Current state of RISC-V BSP
Hesham Almatary heshamelmatary at gmail.com
Wed Aug 9 00:56:08 UTC 2017
Hi Denis,
That's good to know. You might want to try running other samples now
that are not low-memory and see if they work.
Cheers,
Hesham
On Tue, Aug 8, 2017 at 7:51 PM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> 2017-08-07 0:49 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> 2017-08-07 0:44 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
>>> Hi Denis,
>>> Thanks for sharing the state of HiFive1 BSP. At this stage of GSoC, we
>>> would want you to clean-up the code, write documentations/comments and
>>> submit your code for review (probably to my GitHub repo).
>>> Details/instructions how to use your code (compile, build, run, etc)
>>> are also important.
>>> Cheers,
>>> Hesham
>>> On Mon, Aug 7, 2017 at 7:25 AM, Denis Obrezkov <denisobrezkov at gmail.com>
>>> wrote:
>>> > Hello all,
>>> > currently I have some issues with optimization flags.
>>> > First of all, the low ticker example doesn't work with any optimization
>>> > flags.
>>> > Secondly, the hello example is too big and doesn't fit into memory
>>> > without
>>> > optimization.
>>> > And, in conclusion, scanf requires a clock driver, but as I said it
>>> > still
>>> > doesn't
>>> > work with optimization flags, so I can't test it.
>>> > Also, I want to say that on this stage the BSP is very fragile and
>>> > requires
>>> > proper configuration options to be set.
>>> > Regards, Denis Obrezkov
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>>> Hesham
>> Yes, I will try to do it till this Wednesday.
> Sorry, I was too curious and found out why the low ticker example didn't
> work with -Os optimization flag.
> I found out that global interrupts aren't enabled back after task creation
> or starting routing. Thus, I have modified the code
> in this way:
> for (i=1 ; i<=3 ; i++ ) {
>       status = rtems_task_create(
>         rtems_build_name( 'T', 'A', 0x30+1, ' ' ), 1, 0,
> RTEMS_DEFAULT_MODES,
>         RTEMS_DEFAULT_ATTRIBUTES, &id
>       status = rtems_task_start( id, Test_task, i );
> asm volatile ("csrsi mstatus, 0x8");  //I've added this line
> And it works.
> Now I can proceed with documentation and clean up the code.
Hesham
