Current state of RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Sun Aug 6 22:49:01 UTC 2017
2017-08-07 0:44 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
> Hi Denis,
> Thanks for sharing the state of HiFive1 BSP. At this stage of GSoC, we
> would want you to clean-up the code, write documentations/comments and
> submit your code for review (probably to my GitHub repo).
> Details/instructions how to use your code (compile, build, run, etc)
> are also important.
> Cheers,
> Hesham
> On Mon, Aug 7, 2017 at 7:25 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
> > Hello all,
> > currently I have some issues with optimization flags.
> > First of all, the low ticker example doesn't work with any optimization
> > flags.
> > Secondly, the hello example is too big and doesn't fit into memory
> without
> > optimization.
> > And, in conclusion, scanf requires a clock driver, but as I said it still
> > doesn't
> > work with optimization flags, so I can't test it.
> > Also, I want to say that on this stage the BSP is very fragile and
> requires
> > proper configuration options to be set.
> > Regards, Denis Obrezkov
> > devel mailing list
> > devel at rtems.org
> Hesham
Yes, I will try to do it till this Wednesday.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170807/95237777/attachment.html>
