   *  @brief Clock_isr
> @@ -181,6 +183,7 @@ rtems_isr Clock_isr(
>    #endif
>   *  @brief Clock_exit
> @@ -193,6 +196,7 @@ void Clock_exit( void )
>    /* do not restore old vector */
> +#endif
>   * @brief Clock_initialize
> @@ -237,7 +241,9 @@ rtems_device_driver Clock_initialize(
>    Clock_driver_support_initialize_hardware();
>    atexit( Clock_exit );
> +#endif
>     *  If we are counting ISRs per tick, then initialize the counter.
> diff --git a/c/src/lib/libcpu/arm/at91rm9200/clock/clock.c b/c/src/lib/libcpu/arm/at91rm9200/clock/clock.c
> index 42b85f3f98..ac7f5fe783 100644
> --- a/c/src/lib/libcpu/arm/at91rm9200/clock/clock.c
> +++ b/c/src/lib/libcpu/arm/at91rm9200/clock/clock.c
> @@ -106,10 +106,10 @@ static void Clock_driver_support_initialize_hardware(void)
>      (void) st_str; /* avoid set but not used warning */ \
>    } while (0)
> -static void Clock_driver_support_shutdown_hardware( void )
> -  BSP_remove_rtems_irq_handler(&clock_isr_data);
> +  do { \
> +    BSP_remove_rtems_irq_handler(&clock_isr_data); \
> +  } while (0)
> diff --git a/c/src/lib/libcpu/arm/pxa255/clock/clock.c b/c/src/lib/libcpu/arm/pxa255/clock/clock.c
> index 69b684926c..979e6fbd00 100644
> --- a/c/src/lib/libcpu/arm/pxa255/clock/clock.c
> +++ b/c/src/lib/libcpu/arm/pxa255/clock/clock.c
> @@ -111,10 +111,10 @@ static void Clock_driver_support_initialize_hardware(void)
>      XSCALE_OS_TIMER_MR0 = XSCALE_OS_TIMER_TCR + period_num; \
>    } while (0)
> +  do { \
> +  } while (0)
> 2.12.3
> devel mailing list
> devel at rtems.org
