[PATCH 1/3] waf_generator: Copy headers if necessary.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Aug 10 05:34:35 UTC 2017
Am 10.08.2017 um 01:08 schrieb Chris Johns:
> On 10/08/2017 02:29, Sichen Zhao wrote:
>> From: Christian Mauderer <christian.mauderer at embedded-brains.de>
>> There are some cases, where a header is installed into a directory with
>> a different name then it's source directory. In that case, the build
>> might fail because the header is not found. One example would be the
>> <openssl/opensslv.h>. The source for this file is in
>> freebsd/crypto/openssl/crypto/opensslv.h.
>> To allow the build to work in such cases too, copy such files into a
>> temporary location in the build tree.
>>  builder.py       |  1 +
>>  libbsd_waf.py    | 15 +++++++++++++++
>>  waf_generator.py | 23 +++++++++++++++++++++++
>>  3 files changed, 39 insertions(+)
>> diff --git a/builder.py b/builder.py
>> index bb633cb..53802c7 100755
>> --- a/builder.py
>> +++ b/builder.py
>> @@ -172,6 +172,7 @@ def commonNoWarnings():
>>  def includes():
>>      return ['-Irtemsbsd/include',
>> +            '-Ilibbsd_build/include',
> Is this path under the 'build' directory?
Yes.
> Why the 2 directories in the path? Could the path simply be 'build-include' or
> even 'include' ? We know the context because we are looking under the build
> directory.
There was no real reason. I just chose an arbitrary name.
'build-include' is fine for me too. I would avoid just 'include' because
it's a very generic name. If it is added somewhere else, that might lead
to a conflict.
> I would prefer:
> def buildInclude():
>       return 'libbsd_build/include'
> The path can then be referenced in waf_generator.py where needed, for example:
>    for i in builder.includes() + ['-I' + builder.buildInclude()]:
Agreed. I'll change that.
>>              '-Ifreebsd/sys',
>>              '-Ifreebsd/sys/contrib/pf',
>>              '-Ifreebsd/sys/net',
>> diff --git a/libbsd_waf.py b/libbsd_waf.py
>> index aee2e7a..1784f8b 100644
>> --- a/libbsd_waf.py
>> +++ b/libbsd_waf.py
>> @@ -62,6 +62,7 @@ def build(bld):
>>          for i in ['-Irtemsbsd/@CPU@/include', '-Ifreebsd/sys/@CPU@/include']:
>>              includes += ["%s" % (i[2:].replace("@CPU@", "x86"))]
>>      includes += ["rtemsbsd/include"]
>> +    includes += ["libbsd_build/include"]
>>      includes += ["freebsd/sys"]
>>      includes += ["freebsd/sys/contrib/pf"]
>>      includes += ["freebsd/sys/net"]
>> @@ -123,6 +124,20 @@ def build(bld):
>>          rule = "sed -e 's/@NET_CFG_SELF_IP@/%s/' -e 's/@NET_CFG_NETMASK@/%s/' -e 's/@NET_CFG_PEER_IP@/%s/' -e 's/@NET_CFG_GATEWAY_IP@/%s/' < ${SRC} > ${TGT}" % (net_cfg_self_ip, net_cfg_netmask, net_cfg_peer_ip, net_cfg_gateway_ip),
>>          update_outputs = True)
>> +    # copy headers if necessary
>> +    header_build_copy_paths = [
>> +    for headers in header_build_copy_paths:
>> +        target = os.path.join("libbsd_build/include", headers[2])
>> +        start_dir = bld.path.find_dir(headers[0])
>> +        for header in start_dir.ant_glob("**/" + headers[1]):
> Do we always want to copy all the files?
What do you mean by "all the files"? As far as I understood, only the
files that are changed should be copied by waf.
Or do you mean the ant_glob? In that case: I modeled that after the
install target of the headers. I already suggested in the first
discussion regarding the patch that we move the "**" to builder.py
instead. I planed to create a extra patch for that.
>> +            relsourcepath = os.path.relpath(str(header), start=str(start_dir))
> Is 'str(header)' really 'header.abspath()' ? See
> https://waf.io/apidocs/Node.html#waflib.Node.Node.__str__.
> I prefer the explicit use of .abspath() than the conversion operator.
You are right. I didn't take a thorough look at the documentation. I'll
rework that part. Maybe I can also use something like "path_from()" or
some other waf Node function.
>> +            targetheader = os.path.join(target, relsourcepath)
>> +            bld(features = 'subst',
>> +                target = targetheader,
>> +                source = header,
>> +                is_copy = True)
> Does a clean remove these files?
Just checked: Yes it does.
>>      # KVM Symbols
>>      bld(target = "rtemsbsd/rtems/rtems-kernel-kvm-symbols.c",
>>          source = "rtemsbsd/rtems/generate_kvm_symbols",
>> diff --git a/waf_generator.py b/waf_generator.py
>> index 35fe35f..fb52250 100755
>> --- a/waf_generator.py
>> +++ b/waf_generator.py
>> @@ -445,6 +445,29 @@ class ModuleManager(builder.ModuleManager):
>>          self.add('')
>> +        # Add a copy rule for all headers where the install path and the source
>> +        # path are not the same.
>> +        self.add('    # copy headers if necessary')
>> +        headerPaths = builder.headerPaths()
> Can we remove this line and then ....
>> +        self.add('    header_build_copy_paths = [')
>> +        for hp in headerPaths:
> .... use:
>            for hp in builder.headerPaths():
Should work. I'll try it. Maybe it should be changed on the install part
too?
>> +            if hp[2] != '' and not hp[0].endswith(hp[2]):
> I am ok with another boolean field being add to tuples rather than needing to
> encode this some how if that is useful.
I would disagree here. It would be a redundant information in that tuple
and therefore allow a invalid line if that boolean is not correctly set.
Copying file is only necessary in exactly that case: If the dest paths
name is not the same as the local path.
> If a new field is not added can you please update builder.py with this rule so
> we know what to do when adding headers to builder.headerPaths()?
You mean some comment that describes that behavior? I can add that also
I don't really think that it is necessary. It's just a workaround so
that we can build the binaries without having to install the headers
before the build.
>> +                self.add('                               %s,' % (str(hp)))
>> +        self.add('                              ]')
>> +        self.add('    for headers in header_build_copy_paths:')
>> +        self.add('        target = os.path.join("libbsd_build/include", headers[2])')
> Use builder.buildInclude() rather than hard coding the path.
OK.
>> +        self.add('        start_dir = bld.path.find_dir(headers[0])')
>> +        self.add('        for header in start_dir.ant_glob("**/" + headers[1]):')
>> +        self.add('            relsourcepath = os.path.relpath(str(header), start=str(start_dir))')
>> +        self.add('            targetheader = os.path.join(target, relsourcepath)')
>> +        self.add('            bld(features = \'subst\',')
>> +        self.add('                target = targetheader,')
>> +        self.add('                source = header,')
>> +        self.add('                is_copy = True)')
>> +        self.add('')
>>          # Add the specific rule based builders for generating files.
>>          if 'KVMSymbols' in data:
> Do any of these files copied into the build tree need to be installed so users
> can access then? I cannot see an install component.
The install component is unchanged. It should still work exactly like
before. So all headers should be installed correctly just like before.
Kind regards
Christian
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
