BSP receiving messages via uart
Denis Obrezkov
denisobrezkov at gmail.com
Fri Aug 4 20:50:29 UTC 2017
2017-08-02 15:58 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> samples/capture uses the shell. I don't know if there is a small shell
> example.
> On Wed, Aug 2, 2017 at 5:13 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
> > Hello all,
> > I am developing a small size BSP and want to start receiving messages via
> > uart.
> > What is the best way to do it? Are there any tests for message receiving?
> > Regards, Denis Obrezkov
> > devel mailing list
> > devel at rtems.org
I was able to utilize printf, but I can't use scanf in the "hello" example.
I found it hard to utilize the samples/capture example because of its
configure options. With the default options
I have a memory allocation error even with -Os flag.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170804/557f2f2f/attachment.html>
