[PATCH 3/3] Port openssl to RTEMS.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Aug 10 05:42:42 UTC 2017
Am 10.08.2017 um 01:05 schrieb Chris Johns:
> Should we consider an 'OPENSSL.README' file in the top of libbsd to make sure we
> are covered?
+1
> Something like:
> ----8<-------------------
> The RTEMS LibBSD package contains OpenSSL. Please refer to
> https://www.openssl.org/ for the legalities related to your use.
> OpenSSL
> OpenSSL 1.0.2l 25 May 2017
The version here is likely to become out of sync with the sources. To be
exact: It already is in your suggestion.
freebsd-org/crypto/openssl/README states the version 1.0.2.k. Maybe we
should refer to that file instead?
>  Copyright (c) 1998-2015 The OpenSSL Project
>  Copyright (c) 1995-1998 Eric A. Young, Tim J. Hudson
> All rights reserved.
> LEGALITIES
> A number of nations restrict the use or export of cryptography. If you
> are potentially subject to such restrictions you should seek competent
> professional legal advice before attempting to develop or distribute
> cryptographic code.
> -----8<-------------------
> Also once this is merged the wiki page
> https://devel.rtems.org/wiki/Packages/OpenSSL needs to be updated to say OpenSSL
> is part of LibBSD and to hold the legalities section the current page moved to
> https://devel.rtems.org/wiki/Packages/OpenSSL/Legacy-Networking.
> Thanks for this work and effort, it is really great to see openssl is now a
> constant feature of RTEMS.
> Chris
> On 10/08/2017 02:29, Sichen Zhao wrote:
>>  builder.py       |  58 ++++
>>  libbsd.py        | 952 +++++++++++++++++++++++++++++++++++++++++++++++++++++++
>>  libbsd_waf.py    | 901 +++++++++++++++++++++++++++++++++++++++++++++++++++-
>>  waf_generator.py |   3 +
>>  4 files changed, 1898 insertions(+), 16 deletions(-)
>> diff --git a/builder.py b/builder.py
>> index 53802c7..2f6c490 100755
>> --- a/builder.py
>> +++ b/builder.py
>> @@ -217,6 +217,64 @@ def headerPaths():
>>              ('freebsd/sys/netinet',           '*.h',               'netinet'),
>>              ('freebsd/sys/netinet6',          '*.h',               'netinet6'),
>>              ('freebsd/sys/netipsec',          '*.h',               'netipsec'),
>> +            ('freebsd/crypto/openssl', '*.h', 'openssl'),
>> +            ('freebsd/crypto/openssl/crypto', '*.h', 'openssl'),
>> +            ('freebsd/crypto/openssl/crypto', '(opensslconf|opensslv|crypto).h', 'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/aes', 'aes.h', 'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/err', 'err.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/bio', '*.h', 'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/dsa', '*.h', 'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/lhash', 'lhash.h', 'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/asn1', '(asn1|asn1t).h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/x509', 'x509.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/bn', 'bn.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/camellia', 'camellia.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/cast', 'cast.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/objects', '(objects|obj_mac).h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/conf', '(conf|conf_api).h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/des', '(des|des_old).h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/ecdh', 'ecdh.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/ecdsa', 'ecdsa.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/idea', 'idea.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/mdc2', 'mdc2.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/md4', 'md4.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/md5', 'md5.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/rc2', 'rc2.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/rc4', 'rc4.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/ripemd', 'ripemd.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/seed', 'seed.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/sha', 'sha.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/ui', '(ui_compat|ui).h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/whrlpool', 'whrlpool.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/x509v3', 'x509v3.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/x509', 'x509_vfy.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/buffer', 'buffer.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/comp', 'comp.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/stack', '(stack|safestack).h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/asn1', 'asn1_mac.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/pem', '(pem|pem2).h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/rsa', 'rsa.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/evp', 'evp.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/ec', 'ec.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/engine', 'engine.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/pkcs7', 'pkcs7.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/hmac', 'hmac.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/pqueue', 'pqueue.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/ocsp', 'ocsp.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/rand', 'rand.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/srp', 'srp.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/dh', 'dh.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/dso', 'dso.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/krb5', 'krb5_asn.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/cms', 'cms.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/txt_db', 'txt_db.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/ts', 'ts.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/modes', 'modes.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/pkcs12', 'pkcs12.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/bf', 'blowfish.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/crypto/cmac', 'cmac.h',               'openssl'),
>> +            ('freebsd/crypto/openssl/ssl', '(ssl|kssl|ssl2).h', 'openssl'),
>> +            ('freebsd/crypto/openssl/ssl', '*.h', 'openssl'),
>>              ('freebsd/sys/rpc',               '*.h',               'rpc'),
>>              ('freebsd/sys/sys',               '*.h',               'sys'),
>>              ('freebsd/sys/vm',                '*.h',               'vm'),
>> diff --git a/libbsd.py b/libbsd.py
>> index 9cc51d6..b2f3977 100644
>> --- a/libbsd.py
>> +++ b/libbsd.py
>> @@ -2644,6 +2644,957 @@ def user_space_wlanstats(mm):
>>      return mod
>> +# /crypto/openssl
>> +def crypto_openssl(mm):
>> +    mod = builder.Module('crypto_openssl')
>> +    mod.addUserSpaceHeaderFiles(
>> +            'crypto/openssl/engines/e_cswift_err.h',
>> +            'crypto/openssl/engines/e_aep_err.h',
>> +            'crypto/openssl/engines/e_gmp_err.h',
>> +            'crypto/openssl/engines/ccgost/gost2001_keyx.h',
>> +            'crypto/openssl/engines/ccgost/e_gost_err.h',
>> +            'crypto/openssl/engines/ccgost/gost_params.h',
>> +            'crypto/openssl/engines/ccgost/gost_lcl.h',
>> +            'crypto/openssl/engines/ccgost/gost89.h',
>> +            'crypto/openssl/engines/ccgost/gost_keywrap.h',
>> +            'crypto/openssl/engines/ccgost/gosthash.h',
>> +            'crypto/openssl/engines/e_chil_err.h',
>> +            'crypto/openssl/engines/e_4758cca_err.h',
>> +            'crypto/openssl/engines/e_capi_err.h',
>> +            'crypto/openssl/engines/e_nuron_err.h',
>> +            'crypto/openssl/engines/e_atalla_err.h',
>> +            'crypto/openssl/engines/vendor_defns/sureware.h',
>> +            'crypto/openssl/engines/vendor_defns/cswift.h',
>> +            'crypto/openssl/engines/vendor_defns/atalla.h',
>> +            'crypto/openssl/engines/vendor_defns/hwcryptohook.h',
>> +            'crypto/openssl/engines/vendor_defns/hw_4758_cca.h',
>> +            'crypto/openssl/engines/vendor_defns/aep.h',
>> +            'crypto/openssl/engines/vendor_defns/hw_ubsec.h',
>> +            'crypto/openssl/engines/e_sureware_err.h',
>> +            'crypto/openssl/engines/e_ubsec_err.h',
>> +            'crypto/openssl/ssl/ssl2.h',
>> +            'crypto/openssl/ssl/ssl3.h',
>> +            'crypto/openssl/ssl/dtls1.h',
>> +            'crypto/openssl/ssl/kssl_lcl.h',
>> +            'crypto/openssl/ssl/srtp.h',
>> +            'crypto/openssl/ssl/tls1.h',
>> +            'crypto/openssl/ssl/ssl23.h',
>> +            'crypto/openssl/ssl/ssl_locl.h',
>> +            'crypto/openssl/ssl/kssl.h',
>> +            'crypto/openssl/ssl/ssl.h',
>> +            'crypto/openssl/e_os.h',
>> +            'crypto/openssl/e_os2.h',
>> +            'crypto/openssl/crypto/bio/bio_lcl.h',
>> +            'crypto/openssl/crypto/bio/bio.h',
>> +            'crypto/openssl/crypto/modes/modes_lcl.h',
>> +            'crypto/openssl/crypto/modes/modes.h',
>> +            'crypto/openssl/crypto/cms/cms.h',
>> +            'crypto/openssl/crypto/cms/cms_lcl.h',
>> +            'crypto/openssl/crypto/bn/bn_prime.h',
>> +            'crypto/openssl/crypto/bn/bn_lcl.h',
>> +            'crypto/openssl/crypto/bn/bn.h',
>> +            'crypto/openssl/crypto/bn/rsaz_exp.h',
>> +            'crypto/openssl/crypto/ecdh/ecdh.h',
>> +            'crypto/openssl/crypto/ecdh/ech_locl.h',
>> +            'crypto/openssl/crypto/dh/dh.h',
>> +            'crypto/openssl/crypto/opensslv.h',
>> +            'crypto/openssl/crypto/ripemd/ripemd.h',
>> +            'crypto/openssl/crypto/ripemd/rmd_locl.h',
>> +            'crypto/openssl/crypto/ripemd/rmdconst.h',
>> +            'crypto/openssl/crypto/hmac/hmac.h',
>> +            'crypto/openssl/crypto/rand/rand_lcl.h',
>> +            'crypto/openssl/crypto/rand/rand.h',
>> +            'crypto/openssl/crypto/stack/safestack.h',
>> +            'crypto/openssl/crypto/stack/stack.h',
>> +            'crypto/openssl/crypto/pem/pem.h',
>> +            'crypto/openssl/crypto/pem/pem2.h',
>> +            'crypto/openssl/crypto/evp/evp_locl.h',
>> +            'crypto/openssl/crypto/evp/evp.h',
>> +            'crypto/openssl/crypto/constant_time_locl.h',
>> +            'crypto/openssl/crypto/txt_db/txt_db.h',
>> +            'crypto/openssl/crypto/ebcdic.h',
>> +            'crypto/openssl/crypto/cmac/cmac.h',
>> +            'crypto/openssl/crypto/ppc_arch.h',
>> +            'crypto/openssl/crypto/dsa/dsa.h',
>> +            'crypto/openssl/crypto/dsa/dsa_locl.h',
>> +            'crypto/openssl/crypto/md4/md4_locl.h',
>> +            'crypto/openssl/crypto/md4/md4.h',
>> +            'crypto/openssl/crypto/sha/sha_locl.h',
>> +            'crypto/openssl/crypto/sha/sha.h',
>> +            'crypto/openssl/crypto/arm_arch.h',
>> +            'crypto/openssl/crypto/o_str.h',
>> +            'crypto/openssl/crypto/ui/ui_locl.h',
>> +            'crypto/openssl/crypto/ui/ui_compat.h',
>> +            'crypto/openssl/crypto/ui/ui.h',
>> +            'crypto/openssl/crypto/md32_common.h',
>> +            'crypto/openssl/crypto/pkcs7/pkcs7.h',
>> +            'crypto/openssl/crypto/crypto.h',
>> +            'crypto/openssl/crypto/ossl_typ.h',
>> +            'crypto/openssl/crypto/err/err.h',
>> +            'crypto/openssl/crypto/sparc_arch.h',
>> +            'crypto/openssl/crypto/dso/dso.h',
>> +            'crypto/openssl/crypto/o_dir.h',
>> +            'crypto/openssl/crypto/idea/idea.h',
>> +            'crypto/openssl/crypto/idea/idea_lcl.h',
>> +            'crypto/openssl/crypto/engine/eng_int.h',
>> +            'crypto/openssl/crypto/engine/engine.h',
>> +            'crypto/openssl/crypto/fips_err.h',
>> +            'crypto/openssl/crypto/comp/comp.h',
>> +            'crypto/openssl/crypto/ecdsa/ecdsa.h',
>> +            'crypto/openssl/crypto/ecdsa/ecs_locl.h',
>> +            'crypto/openssl/crypto/pkcs12/pkcs12.h',
>> +            'crypto/openssl/crypto/srp/srp_lcl.h',
>> +            'crypto/openssl/crypto/srp/srp_grps.h',
>> +            'crypto/openssl/crypto/srp/srp.h',
>> +            'crypto/openssl/crypto/x509v3/x509v3.h',
>> +            'crypto/openssl/crypto/x509v3/pcy_int.h',
>> +            'crypto/openssl/crypto/x509v3/ext_dat.h',
>> +            'crypto/openssl/crypto/symhacks.h',
>> +            'crypto/openssl/crypto/aes/aes.h',
>> +            'crypto/openssl/crypto/aes/aes_locl.h',
>> +            'crypto/openssl/crypto/bf/bf_locl.h',
>> +            'crypto/openssl/crypto/bf/bf_pi.h',
>> +            'crypto/openssl/crypto/bf/blowfish.h',
>> +            'crypto/openssl/crypto/rc4/rc4_locl.h',
>> +            'crypto/openssl/crypto/rc4/rc4.h',
>> +            'crypto/openssl/crypto/ocsp/ocsp.h',
>> +            'crypto/openssl/crypto/rc2/rc2.h',
>> +            'crypto/openssl/crypto/rc2/rc2_locl.h',
>> +            'crypto/openssl/crypto/md5/md5_locl.h',
>> +            'crypto/openssl/crypto/md5/md5.h',
>> +            'crypto/openssl/crypto/des/des_locl.h',
>> +            'crypto/openssl/crypto/des/rpc_des.h',
>> +            'crypto/openssl/crypto/des/des.h',
>> +            'crypto/openssl/crypto/des/spr.h',
>> +            'crypto/openssl/crypto/des/des_ver.h',
>> +            'crypto/openssl/crypto/des/des_old.h',
>> +            'crypto/openssl/crypto/cryptlib.h',
>> +            'crypto/openssl/crypto/krb5/krb5_asn.h',
>> +            'crypto/openssl/crypto/o_time.h',
>> +            'crypto/openssl/crypto/opensslconf.h',
>> +            'crypto/openssl/crypto/camellia/cmll_locl.h',
>> +            'crypto/openssl/crypto/camellia/camellia.h',
>> +            'crypto/openssl/crypto/x509/x509.h',
>> +            'crypto/openssl/crypto/x509/vpm_int.h',
>> +            'crypto/openssl/crypto/x509/x509_vfy.h',
>> +            'crypto/openssl/crypto/seed/seed_locl.h',
>> +            'crypto/openssl/crypto/seed/seed.h',
>> +            'crypto/openssl/crypto/objects/obj_xref.h',
>> +            'crypto/openssl/crypto/objects/obj_mac.h',
>> +            'crypto/openssl/crypto/objects/objects.h',
>> +            'crypto/openssl/crypto/objects/obj_dat.h',
>> +            'crypto/openssl/crypto/ts/ts.h',
>> +            'crypto/openssl/crypto/mdc2/mdc2.h',
>> +            'crypto/openssl/crypto/pqueue/pqueue.h',
>> +            'crypto/openssl/crypto/vms_rms.h',
>> +            'crypto/openssl/crypto/buffer/buffer.h',
>> +            'crypto/openssl/crypto/cast/cast.h',
>> +            'crypto/openssl/crypto/cast/cast_s.h',
>> +            'crypto/openssl/crypto/cast/cast_lcl.h',
>> +            'crypto/openssl/crypto/rsa/rsa.h',
>> +            'crypto/openssl/crypto/rsa/rsa_locl.h',
>> +            'crypto/openssl/crypto/whrlpool/whrlpool.h',
>> +            'crypto/openssl/crypto/whrlpool/wp_locl.h',
>> +            'crypto/openssl/crypto/asn1/asn1t.h',
>> +            'crypto/openssl/crypto/asn1/charmap.h',
>> +            'crypto/openssl/crypto/asn1/asn1_mac.h',
>> +            'crypto/openssl/crypto/asn1/asn1.h',
>> +            'crypto/openssl/crypto/asn1/asn1_locl.h',
>> +            'crypto/openssl/crypto/ec/ec_lcl.h',
>> +            'crypto/openssl/crypto/ec/ec.h',
>> +            'crypto/openssl/crypto/conf/conf.h',
>> +	    'crypto/openssl/crypto/conf/conf_def.h',
>> +            'crypto/openssl/crypto/conf/conf_api.h',
>> +            'crypto/openssl/crypto/lhash/lhash.h',
>> +    mod.addUserSpaceSourceFiles(
>> +            'crypto/openssl/engines/ccgost/e_gost_err.c',
>> +            'crypto/openssl/engines/ccgost/gost_sign.c',
>> +            'crypto/openssl/engines/ccgost/gost_params.c',
>> +            'crypto/openssl/engines/ccgost/gost_md.c',
>> +            'crypto/openssl/engines/ccgost/gost2001_keyx.c',
>> +            'crypto/openssl/engines/ccgost/gostsum.c',
>> +            'crypto/openssl/engines/ccgost/gost_eng.c',
>> +            'crypto/openssl/engines/ccgost/gost_asn1.c',
>> +            'crypto/openssl/engines/ccgost/gost_ameth.c',
>> +            'crypto/openssl/engines/ccgost/gost_keywrap.c',
>> +            'crypto/openssl/engines/ccgost/gost_pmeth.c',
>> +            'crypto/openssl/engines/ccgost/gost2001.c',
>> +            'crypto/openssl/engines/ccgost/gost94_keyx.c',
>> +            'crypto/openssl/engines/ccgost/gost89.c',
>> +            'crypto/openssl/engines/ccgost/gost_crypt.c',
>> +            'crypto/openssl/engines/ccgost/gosthash.c',
>> +            'crypto/openssl/engines/ccgost/gost_ctl.c',
>> +            'crypto/openssl/engines/e_4758cca_err.c',
>> +            'crypto/openssl/engines/e_gmp.c',
>> +            'crypto/openssl/engines/e_sureware_err.c',
>> +            'crypto/openssl/engines/e_ubsec.c',
>> +            'crypto/openssl/engines/e_gmp_err.c',
>> +            'crypto/openssl/engines/e_ubsec_err.c',
>> +            'crypto/openssl/engines/e_cswift_err.c',
>> +            'crypto/openssl/engines/e_chil_err.c',
>> +            'crypto/openssl/engines/e_aep_err.c',
>> +            'crypto/openssl/engines/e_4758cca.c',
>> +            'crypto/openssl/engines/e_chil.c',
>> +            'crypto/openssl/engines/e_nuron.c',
>> +            'crypto/openssl/engines/e_aep.c',
>> +            'crypto/openssl/engines/e_cswift.c',
>> +            'crypto/openssl/engines/e_atalla_err.c',
>> +            'crypto/openssl/engines/e_capi.c',
>> +            'crypto/openssl/engines/e_nuron_err.c',
>> +            'crypto/openssl/engines/e_atalla.c',
>> +            'crypto/openssl/engines/e_capi_err.c',
>> +            'crypto/openssl/engines/e_padlock.c',
>> +            'crypto/openssl/engines/e_sureware.c',
>> +            'crypto/openssl/ssl/ssl_utst.c',
>> +            'crypto/openssl/ssl/t1_ext.c',
>> +            'crypto/openssl/ssl/ssltest.c',
>> +            'crypto/openssl/ssl/s2_pkt.c',
>> +            'crypto/openssl/ssl/s23_pkt.c',
>> +            'crypto/openssl/ssl/t1_enc.c',
>> +            'crypto/openssl/ssl/s23_lib.c',
>> +            'crypto/openssl/ssl/s23_clnt.c',
>> +            'crypto/openssl/ssl/s23_meth.c',
>> +            'crypto/openssl/ssl/ssl_stat.c',
>> +            'crypto/openssl/ssl/s3_srvr.c',
>> +            'crypto/openssl/ssl/s2_clnt.c',
>> +            'crypto/openssl/ssl/t1_reneg.c',
>> +            'crypto/openssl/ssl/s3_pkt.c',
>> +            'crypto/openssl/ssl/s3_cbc.c',
>> +            'crypto/openssl/ssl/t1_clnt.c',
>> +            'crypto/openssl/ssl/kssl.c',
>> +            'crypto/openssl/ssl/s3_both.c',
>> +            'crypto/openssl/ssl/t1_meth.c',
>> +            'crypto/openssl/ssl/s3_enc.c',
>> +            'crypto/openssl/ssl/tls_srp.c',
>> +            'crypto/openssl/ssl/d1_srvr.c',
>> +            'crypto/openssl/ssl/ssl_cert.c',
>> +            'crypto/openssl/ssl/ssl_rsa.c',
>> +            'crypto/openssl/ssl/ssl_lib.c',
>> +            'crypto/openssl/ssl/s2_lib.c',
>> +            'crypto/openssl/ssl/clienthellotest.c',
>> +            'crypto/openssl/ssl/ssl_err2.c',
>> +            'crypto/openssl/ssl/ssl_asn1.c',
>> +            'crypto/openssl/ssl/d1_pkt.c',
>> +            'crypto/openssl/ssl/t1_srvr.c',
>> +            'crypto/openssl/ssl/s2_enc.c',
>> +            'crypto/openssl/ssl/ssl_conf.c',
>> +            'crypto/openssl/ssl/s3_lib.c',
>> +            'crypto/openssl/ssl/sslv2conftest.c',
>> +            'crypto/openssl/ssl/d1_meth.c',
>> +            'crypto/openssl/ssl/ssl_algs.c',
>> +            'crypto/openssl/ssl/t1_lib.c',
>> +            'crypto/openssl/ssl/ssl_err.c',
>> +            'crypto/openssl/ssl/d1_clnt.c',
>> +            'crypto/openssl/ssl/t1_trce.c',
>> +            'crypto/openssl/ssl/s3_meth.c',
>> +            'crypto/openssl/ssl/d1_lib.c',
>> +            'crypto/openssl/ssl/ssl_ciph.c',
>> +            'crypto/openssl/ssl/ssl_sess.c',
>> +            'crypto/openssl/ssl/ssl_txt.c',
>> +            'crypto/openssl/ssl/bio_ssl.c',
>> +            'crypto/openssl/ssl/s2_srvr.c',
>> +            'crypto/openssl/ssl/s3_clnt.c',
>> +            'crypto/openssl/ssl/s23_srvr.c',
>> +            'crypto/openssl/ssl/d1_srtp.c',
>> +            'crypto/openssl/ssl/d1_both.c',
>> +            'crypto/openssl/ssl/s2_meth.c',
>> +            'crypto/openssl/ssl/bad_dtls_test.c',
>> +            'crypto/openssl/crypto/bio/bss_bio.c',
>> +            'crypto/openssl/crypto/bio/bf_lbuf.c',
>> +            'crypto/openssl/crypto/bio/b_dump.c',
>> +            'crypto/openssl/crypto/bio/bf_buff.c',
>> +            'crypto/openssl/crypto/bio/bf_nbio.c',
>> +            'crypto/openssl/crypto/bio/bss_file.c',
>> +            'crypto/openssl/crypto/bio/bss_acpt.c',
>> +            'crypto/openssl/crypto/bio/bf_null.c',
>> +            'crypto/openssl/crypto/bio/bss_dgram.c',
>> +            'crypto/openssl/crypto/bio/bss_fd.c',
>> +            'crypto/openssl/crypto/bio/bss_sock.c',
>> +            'crypto/openssl/crypto/bio/bio_lib.c',
>> +            'crypto/openssl/crypto/bio/b_sock.c',
>> +            'crypto/openssl/crypto/bio/bio_err.c',
>> +            'crypto/openssl/crypto/bio/bio_cb.c',
>> +            'crypto/openssl/crypto/bio/bss_mem.c',
>> +            'crypto/openssl/crypto/bio/bss_conn.c',
>> +            'crypto/openssl/crypto/bio/bss_log.c',
>> +            'crypto/openssl/crypto/bio/b_print.c',
>> +            'crypto/openssl/crypto/bio/bss_null.c',
>> +            'crypto/openssl/crypto/modes/cbc128.c',
>> +            'crypto/openssl/crypto/modes/ccm128.c',
>> +            'crypto/openssl/crypto/modes/wrap128.c',
>> +            'crypto/openssl/crypto/modes/cts128.c',
>> +            'crypto/openssl/crypto/modes/xts128.c',
>> +            'crypto/openssl/crypto/modes/ctr128.c',
>> +            'crypto/openssl/crypto/modes/gcm128.c',
>> +            'crypto/openssl/crypto/modes/ofb128.c',
>> +            'crypto/openssl/crypto/modes/cfb128.c',
>> +            'crypto/openssl/crypto/fips_ers.c',
>> +            'crypto/openssl/crypto/o_time.c',
>> +            'crypto/openssl/crypto/cms/cms_sd.c',
>> +            'crypto/openssl/crypto/cms/cms_enc.c',
>> +            'crypto/openssl/crypto/cms/cms_att.c',
>> +            'crypto/openssl/crypto/cms/cms_env.c',
>> +            'crypto/openssl/crypto/cms/cms_ess.c',
>> +            'crypto/openssl/crypto/cms/cms_kari.c',
>> +            'crypto/openssl/crypto/cms/cms_cd.c',
>> +            'crypto/openssl/crypto/cms/cms_dd.c',
>> +            'crypto/openssl/crypto/cms/cms_io.c',
>> +            'crypto/openssl/crypto/cms/cms_lib.c',
>> +            'crypto/openssl/crypto/cms/cms_err.c',
>> +            'crypto/openssl/crypto/cms/cms_pwri.c',
>> +            'crypto/openssl/crypto/cms/cms_smime.c',
>> +            'crypto/openssl/crypto/cms/cms_asn1.c',
>> +            'crypto/openssl/crypto/uid.c',
>> +            'crypto/openssl/crypto/bn/bn_word.c',
>> +            'crypto/openssl/crypto/bn/bn_mul.c',
>> +            'crypto/openssl/crypto/bn/bn_gf2m.c',
>> +            'crypto/openssl/crypto/bn/bn_gcd.c',
>> +            'crypto/openssl/crypto/bn/bn_exp2.c',
>> +            'crypto/openssl/crypto/bn/expspeed.c',
>> +            'crypto/openssl/crypto/bn/bn_print.c',
>> +            'crypto/openssl/crypto/bn/bn_add.c',
>> +            'crypto/openssl/crypto/bn/bn_mpi.c',
>> +            'crypto/openssl/crypto/bn/exptest.c',
>> +            'crypto/openssl/crypto/bn/bn_prime.c',
>> +            'crypto/openssl/crypto/bn/rsaz_exp.c',
>> +            'crypto/openssl/crypto/bn/bn_lib.c',
>> +            'crypto/openssl/crypto/bn/bn_exp.c',
>> +            'crypto/openssl/crypto/bn/bn_kron.c',
>> +            'crypto/openssl/crypto/bn/bn_const.c',
>> +            'crypto/openssl/crypto/bn/bnspeed.c',
>> +            'crypto/openssl/crypto/bn/bn_recp.c',
>> +            'crypto/openssl/crypto/bn/bn_rand.c',
>> +            'crypto/openssl/crypto/bn/bn_div.c',
>> +            'crypto/openssl/crypto/bn/bn_mod.c',
>> +            'crypto/openssl/crypto/bn/bn_sqr.c',
>> +            'crypto/openssl/crypto/bn/bn_depr.c',
>> +            'crypto/openssl/crypto/bn/bn_shift.c',
>> +            'crypto/openssl/crypto/bn/bn_ctx.c',
>> +            'crypto/openssl/crypto/bn/bn_mont.c',
>> +            'crypto/openssl/crypto/bn/divtest.c',
>> +            'crypto/openssl/crypto/bn/bn_nist.c',
>> +            'crypto/openssl/crypto/bn/bn_sqrt.c',
>> +            'crypto/openssl/crypto/bn/bn_err.c',
>> +            'crypto/openssl/crypto/bn/bn_x931p.c',
>> +            'crypto/openssl/crypto/bn/bn_asm.c',
>> +            'crypto/openssl/crypto/bn/bntest.c',
>> +            'crypto/openssl/crypto/bn/bn_blind.c',
>> +            'crypto/openssl/crypto/mem.c',
>> +            'crypto/openssl/crypto/ecdh/ech_err.c',
>> +            'crypto/openssl/crypto/ecdh/ecdhtest.c',
>> +            'crypto/openssl/crypto/ecdh/ech_ossl.c',
>> +            'crypto/openssl/crypto/ecdh/ech_kdf.c',
>> +            'crypto/openssl/crypto/ecdh/ech_key.c',
>> +            'crypto/openssl/crypto/ecdh/ech_lib.c',
>> +            'crypto/openssl/crypto/dh/dh_rfc5114.c',
>> +            'crypto/openssl/crypto/dh/dh_lib.c',
>> +            'crypto/openssl/crypto/dh/p192.c',
>> +            'crypto/openssl/crypto/dh/p512.c',
>> +            'crypto/openssl/crypto/dh/dh_key.c',
>> +            'crypto/openssl/crypto/dh/p1024.c',
>> +            'crypto/openssl/crypto/dh/dh_kdf.c',
>> +            'crypto/openssl/crypto/dh/dh_gen.c',
>> +            'crypto/openssl/crypto/dh/dh_ameth.c',
>> +            'crypto/openssl/crypto/dh/dh_prn.c',
>> +            'crypto/openssl/crypto/dh/dh_depr.c',
>> +            'crypto/openssl/crypto/dh/dh_err.c',
>> +            'crypto/openssl/crypto/dh/dh_pmeth.c',
>> +            'crypto/openssl/crypto/dh/dh_asn1.c',
>> +            'crypto/openssl/crypto/dh/dh_check.c',
>> +            'crypto/openssl/crypto/dh/dhtest.c',
>> +            'crypto/openssl/crypto/ripemd/rmd_one.c',
>> +            'crypto/openssl/crypto/ripemd/rmd_dgst.c',
>> +            'crypto/openssl/crypto/ripemd/rmdtest.c',
>> +            'crypto/openssl/crypto/ripemd/rmd160.c',
>> +            'crypto/openssl/crypto/hmac/hm_pmeth.c',
>> +            'crypto/openssl/crypto/hmac/hm_ameth.c',
>> +            'crypto/openssl/crypto/hmac/hmactest.c',
>> +            'crypto/openssl/crypto/hmac/hmac.c',
>> +            'crypto/openssl/crypto/rand/md_rand.c',
>> +            'crypto/openssl/crypto/rand/rand_egd.c',
>> +            'crypto/openssl/crypto/rand/randfile.c',
>> +            'crypto/openssl/crypto/rand/rand_err.c',
>> +            'crypto/openssl/crypto/rand/rand_unix.c',
>> +            'crypto/openssl/crypto/rand/randtest.c',
>> +            'crypto/openssl/crypto/rand/rand_lib.c',
>> +            'crypto/openssl/crypto/stack/stack.c',
>> +            'crypto/openssl/crypto/pem/pem_oth.c',
>> +            'crypto/openssl/crypto/pem/pem_all.c',
>> +            'crypto/openssl/crypto/pem/pem_info.c',
>> +            'crypto/openssl/crypto/pem/pem_pk8.c',
>> +            'crypto/openssl/crypto/pem/pem_err.c',
>> +            'crypto/openssl/crypto/pem/pem_sign.c',
>> +            'crypto/openssl/crypto/pem/pem_lib.c',
>> +            'crypto/openssl/crypto/pem/pem_x509.c',
>> +            'crypto/openssl/crypto/pem/pem_seal.c',
>> +            'crypto/openssl/crypto/pem/pvkfmt.c',
>> +            'crypto/openssl/crypto/pem/pem_pkey.c',
>> +            'crypto/openssl/crypto/pem/pem_xaux.c',
>> +            'crypto/openssl/crypto/evp/e_camellia.c',
>> +            'crypto/openssl/crypto/evp/p_enc.c',
>> +            'crypto/openssl/crypto/evp/m_sha.c',
>> +            'crypto/openssl/crypto/evp/e_rc2.c',
>> +            'crypto/openssl/crypto/evp/e_old.c',
>> +            'crypto/openssl/crypto/evp/e_xcbc_d.c',
>> +            'crypto/openssl/crypto/evp/e_des3.c',
>> +            'crypto/openssl/crypto/evp/evp_err.c',
>> +            'crypto/openssl/crypto/evp/p_lib.c',
>> +            'crypto/openssl/crypto/evp/digest.c',
>> +            'crypto/openssl/crypto/evp/m_wp.c',
>> +            'crypto/openssl/crypto/evp/p_seal.c',
>> +            'crypto/openssl/crypto/evp/e_null.c',
>> +            'crypto/openssl/crypto/evp/e_aes.c',
>> +            'crypto/openssl/crypto/evp/m_md2.c',
>> +            'crypto/openssl/crypto/evp/p_dec.c',
>> +            'crypto/openssl/crypto/evp/e_idea.c',
>> +            'crypto/openssl/crypto/evp/evp_pkey.c',
>> +            'crypto/openssl/crypto/evp/p_open.c',
>> +            'crypto/openssl/crypto/evp/c_allc.c',
>> +            'crypto/openssl/crypto/evp/m_mdc2.c',
>> +            'crypto/openssl/crypto/evp/evp_pbe.c',
>> +            'crypto/openssl/crypto/evp/pmeth_lib.c',
>> +            'crypto/openssl/crypto/evp/c_alld.c',
>> +            'crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c',
>> +            'crypto/openssl/crypto/evp/openbsd_hw.c',
>> +            'crypto/openssl/crypto/evp/p_verify.c',
>> +            'crypto/openssl/crypto/evp/evp_acnf.c',
>> +            'crypto/openssl/crypto/evp/evp_enc.c',
>> +            'crypto/openssl/crypto/evp/m_md5.c',
>> +            'crypto/openssl/crypto/evp/evp_extra_test.c',
>> +            'crypto/openssl/crypto/evp/m_ripemd.c',
>> +            'crypto/openssl/crypto/evp/p_sign.c',
>> +            'crypto/openssl/crypto/evp/bio_ok.c',
>> +            'crypto/openssl/crypto/evp/e_rc5.c',
>> +            'crypto/openssl/crypto/evp/e_des.c',
>> +            'crypto/openssl/crypto/evp/evp_cnf.c',
>> +            'crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c',
>> +            'crypto/openssl/crypto/evp/e_cast.c',
>> +            'crypto/openssl/crypto/evp/bio_enc.c',
>> +            'crypto/openssl/crypto/evp/m_md4.c',
>> +            'crypto/openssl/crypto/evp/p5_crpt.c',
>> +            'crypto/openssl/crypto/evp/evp_lib.c',
>> +            'crypto/openssl/crypto/evp/bio_b64.c',
>> +            'crypto/openssl/crypto/evp/evp_test.c',
>> +            'crypto/openssl/crypto/evp/c_all.c',
>> +            'crypto/openssl/crypto/evp/m_null.c',
>> +            'crypto/openssl/crypto/evp/e_rc4.c',
>> +            'crypto/openssl/crypto/evp/m_sigver.c',
>> +            'crypto/openssl/crypto/evp/m_sha1.c',
>> +            'crypto/openssl/crypto/evp/e_seed.c',
>> +            'crypto/openssl/crypto/evp/evp_key.c',
>> +            'crypto/openssl/crypto/evp/e_rc4_hmac_md5.c',
>> +            'crypto/openssl/crypto/evp/e_bf.c',
>> +            'crypto/openssl/crypto/evp/pmeth_fn.c',
>> +            'crypto/openssl/crypto/evp/m_ecdsa.c',
>> +            'crypto/openssl/crypto/evp/pmeth_gn.c',
>> +            'crypto/openssl/crypto/evp/p5_crpt2.c',
>> +            'crypto/openssl/crypto/evp/bio_md.c',
>> +            'crypto/openssl/crypto/evp/names.c',
>> +            'crypto/openssl/crypto/evp/encode.c',
>> +            'crypto/openssl/crypto/evp/m_dss.c',
>> +            'crypto/openssl/crypto/evp/m_dss1.c',
>> +            'crypto/openssl/crypto/ppccap.c',
>> +            'crypto/openssl/crypto/txt_db/txt_db.c',
>> +            'crypto/openssl/crypto/s390xcap.c',
>> +            'crypto/openssl/crypto/cmac/cm_pmeth.c',
>> +            'crypto/openssl/crypto/cmac/cmac.c',
>> +            'crypto/openssl/crypto/cmac/cm_ameth.c',
>> +            'crypto/openssl/crypto/dsa/dsa_key.c',
>> +            'crypto/openssl/crypto/dsa/dsa_err.c',
>> +            'crypto/openssl/crypto/dsa/dsa_gen.c',
>> +            'crypto/openssl/crypto/dsa/dsa_ossl.c',
>> +            'crypto/openssl/crypto/dsa/dsa_lib.c',
>> +            'crypto/openssl/crypto/dsa/dsa_vrf.c',
>> +            'crypto/openssl/crypto/dsa/dsa_sign.c',
>> +            'crypto/openssl/crypto/dsa/dsagen.c',
>> +            'crypto/openssl/crypto/dsa/dsa_ameth.c',
>> +            'crypto/openssl/crypto/dsa/dsa_pmeth.c',
>> +            'crypto/openssl/crypto/dsa/dsa_depr.c',
>> +            'crypto/openssl/crypto/dsa/dsa_asn1.c',
>> +            'crypto/openssl/crypto/dsa/dsa_prn.c',
>> +            'crypto/openssl/crypto/dsa/dsatest.c',
>> +            'crypto/openssl/crypto/md4/md4test.c',
>> +            'crypto/openssl/crypto/md4/md4_dgst.c',
>> +            'crypto/openssl/crypto/md4/md4.c',
>> +            'crypto/openssl/crypto/md4/md4_one.c',
>> +            'crypto/openssl/crypto/sha/shatest.c',
>> +            'crypto/openssl/crypto/sha/sha1.c',
>> +            'crypto/openssl/crypto/sha/sha1test.c',
>> +            'crypto/openssl/crypto/sha/sha_dgst.c',
>> +            'crypto/openssl/crypto/sha/sha512.c',
>> +            'crypto/openssl/crypto/sha/sha_one.c',
>> +            'crypto/openssl/crypto/sha/sha256.c',
>> +            'crypto/openssl/crypto/sha/sha1dgst.c',
>> +            'crypto/openssl/crypto/sha/sha1_one.c',
>> +            'crypto/openssl/crypto/sha/sha.c',
>> +            'crypto/openssl/crypto/sha/sha256t.c',
>> +            'crypto/openssl/crypto/sha/sha512t.c',
>> +            'crypto/openssl/crypto/ui/ui_openssl.c',
>> +            'crypto/openssl/crypto/ui/ui_compat.c',
>> +            'crypto/openssl/crypto/ui/ui_lib.c',
>> +            'crypto/openssl/crypto/ui/ui_err.c',
>> +            'crypto/openssl/crypto/ui/ui_util.c',
>> +            'crypto/openssl/crypto/pkcs7/pkcs7err.c',
>> +            'crypto/openssl/crypto/pkcs7/pk7_dgst.c',
>> +            'crypto/openssl/crypto/pkcs7/pk7_lib.c',
>> +            'crypto/openssl/crypto/pkcs7/pk7_smime.c',
>> +            'crypto/openssl/crypto/pkcs7/pk7_mime.c',
>> +            'crypto/openssl/crypto/pkcs7/bio_pk7.c',
>> +            'crypto/openssl/crypto/pkcs7/pk7_asn1.c',
>> +            'crypto/openssl/crypto/pkcs7/pk7_attr.c',
>> +            'crypto/openssl/crypto/pkcs7/pk7_doit.c',
>> +            'crypto/openssl/crypto/err/err_all.c',
>> +            'crypto/openssl/crypto/err/err.c',
>> +            'crypto/openssl/crypto/err/err_prn.c',
>> +            'crypto/openssl/crypto/ex_data.c',
>> +            'crypto/openssl/crypto/dso/dso_openssl.c',
>> +            'crypto/openssl/crypto/dso/dso_dl.c',
>> +            'crypto/openssl/crypto/dso/dso_beos.c',
>> +            'crypto/openssl/crypto/dso/dso_dlfcn.c',
>> +            'crypto/openssl/crypto/dso/dso_err.c',
>> +            'crypto/openssl/crypto/dso/dso_null.c',
>> +            'crypto/openssl/crypto/dso/dso_lib.c',
>> +            'crypto/openssl/crypto/idea/i_ecb.c',
>> +            'crypto/openssl/crypto/idea/i_cfb64.c',
>> +            'crypto/openssl/crypto/idea/i_ofb64.c',
>> +            'crypto/openssl/crypto/idea/ideatest.c',
>> +            'crypto/openssl/crypto/idea/i_cbc.c',
>> +            'crypto/openssl/crypto/idea/i_skey.c',
>> +            'crypto/openssl/crypto/idea/idea_spd.c',
>> +            'crypto/openssl/crypto/armcap.c',
>> +            'crypto/openssl/crypto/engine/tb_asnmth.c',
>> +            'crypto/openssl/crypto/engine/eng_dyn.c',
>> +            'crypto/openssl/crypto/engine/eng_openssl.c',
>> +            'crypto/openssl/crypto/engine/eng_all.c',
>> +            'crypto/openssl/crypto/engine/tb_ecdsa.c',
>> +            'crypto/openssl/crypto/engine/eng_lib.c',
>> +            'crypto/openssl/crypto/engine/eng_err.c',
>> +            'crypto/openssl/crypto/engine/tb_store.c',
>> +            'crypto/openssl/crypto/engine/eng_init.c',
>> +            'crypto/openssl/crypto/engine/tb_dsa.c',
>> +            'crypto/openssl/crypto/engine/eng_pkey.c',
>> +            'crypto/openssl/crypto/engine/eng_cnf.c',
>> +            'crypto/openssl/crypto/engine/eng_ctrl.c',
>> +            'crypto/openssl/crypto/engine/eng_list.c',
>> +            'crypto/openssl/crypto/engine/tb_cipher.c',
>> +            'crypto/openssl/crypto/engine/tb_dh.c',
>> +            'crypto/openssl/crypto/engine/eng_rdrand.c',
>> +            'crypto/openssl/crypto/engine/tb_rsa.c',
>> +            'crypto/openssl/crypto/engine/tb_pkmeth.c',
>> +            'crypto/openssl/crypto/engine/eng_cryptodev.c',
>> +            'crypto/openssl/crypto/engine/tb_digest.c',
>> +            'crypto/openssl/crypto/engine/tb_ecdh.c',
>> +            'crypto/openssl/crypto/engine/enginetest.c',
>> +            'crypto/openssl/crypto/engine/eng_fat.c',
>> +            'crypto/openssl/crypto/engine/tb_rand.c',
>> +            'crypto/openssl/crypto/engine/eng_table.c',
>> +            'crypto/openssl/crypto/cryptlib.c',
>> +            'crypto/openssl/crypto/comp/comp_lib.c',
>> +            'crypto/openssl/crypto/comp/c_rle.c',
>> +            'crypto/openssl/crypto/comp/c_zlib.c',
>> +            'crypto/openssl/crypto/comp/comp_err.c',
>> +            'crypto/openssl/crypto/ecdsa/ecs_sign.c',
>> +            'crypto/openssl/crypto/ecdsa/ecs_vrf.c',
>> +            'crypto/openssl/crypto/ecdsa/ecdsatest.c',
>> +            'crypto/openssl/crypto/ecdsa/ecs_ossl.c',
>> +            'crypto/openssl/crypto/ecdsa/ecs_asn1.c',
>> +            'crypto/openssl/crypto/ecdsa/ecs_err.c',
>> +            'crypto/openssl/crypto/ecdsa/ecs_lib.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_key.c',
>> +            'crypto/openssl/crypto/pkcs12/pk12err.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_asn.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_crpt.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_init.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_p8e.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_p8d.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_mutl.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_utl.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_kiss.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_decr.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_crt.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_add.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_npas.c',
>> +            'crypto/openssl/crypto/pkcs12/p12_attr.c',
>> +            'crypto/openssl/crypto/srp/srp_lib.c',
>> +            'crypto/openssl/crypto/srp/srp_vfy.c',
>> +            'crypto/openssl/crypto/srp/srptest.c',
>> +            'crypto/openssl/crypto/x509v3/pcy_lib.c',
>> +            'crypto/openssl/crypto/x509v3/v3_pmaps.c',
>> +            'crypto/openssl/crypto/x509v3/v3_akeya.c',
>> +            'crypto/openssl/crypto/x509v3/pcy_cache.c',
>> +            'crypto/openssl/crypto/x509v3/v3_extku.c',
>> +            'crypto/openssl/crypto/x509v3/v3_bcons.c',
>> +            'crypto/openssl/crypto/x509v3/v3_scts.c',
>> +            'crypto/openssl/crypto/x509v3/v3_utl.c',
>> +            'crypto/openssl/crypto/x509v3/v3_ia5.c',
>> +            'crypto/openssl/crypto/x509v3/v3nametest.c',
>> +            'crypto/openssl/crypto/x509v3/v3_pci.c',
>> +            'crypto/openssl/crypto/x509v3/v3_int.c',
>> +            'crypto/openssl/crypto/x509v3/v3_crld.c',
>> +            'crypto/openssl/crypto/x509v3/v3_bitst.c',
>> +            'crypto/openssl/crypto/x509v3/v3_cpols.c',
>> +            'crypto/openssl/crypto/x509v3/v3_sxnet.c',
>> +            'crypto/openssl/crypto/x509v3/v3_alt.c',
>> +            'crypto/openssl/crypto/x509v3/pcy_node.c',
>> +            'crypto/openssl/crypto/x509v3/tabtest.c',
>> +            'crypto/openssl/crypto/x509v3/v3_pcia.c',
>> +            'crypto/openssl/crypto/x509v3/v3_pku.c',
>> +            'crypto/openssl/crypto/x509v3/v3_info.c',
>> +            'crypto/openssl/crypto/x509v3/v3_genn.c',
>> +            'crypto/openssl/crypto/x509v3/pcy_data.c',
>> +            'crypto/openssl/crypto/x509v3/v3_enum.c',
>> +            'crypto/openssl/crypto/x509v3/v3err.c',
>> +            'crypto/openssl/crypto/x509v3/v3_lib.c',
>> +            'crypto/openssl/crypto/x509v3/v3_pcons.c',
>> +            'crypto/openssl/crypto/x509v3/pcy_tree.c',
>> +            'crypto/openssl/crypto/x509v3/v3_conf.c',
>> +            'crypto/openssl/crypto/x509v3/v3_asid.c',
>> +            'crypto/openssl/crypto/x509v3/v3_akey.c',
>> +            'crypto/openssl/crypto/x509v3/v3_addr.c',
>> +            'crypto/openssl/crypto/x509v3/pcy_map.c',
>> +            'crypto/openssl/crypto/x509v3/v3_ocsp.c',
>> +            'crypto/openssl/crypto/x509v3/v3prin.c',
>> +            'crypto/openssl/crypto/x509v3/v3_skey.c',
>> +            'crypto/openssl/crypto/x509v3/v3_purp.c',
>> +            'crypto/openssl/crypto/x509v3/v3_ncons.c',
>> +            'crypto/openssl/crypto/x509v3/v3_prn.c',
>> +            'crypto/openssl/crypto/aes/aes_core.c',
>> +            'crypto/openssl/crypto/aes/aes_ige.c',
>> +            'crypto/openssl/crypto/aes/aes_ofb.c',
>> +            'crypto/openssl/crypto/aes/aes_cfb.c',
>> +            'crypto/openssl/crypto/aes/aes_cbc.c',
>> +            'crypto/openssl/crypto/aes/aes_ctr.c',
>> +            'crypto/openssl/crypto/aes/aes_misc.c',
>> +            'crypto/openssl/crypto/aes/aes_ecb.c',
>> +            'crypto/openssl/crypto/aes/aes_wrap.c',
>> +            'crypto/openssl/crypto/o_dir.c',
>> +            'crypto/openssl/crypto/bf/bf_opts.c',
>> +            'crypto/openssl/crypto/bf/bf_ofb64.c',
>> +            'crypto/openssl/crypto/bf/bf_skey.c',
>> +            'crypto/openssl/crypto/bf/bftest.c',
>> +            'crypto/openssl/crypto/bf/bf_enc.c',
>> +            'crypto/openssl/crypto/bf/bfspeed.c',
>> +            'crypto/openssl/crypto/bf/bf_cfb64.c',
>> +            'crypto/openssl/crypto/bf/bf_cbc.c',
>> +            'crypto/openssl/crypto/bf/bf_ecb.c',
>> +            'crypto/openssl/crypto/rc4/rc4_utl.c',
>> +            'crypto/openssl/crypto/rc4/rc4_enc.c',
>> +            'crypto/openssl/crypto/rc4/rc4speed.c',
>> +            'crypto/openssl/crypto/rc4/rc4_skey.c',
>> +            'crypto/openssl/crypto/rc4/rc4test.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_err.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_prn.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_cl.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_vfy.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_lib.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_srv.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_asn.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_ht.c',
>> +            'crypto/openssl/crypto/ocsp/ocsp_ext.c',
>> +            'crypto/openssl/crypto/rc2/rc2speed.c',
>> +            'crypto/openssl/crypto/rc2/rc2_skey.c',
>> +            'crypto/openssl/crypto/rc2/rc2_ecb.c',
>> +            'crypto/openssl/crypto/rc2/rc2ofb64.c',
>> +            'crypto/openssl/crypto/rc2/rc2test.c',
>> +            'crypto/openssl/crypto/rc2/tab.c',
>> +            'crypto/openssl/crypto/rc2/rc2cfb64.c',
>> +            'crypto/openssl/crypto/rc2/rc2_cbc.c',
>> +            'crypto/openssl/crypto/md5/md5_one.c',
>> +            'crypto/openssl/crypto/md5/md5test.c',
>> +            'crypto/openssl/crypto/md5/md5_dgst.c',
>> +            'crypto/openssl/crypto/md5/md5.c',
>> +            'crypto/openssl/crypto/des/rpw.c',
>> +            'crypto/openssl/crypto/des/cbc_cksm.c',
>> +            'crypto/openssl/crypto/des/speed.c',
>> +            'crypto/openssl/crypto/des/str2key.c',
>> +            'crypto/openssl/crypto/des/rpc_enc.c',
>> +            'crypto/openssl/crypto/des/ecb_enc.c',
>> +            'crypto/openssl/crypto/des/cfb64enc.c',
>> +            'crypto/openssl/crypto/des/des_old2.c',
>> +            'crypto/openssl/crypto/des/fcrypt_b.c',
>> +            'crypto/openssl/crypto/des/cfb_enc.c',
>> +            'crypto/openssl/crypto/des/ofb64ede.c',
>> +            'crypto/openssl/crypto/des/cbc_enc.c',
>> +            'crypto/openssl/crypto/des/set_key.c',
>> +            'crypto/openssl/crypto/des/enc_read.c',
>> +            'crypto/openssl/crypto/des/cbc3_enc.c',
>> +            'crypto/openssl/crypto/des/ncbc_enc.c',
>> +            'crypto/openssl/crypto/des/ofb64enc.c',
>> +            'crypto/openssl/crypto/des/qud_cksm.c',
>> +            'crypto/openssl/crypto/des/read_pwd.c',
>> +            'crypto/openssl/crypto/des/cfb64ede.c',
>> +            'crypto/openssl/crypto/des/des.c',
>> +            'crypto/openssl/crypto/des/fcrypt.c',
>> +            'crypto/openssl/crypto/des/ofb_enc.c',
>> +            'crypto/openssl/crypto/des/rand_key.c',
>> +            'crypto/openssl/crypto/des/enc_writ.c',
>> +            'crypto/openssl/crypto/des/xcbc_enc.c',
>> +            'crypto/openssl/crypto/des/ede_cbcm_enc.c',
>> +            'crypto/openssl/crypto/des/read2pwd.c',
>> +            'crypto/openssl/crypto/des/pcbc_enc.c',
>> +            'crypto/openssl/crypto/des/des_enc.c',
>> +            'crypto/openssl/crypto/des/ecb3_enc.c',
>> +            'crypto/openssl/crypto/cpt_err.c',
>> +            'crypto/openssl/crypto/o_init.c',
>> +            'crypto/openssl/crypto/krb5/krb5_asn.c',
>> +            'crypto/openssl/crypto/mem_dbg.c',
>> +            'crypto/openssl/crypto/constant_time_test.c',
>> +            'crypto/openssl/crypto/ebcdic.c',
>> +            'crypto/openssl/crypto/camellia/camellia.c',
>> +            'crypto/openssl/crypto/camellia/cmll_misc.c',
>> +            'crypto/openssl/crypto/camellia/cmll_cbc.c',
>> +            'crypto/openssl/crypto/camellia/cmll_utl.c',
>> +            'crypto/openssl/crypto/camellia/cmll_ofb.c',
>> +            'crypto/openssl/crypto/camellia/cmll_ecb.c',
>> +            'crypto/openssl/crypto/camellia/cmll_ctr.c',
>> +            'crypto/openssl/crypto/camellia/cmll_cfb.c',
>> +            'crypto/openssl/crypto/x509/x509_r2x.c',
>> +            'crypto/openssl/crypto/x509/x509type.c',
>> +            'crypto/openssl/crypto/x509/x509_vfy.c',
>> +            'crypto/openssl/crypto/x509/x509_set.c',
>> +            'crypto/openssl/crypto/x509/x509_lu.c',
>> +            'crypto/openssl/crypto/x509/x509_trs.c',
>> +            'crypto/openssl/crypto/x509/verify_extra_test.c',
>> +            'crypto/openssl/crypto/x509/x509rset.c',
>> +            'crypto/openssl/crypto/x509/x509_ext.c',
>> +            'crypto/openssl/crypto/x509/x_all.c',
>> +            'crypto/openssl/crypto/x509/x509_vpm.c',
>> +            'crypto/openssl/crypto/x509/x509_v3.c',
>> +            'crypto/openssl/crypto/x509/x509_err.c',
>> +            'crypto/openssl/crypto/x509/by_file.c',
>> +            'crypto/openssl/crypto/x509/x509_txt.c',
>> +            'crypto/openssl/crypto/x509/x509_obj.c',
>> +            'crypto/openssl/crypto/x509/x509_att.c',
>> +            'crypto/openssl/crypto/x509/by_dir.c',
>> +            'crypto/openssl/crypto/x509/x509_cmp.c',
>> +            'crypto/openssl/crypto/x509/x509spki.c',
>> +            'crypto/openssl/crypto/x509/x509_def.c',
>> +            'crypto/openssl/crypto/x509/x509_d2.c',
>> +            'crypto/openssl/crypto/x509/x509_req.c',
>> +            'crypto/openssl/crypto/x509/x509cset.c',
>> +            'crypto/openssl/crypto/x509/x509name.c',
>> +            'crypto/openssl/crypto/threads/th-lock.c',
>> +            'crypto/openssl/crypto/threads/mttest.c',
>> +            'crypto/openssl/crypto/seed/seed_cfb.c',
>> +            'crypto/openssl/crypto/seed/seed_cbc.c',
>> +            'crypto/openssl/crypto/seed/seed.c',
>> +            'crypto/openssl/crypto/seed/seed_ecb.c',
>> +            'crypto/openssl/crypto/seed/seed_ofb.c',
>> +            'crypto/openssl/crypto/objects/obj_err.c',
>> +            'crypto/openssl/crypto/objects/o_names.c',
>> +            'crypto/openssl/crypto/objects/obj_dat.c',
>> +            'crypto/openssl/crypto/objects/obj_xref.c',
>> +            'crypto/openssl/crypto/objects/obj_lib.c',
>> +            'crypto/openssl/crypto/ts/ts_asn1.c',
>> +            'crypto/openssl/crypto/ts/ts_req_print.c',
>> +            'crypto/openssl/crypto/ts/ts_rsp_print.c',
>> +            'crypto/openssl/crypto/ts/ts_rsp_sign.c',
>> +            'crypto/openssl/crypto/ts/ts_conf.c',
>> +            'crypto/openssl/crypto/ts/ts_rsp_verify.c',
>> +            'crypto/openssl/crypto/ts/ts_req_utils.c',
>> +            'crypto/openssl/crypto/ts/ts_rsp_utils.c',
>> +            'crypto/openssl/crypto/ts/ts_err.c',
>> +            'crypto/openssl/crypto/ts/ts_verify_ctx.c',
>> +            'crypto/openssl/crypto/ts/ts_lib.c',
>> +            'crypto/openssl/crypto/mdc2/mdc2dgst.c',
>> +            'crypto/openssl/crypto/mdc2/mdc2_one.c',
>> +            'crypto/openssl/crypto/mdc2/mdc2test.c',
>> +            'crypto/openssl/crypto/pqueue/pqueue.c',
>> +            'crypto/openssl/crypto/pqueue/pq_test.c',
>> +            'crypto/openssl/crypto/buffer/buf_str.c',
>> +            'crypto/openssl/crypto/buffer/buffer.c',
>> +            'crypto/openssl/crypto/buffer/buf_err.c',
>> +            'crypto/openssl/crypto/o_fips.c',
>> +            'crypto/openssl/crypto/mem_clr.c',
>> +            'crypto/openssl/crypto/cast/c_skey.c',
>> +            'crypto/openssl/crypto/cast/c_ecb.c',
>> +            'crypto/openssl/crypto/cast/cast_spd.c',
>> +            'crypto/openssl/crypto/cast/c_ofb64.c',
>> +            'crypto/openssl/crypto/cast/c_cfb64.c',
>> +            'crypto/openssl/crypto/cast/c_enc.c',
>> +            'crypto/openssl/crypto/cast/castopts.c',
>> +            'crypto/openssl/crypto/cast/casttest.c',
>> +            'crypto/openssl/crypto/rsa/rsa_gen.c',
>> +            'crypto/openssl/crypto/rsa/rsa_none.c',
>> +            'crypto/openssl/crypto/rsa/rsa_ameth.c',
>> +            'crypto/openssl/crypto/rsa/rsa_crpt.c',
>> +            'crypto/openssl/crypto/rsa/rsa_pss.c',
>> +            'crypto/openssl/crypto/rsa/rsa_pmeth.c',
>> +            'crypto/openssl/crypto/rsa/rsa_sign.c',
>> +            'crypto/openssl/crypto/rsa/rsa_eay.c',
>> +            'crypto/openssl/crypto/rsa/rsa_oaep.c',
>> +            'crypto/openssl/crypto/rsa/rsa_saos.c',
>> +            'crypto/openssl/crypto/rsa/rsa_pk1.c',
>> +            'crypto/openssl/crypto/rsa/rsa_asn1.c',
>> +            'crypto/openssl/crypto/rsa/rsa_depr.c',
>> +            'crypto/openssl/crypto/rsa/rsa_err.c',
>> +            'crypto/openssl/crypto/rsa/rsa_prn.c',
>> +            'crypto/openssl/crypto/rsa/rsa_test.c',
>> +            'crypto/openssl/crypto/rsa/rsa_lib.c',
>> +            'crypto/openssl/crypto/rsa/rsa_chk.c',
>> +            'crypto/openssl/crypto/rsa/rsa_x931.c',
>> +            'crypto/openssl/crypto/rsa/rsa_null.c',
>> +            'crypto/openssl/crypto/rsa/rsa_ssl.c',
>> +            'crypto/openssl/crypto/o_dir_test.c',
>> +            'crypto/openssl/crypto/sparcv9cap.c',
>> +            'crypto/openssl/crypto/whrlpool/wp_dgst.c',
>> +            'crypto/openssl/crypto/whrlpool/wp_block.c',
>> +            'crypto/openssl/crypto/whrlpool/wp_test.c',
>> +            'crypto/openssl/crypto/asn1/f_string.c',
>> +            'crypto/openssl/crypto/asn1/t_req.c',
>> +            'crypto/openssl/crypto/asn1/x_long.c',
>> +            'crypto/openssl/crypto/asn1/tasn_utl.c',
>> +            'crypto/openssl/crypto/asn1/p5_pbev2.c',
>> +            'crypto/openssl/crypto/asn1/a_time.c',
>> +            'crypto/openssl/crypto/asn1/t_crl.c',
>> +            'crypto/openssl/crypto/asn1/p5_pbe.c',
>> +            'crypto/openssl/crypto/asn1/asn1_gen.c',
>> +            'crypto/openssl/crypto/asn1/t_x509.c',
>> +            'crypto/openssl/crypto/asn1/x_bignum.c',
>> +            'crypto/openssl/crypto/asn1/x_attrib.c',
>> +            'crypto/openssl/crypto/asn1/x_x509.c',
>> +            'crypto/openssl/crypto/asn1/x_spki.c',
>> +            'crypto/openssl/crypto/asn1/x_nx509.c',
>> +            'crypto/openssl/crypto/asn1/tasn_prn.c',
>> +            'crypto/openssl/crypto/asn1/x_pkey.c',
>> +            'crypto/openssl/crypto/asn1/x_algor.c',
>> +            'crypto/openssl/crypto/asn1/x_sig.c',
>> +            'crypto/openssl/crypto/asn1/a_i2d_fp.c',
>> +            'crypto/openssl/crypto/asn1/x_exten.c',
>> +            'crypto/openssl/crypto/asn1/bio_asn1.c',
>> +            'crypto/openssl/crypto/asn1/n_pkey.c',
>> +            'crypto/openssl/crypto/asn1/asn1_par.c',
>> +            'crypto/openssl/crypto/asn1/p8_pkey.c',
>> +            'crypto/openssl/crypto/asn1/t_x509a.c',
>> +            'crypto/openssl/crypto/asn1/x_x509a.c',
>> +            'crypto/openssl/crypto/asn1/bio_ndef.c',
>> +            'crypto/openssl/crypto/asn1/a_strnid.c',
>> +            'crypto/openssl/crypto/asn1/x_pubkey.c',
>> +            'crypto/openssl/crypto/asn1/x_name.c',
>> +            'crypto/openssl/crypto/asn1/tasn_dec.c',
>> +            'crypto/openssl/crypto/asn1/f_enum.c',
>> +            'crypto/openssl/crypto/asn1/t_spki.c',
>> +            'crypto/openssl/crypto/asn1/d2i_pu.c',
>> +            'crypto/openssl/crypto/asn1/a_sign.c',
>> +            'crypto/openssl/crypto/asn1/a_bitstr.c',
>> +            'crypto/openssl/crypto/asn1/a_set.c',
>> +            'crypto/openssl/crypto/asn1/a_mbstr.c',
>> +            'crypto/openssl/crypto/asn1/x_info.c',
>> +            'crypto/openssl/crypto/asn1/asn_moid.c',
>> +            'crypto/openssl/crypto/asn1/tasn_typ.c',
>> +            'crypto/openssl/crypto/asn1/a_octet.c',
>> +            'crypto/openssl/crypto/asn1/a_digest.c',
>> +            'crypto/openssl/crypto/asn1/t_pkey.c',
>> +            'crypto/openssl/crypto/asn1/x_crl.c',
>> +            'crypto/openssl/crypto/asn1/i2d_pr.c',
>> +            'crypto/openssl/crypto/asn1/a_gentm.c',
>> +            'crypto/openssl/crypto/asn1/x_req.c',
>> +            'crypto/openssl/crypto/asn1/d2i_pr.c',
>> +            'crypto/openssl/crypto/asn1/nsseq.c',
>> +            'crypto/openssl/crypto/asn1/a_enum.c',
>> +            'crypto/openssl/crypto/asn1/a_bool.c',
>> +            'crypto/openssl/crypto/asn1/a_d2i_fp.c',
>> +            'crypto/openssl/crypto/asn1/tasn_enc.c',
>> +            'crypto/openssl/crypto/asn1/a_type.c',
>> +            'crypto/openssl/crypto/asn1/t_bitst.c',
>> +            'crypto/openssl/crypto/asn1/asn1_lib.c',
>> +            'crypto/openssl/crypto/asn1/a_dup.c',
>> +            'crypto/openssl/crypto/asn1/a_int.c',
>> +            'crypto/openssl/crypto/asn1/a_object.c',
>> +            'crypto/openssl/crypto/asn1/i2d_pu.c',
>> +            'crypto/openssl/crypto/asn1/a_print.c',
>> +            'crypto/openssl/crypto/asn1/x_val.c',
>> +            'crypto/openssl/crypto/asn1/a_utctm.c',
>> +            'crypto/openssl/crypto/asn1/a_utf8.c',
>> +            'crypto/openssl/crypto/asn1/f_int.c',
>> +            'crypto/openssl/crypto/asn1/ameth_lib.c',
>> +            'crypto/openssl/crypto/asn1/asn_pack.c',
>> +            'crypto/openssl/crypto/asn1/a_bytes.c',
>> +            'crypto/openssl/crypto/asn1/asn_mime.c',
>> +            'crypto/openssl/crypto/asn1/a_verify.c',
>> +            'crypto/openssl/crypto/asn1/evp_asn1.c',
>> +            'crypto/openssl/crypto/asn1/a_strex.c',
>> +            'crypto/openssl/crypto/asn1/tasn_new.c',
>> +            'crypto/openssl/crypto/asn1/asn1_err.c',
>> +            'crypto/openssl/crypto/asn1/tasn_fre.c',
>> +            'crypto/openssl/crypto/ec/ecp_smpl.c',
>> +            'crypto/openssl/crypto/ec/ec2_mult.c',
>> +            'crypto/openssl/crypto/ec/ecp_nistz256.c',
>> +            'crypto/openssl/crypto/ec/ecp_nistp521.c',
>> +            'crypto/openssl/crypto/ec/ec2_smpl.c',
>> +            'crypto/openssl/crypto/ec/ec_key.c',
>> +            'crypto/openssl/crypto/ec/ec_cvt.c',
>> +            'crypto/openssl/crypto/ec/ecp_nist.c',
>> +            'crypto/openssl/crypto/ec/ec2_oct.c',
>> +            'crypto/openssl/crypto/ec/ec_ameth.c',
>> +            'crypto/openssl/crypto/ec/ec_pmeth.c',
>> +            'crypto/openssl/crypto/ec/ec_oct.c',
>> +            'crypto/openssl/crypto/ec/ec_err.c',
>> +            'crypto/openssl/crypto/ec/ec_print.c',
>> +            'crypto/openssl/crypto/ec/ecp_oct.c',
>> +            'crypto/openssl/crypto/ec/ec_check.c',
>> +            'crypto/openssl/crypto/ec/ecp_nistp224.c',
>> +            'crypto/openssl/crypto/ec/eck_prn.c',
>> +            'crypto/openssl/crypto/ec/ec_mult.c',
>> +            'crypto/openssl/crypto/ec/ecp_mont.c',
>> +            'crypto/openssl/crypto/ec/ec_curve.c',
>> +            'crypto/openssl/crypto/ec/ecp_nistputil.c',
>> +            'crypto/openssl/crypto/ec/ectest.c',
>> +            'crypto/openssl/crypto/ec/ec_asn1.c',
>> +            'crypto/openssl/crypto/ec/ecp_nistp256.c',
>> +            'crypto/openssl/crypto/ec/ec_lib.c',
>> +            'crypto/openssl/crypto/conf/conf_sap.c',
>> +            'crypto/openssl/crypto/conf/conf_api.c',
>> +            'crypto/openssl/crypto/conf/conf_err.c',
>> +            'crypto/openssl/crypto/conf/conf_mall.c',
>> +            'crypto/openssl/crypto/conf/conf_lib.c',
>> +            'crypto/openssl/crypto/conf/conf_def.c',
>> +            'crypto/openssl/crypto/conf/conf_mod.c',
>> +            'crypto/openssl/crypto/lhash/lhash.c',
>> +            'crypto/openssl/crypto/cversion.c',
>> +            'crypto/openssl/crypto/o_str.c',
>> +        mm.generator['source'](['-DOPENSSL_NO_DEPRECATED=1',
>> +                                '-DOPENSSL_NO_EC_NISTP_64_GCC_128=1',
>> +                                '-DOPENSSL_NO_GMP=1',
>> +                                '-DOPENSSL_NO_JPAKE=1',
>> +                                '-DOPENSSL_NO_LIBUNBOUND=1',
>> +                                '-DOPENSSL_NO_MD2=1',
>> +                                '-DOPENSSL_NO_RC5=1',
>> +                                '-DOPENSSL_NO_RFC3779=1',
>> +                                '-DOPENSSL_NO_SCTP=1',
>> +                                '-DOPENSSL_NO_SSL_TRACE=1',
>> +                                '-DOPENSSL_NO_SSL2=1',
>> +                                '-DOPENSSL_NO_STORE=1',
>> +                                '-DOPENSSL_NO_UNIT_TEST=1',
>> +                                '-DOPENSSL_NO_WEAK_SSL_CIPHERS=1',
>> +                                '-DNO_WINDOWS_BRAINDEATH=1',
>> +                                '-DOPENSSL_DISABLE_OLD_DES_SUPPORT=1'],
>> +                               ['freebsd/crypto',
>> +                                'freebsd/crypto/openssl',
>> +                                'freebsd/crypto/openssl/crypto',
>> +                                'freebsd/crypto/openssl/crypto/evp',
>> +                                'freebsd/crypto/openssl/crypto/asn1',
>> +                                'freebsd/crypto/openssl/crypto/modes'])
>> +    mod.addFile(mm.generator['file']('crypto/openssl/crypto/LPdir_unix.c',
>> +                                     mm.generator['freebsd-path'](),
>> +                                     mm.generator['from-FreeBSD-to-RTEMS-UserSpaceSourceConverter'](),
>> +                                     mm.generator['from-RTEMS-To-FreeBSD-SourceConverter'](),
>> +                                     mm.generator['buildSystemFragmentComposer']()))
>> +    mod.addFile(mm.generator['file']('crypto/openssl/crypto/ec/ecp_nistz256_table.c',
>> +    return mod
>>  # Contrib expat
>>  def contrib_expat(mm):
>> @@ -3285,6 +4236,7 @@ def sources(mm):
>>      mm.addModule(contrib_expat(mm))
>>      mm.addModule(contrib_libpcap(mm))
>>      mm.addModule(usr_sbin_tcpdump(mm))
>> +    mm.addModule(crypto_openssl(mm))
>>      mm.addModule(tests(mm))
>>      mm.addModule(dhcpcd(mm))
>> diff --git a/libbsd_waf.py b/libbsd_waf.py
>> index 1784f8b..afdf510 100644
>> --- a/libbsd_waf.py
>> +++ b/libbsd_waf.py
>> @@ -126,6 +126,63 @@ def build(bld):
>>      # copy headers if necessary
>>      header_build_copy_paths = [
>>      for headers in header_build_copy_paths:
>>          target = os.path.join("libbsd_build/include", headers[2])
>> @@ -510,7 +567,761 @@ def build(bld):
>>                  source = objs03_source)
>>      libbsd_use += ["objs03"]
>> -    objs04_source = ['freebsd/lib/libc/db/btree/bt_close.c',
>> +    objs04_source = ['freebsd/crypto/openssl/crypto/aes/aes_cbc.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_cfb.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_core.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_ctr.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_ecb.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_ige.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_misc.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_ofb.c',
>> +                     'freebsd/crypto/openssl/crypto/aes/aes_wrap.c',
>> +                     'freebsd/crypto/openssl/crypto/armcap.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_bitstr.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_bool.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_bytes.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_d2i_fp.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_digest.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_dup.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_enum.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_gentm.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_i2d_fp.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_int.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_mbstr.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_object.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_octet.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_print.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_set.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_sign.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_strex.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_strnid.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_time.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_type.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_utctm.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_utf8.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/a_verify.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/ameth_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/asn1_err.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/asn1_gen.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/asn1_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/asn1_par.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/asn_mime.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/asn_moid.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/asn_pack.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/bio_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/bio_ndef.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/d2i_pr.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/d2i_pu.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/evp_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/f_enum.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/f_int.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/f_string.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/i2d_pr.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/i2d_pu.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/n_pkey.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/nsseq.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/p5_pbe.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/p5_pbev2.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/p8_pkey.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/t_bitst.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/t_crl.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/t_pkey.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/t_req.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/t_spki.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/t_x509.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/t_x509a.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/tasn_dec.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/tasn_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/tasn_fre.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/tasn_new.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/tasn_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/tasn_typ.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/tasn_utl.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_algor.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_attrib.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_bignum.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_crl.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_exten.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_info.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_long.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_name.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_nx509.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_pkey.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_pubkey.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_req.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_sig.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_spki.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_val.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_x509.c',
>> +                     'freebsd/crypto/openssl/crypto/asn1/x_x509a.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bf_cbc.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bf_cfb64.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bf_ecb.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bf_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bf_ofb64.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bf_opts.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bf_skey.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bfspeed.c',
>> +                     'freebsd/crypto/openssl/crypto/bf/bftest.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/b_dump.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/b_print.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/b_sock.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bf_buff.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bf_lbuf.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bf_nbio.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bf_null.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bio_cb.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bio_err.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bio_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_acpt.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_bio.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_conn.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_dgram.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_fd.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_file.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_log.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_mem.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_null.c',
>> +                     'freebsd/crypto/openssl/crypto/bio/bss_sock.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_add.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_asm.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_blind.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_const.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_ctx.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_depr.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_div.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_err.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_exp.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_exp2.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_gcd.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_gf2m.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_kron.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_mod.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_mont.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_mpi.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_mul.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_nist.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_prime.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_print.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_rand.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_recp.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_shift.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_sqr.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_sqrt.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_word.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bn_x931p.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bnspeed.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/bntest.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/divtest.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/expspeed.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/exptest.c',
>> +                     'freebsd/crypto/openssl/crypto/bn/rsaz_exp.c',
>> +                     'freebsd/crypto/openssl/crypto/buffer/buf_err.c',
>> +                     'freebsd/crypto/openssl/crypto/buffer/buf_str.c',
>> +                     'freebsd/crypto/openssl/crypto/buffer/buffer.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/camellia.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/cmll_cbc.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/cmll_cfb.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/cmll_ctr.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/cmll_ecb.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/cmll_misc.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/cmll_ofb.c',
>> +                     'freebsd/crypto/openssl/crypto/camellia/cmll_utl.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/c_cfb64.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/c_ecb.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/c_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/c_ofb64.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/c_skey.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/cast_spd.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/castopts.c',
>> +                     'freebsd/crypto/openssl/crypto/cast/casttest.c',
>> +                     'freebsd/crypto/openssl/crypto/cmac/cm_ameth.c',
>> +                     'freebsd/crypto/openssl/crypto/cmac/cm_pmeth.c',
>> +                     'freebsd/crypto/openssl/crypto/cmac/cmac.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_att.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_cd.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_dd.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_env.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_err.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_ess.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_io.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_kari.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_pwri.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_sd.c',
>> +                     'freebsd/crypto/openssl/crypto/cms/cms_smime.c',
>> +                     'freebsd/crypto/openssl/crypto/comp/c_rle.c',
>> +                     'freebsd/crypto/openssl/crypto/comp/c_zlib.c',
>> +                     'freebsd/crypto/openssl/crypto/comp/comp_err.c',
>> +                     'freebsd/crypto/openssl/crypto/comp/comp_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/conf/conf_api.c',
>> +                     'freebsd/crypto/openssl/crypto/conf/conf_def.c',
>> +                     'freebsd/crypto/openssl/crypto/conf/conf_err.c',
>> +                     'freebsd/crypto/openssl/crypto/conf/conf_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/conf/conf_mall.c',
>> +                     'freebsd/crypto/openssl/crypto/conf/conf_mod.c',
>> +                     'freebsd/crypto/openssl/crypto/conf/conf_sap.c',
>> +                     'freebsd/crypto/openssl/crypto/constant_time_test.c',
>> +                     'freebsd/crypto/openssl/crypto/cpt_err.c',
>> +                     'freebsd/crypto/openssl/crypto/cryptlib.c',
>> +                     'freebsd/crypto/openssl/crypto/cversion.c',
>> +                     'freebsd/crypto/openssl/crypto/des/cbc3_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/cbc_cksm.c',
>> +                     'freebsd/crypto/openssl/crypto/des/cbc_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/cfb64ede.c',
>> +                     'freebsd/crypto/openssl/crypto/des/cfb64enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/cfb_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/des.c',
>> +                     'freebsd/crypto/openssl/crypto/des/des_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/des_old2.c',
>> +                     'freebsd/crypto/openssl/crypto/des/ecb3_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/ecb_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/ede_cbcm_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/enc_read.c',
>> +                     'freebsd/crypto/openssl/crypto/des/enc_writ.c',
>> +                     'freebsd/crypto/openssl/crypto/des/fcrypt.c',
>> +                     'freebsd/crypto/openssl/crypto/des/fcrypt_b.c',
>> +                     'freebsd/crypto/openssl/crypto/des/ncbc_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/ofb64ede.c',
>> +                     'freebsd/crypto/openssl/crypto/des/ofb64enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/ofb_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/pcbc_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/qud_cksm.c',
>> +                     'freebsd/crypto/openssl/crypto/des/rand_key.c',
>> +                     'freebsd/crypto/openssl/crypto/des/read2pwd.c',
>> +                     'freebsd/crypto/openssl/crypto/des/read_pwd.c',
>> +                     'freebsd/crypto/openssl/crypto/des/rpc_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/des/rpw.c',
>> +                     'freebsd/crypto/openssl/crypto/des/set_key.c',
>> +                     'freebsd/crypto/openssl/crypto/des/speed.c',
>> +                     'freebsd/crypto/openssl/crypto/des/str2key.c',
>> +                     'freebsd/crypto/openssl/crypto/des/xcbc_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_ameth.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_check.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_depr.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_err.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_gen.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_kdf.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_key.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_pmeth.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dh_rfc5114.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/dhtest.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/p1024.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/p192.c',
>> +                     'freebsd/crypto/openssl/crypto/dh/p512.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_ameth.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_depr.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_err.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_gen.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_key.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_ossl.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_pmeth.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_sign.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsa_vrf.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsagen.c',
>> +                     'freebsd/crypto/openssl/crypto/dsa/dsatest.c',
>> +                     'freebsd/crypto/openssl/crypto/dso/dso_beos.c',
>> +                     'freebsd/crypto/openssl/crypto/dso/dso_dl.c',
>> +                     'freebsd/crypto/openssl/crypto/dso/dso_dlfcn.c',
>> +                     'freebsd/crypto/openssl/crypto/dso/dso_err.c',
>> +                     'freebsd/crypto/openssl/crypto/dso/dso_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/dso/dso_null.c',
>> +                     'freebsd/crypto/openssl/crypto/dso/dso_openssl.c',
>> +                     'freebsd/crypto/openssl/crypto/ebcdic.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec2_mult.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec2_oct.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec2_smpl.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_ameth.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_check.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_curve.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_cvt.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_err.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_key.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_mult.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_oct.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_pmeth.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ec_print.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/eck_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_mont.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_nist.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_nistp224.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_nistp256.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_nistp521.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_nistputil.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_nistz256.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_oct.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ecp_smpl.c',
>> +                     'freebsd/crypto/openssl/crypto/ec/ectest.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdh/ecdhtest.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdh/ech_err.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdh/ech_kdf.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdh/ech_key.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdh/ech_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdh/ech_ossl.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdsa/ecdsatest.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdsa/ecs_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdsa/ecs_err.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdsa/ecs_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdsa/ecs_ossl.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdsa/ecs_sign.c',
>> +                     'freebsd/crypto/openssl/crypto/ecdsa/ecs_vrf.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_all.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_cnf.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_cryptodev.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_ctrl.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_dyn.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_err.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_fat.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_init.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_list.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_openssl.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_pkey.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_rdrand.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/eng_table.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/enginetest.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_asnmth.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_cipher.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_dh.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_digest.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_dsa.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_ecdh.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_ecdsa.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_pkmeth.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_rand.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_rsa.c',
>> +                     'freebsd/crypto/openssl/crypto/engine/tb_store.c',
>> +                     'freebsd/crypto/openssl/crypto/err/err.c',
>> +                     'freebsd/crypto/openssl/crypto/err/err_all.c',
>> +                     'freebsd/crypto/openssl/crypto/err/err_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/bio_b64.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/bio_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/bio_md.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/bio_ok.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/c_all.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/c_allc.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/c_alld.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/digest.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_aes.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha1.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_aes_cbc_hmac_sha256.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_bf.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_camellia.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_cast.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_des.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_des3.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_idea.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_null.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_old.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_rc2.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_rc4.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_rc4_hmac_md5.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_rc5.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_seed.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/e_xcbc_d.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/encode.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_acnf.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_cnf.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_err.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_extra_test.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_key.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_pbe.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_pkey.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/evp_test.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_dss.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_dss1.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_ecdsa.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_md2.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_md4.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_md5.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_mdc2.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_null.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_ripemd.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_sha.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_sha1.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_sigver.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/m_wp.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/names.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/openbsd_hw.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p5_crpt.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p5_crpt2.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p_dec.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p_open.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p_seal.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p_sign.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/p_verify.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/pmeth_fn.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/pmeth_gn.c',
>> +                     'freebsd/crypto/openssl/crypto/evp/pmeth_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/ex_data.c',
>> +                     'freebsd/crypto/openssl/crypto/fips_ers.c',
>> +                     'freebsd/crypto/openssl/crypto/hmac/hm_ameth.c',
>> +                     'freebsd/crypto/openssl/crypto/hmac/hm_pmeth.c',
>> +                     'freebsd/crypto/openssl/crypto/hmac/hmac.c',
>> +                     'freebsd/crypto/openssl/crypto/hmac/hmactest.c',
>> +                     'freebsd/crypto/openssl/crypto/idea/i_cbc.c',
>> +                     'freebsd/crypto/openssl/crypto/idea/i_cfb64.c',
>> +                     'freebsd/crypto/openssl/crypto/idea/i_ecb.c',
>> +                     'freebsd/crypto/openssl/crypto/idea/i_ofb64.c',
>> +                     'freebsd/crypto/openssl/crypto/idea/i_skey.c',
>> +                     'freebsd/crypto/openssl/crypto/idea/idea_spd.c',
>> +                     'freebsd/crypto/openssl/crypto/idea/ideatest.c',
>> +                     'freebsd/crypto/openssl/crypto/krb5/krb5_asn.c',
>> +                     'freebsd/crypto/openssl/crypto/lhash/lhash.c',
>> +                     'freebsd/crypto/openssl/crypto/md4/md4.c',
>> +                     'freebsd/crypto/openssl/crypto/md4/md4_dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/md4/md4_one.c',
>> +                     'freebsd/crypto/openssl/crypto/md4/md4test.c',
>> +                     'freebsd/crypto/openssl/crypto/md5/md5.c',
>> +                     'freebsd/crypto/openssl/crypto/md5/md5_dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/md5/md5_one.c',
>> +                     'freebsd/crypto/openssl/crypto/md5/md5test.c',
>> +                     'freebsd/crypto/openssl/crypto/mdc2/mdc2_one.c',
>> +                     'freebsd/crypto/openssl/crypto/mdc2/mdc2dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/mdc2/mdc2test.c',
>> +                     'freebsd/crypto/openssl/crypto/mem.c',
>> +                     'freebsd/crypto/openssl/crypto/mem_clr.c',
>> +                     'freebsd/crypto/openssl/crypto/mem_dbg.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/cbc128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/ccm128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/cfb128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/ctr128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/cts128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/gcm128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/ofb128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/wrap128.c',
>> +                     'freebsd/crypto/openssl/crypto/modes/xts128.c',
>> +                     'freebsd/crypto/openssl/crypto/o_dir.c',
>> +                     'freebsd/crypto/openssl/crypto/o_dir_test.c',
>> +                     'freebsd/crypto/openssl/crypto/o_fips.c',
>> +                     'freebsd/crypto/openssl/crypto/o_init.c',
>> +                     'freebsd/crypto/openssl/crypto/o_str.c',
>> +                     'freebsd/crypto/openssl/crypto/o_time.c',
>> +                     'freebsd/crypto/openssl/crypto/objects/o_names.c',
>> +                     'freebsd/crypto/openssl/crypto/objects/obj_dat.c',
>> +                     'freebsd/crypto/openssl/crypto/objects/obj_err.c',
>> +                     'freebsd/crypto/openssl/crypto/objects/obj_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/objects/obj_xref.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_asn.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_cl.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_err.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_ext.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_ht.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_srv.c',
>> +                     'freebsd/crypto/openssl/crypto/ocsp/ocsp_vfy.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_all.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_err.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_info.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_oth.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_pk8.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_pkey.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_seal.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_sign.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_x509.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pem_xaux.c',
>> +                     'freebsd/crypto/openssl/crypto/pem/pvkfmt.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_add.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_asn.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_attr.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_crpt.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_crt.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_decr.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_init.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_key.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_kiss.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_mutl.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_npas.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_p8d.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_p8e.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/p12_utl.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs12/pk12err.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/bio_pk7.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pk7_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pk7_attr.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pk7_dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pk7_doit.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pk7_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pk7_mime.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pk7_smime.c',
>> +                     'freebsd/crypto/openssl/crypto/pkcs7/pkcs7err.c',
>> +                     'freebsd/crypto/openssl/crypto/ppccap.c',
>> +                     'freebsd/crypto/openssl/crypto/pqueue/pq_test.c',
>> +                     'freebsd/crypto/openssl/crypto/pqueue/pqueue.c',
>> +                     'freebsd/crypto/openssl/crypto/rand/md_rand.c',
>> +                     'freebsd/crypto/openssl/crypto/rand/rand_egd.c',
>> +                     'freebsd/crypto/openssl/crypto/rand/rand_err.c',
>> +                     'freebsd/crypto/openssl/crypto/rand/rand_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/rand/rand_unix.c',
>> +                     'freebsd/crypto/openssl/crypto/rand/randfile.c',
>> +                     'freebsd/crypto/openssl/crypto/rand/randtest.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/rc2_cbc.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/rc2_ecb.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/rc2_skey.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/rc2cfb64.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/rc2ofb64.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/rc2speed.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/rc2test.c',
>> +                     'freebsd/crypto/openssl/crypto/rc2/tab.c',
>> +                     'freebsd/crypto/openssl/crypto/rc4/rc4_enc.c',
>> +                     'freebsd/crypto/openssl/crypto/rc4/rc4_skey.c',
>> +                     'freebsd/crypto/openssl/crypto/rc4/rc4_utl.c',
>> +                     'freebsd/crypto/openssl/crypto/rc4/rc4speed.c',
>> +                     'freebsd/crypto/openssl/crypto/rc4/rc4test.c',
>> +                     'freebsd/crypto/openssl/crypto/ripemd/rmd160.c',
>> +                     'freebsd/crypto/openssl/crypto/ripemd/rmd_dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/ripemd/rmd_one.c',
>> +                     'freebsd/crypto/openssl/crypto/ripemd/rmdtest.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_ameth.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_chk.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_crpt.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_depr.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_eay.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_err.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_gen.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_none.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_null.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_oaep.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_pk1.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_pmeth.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_pss.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_saos.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_sign.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_ssl.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_test.c',
>> +                     'freebsd/crypto/openssl/crypto/rsa/rsa_x931.c',
>> +                     'freebsd/crypto/openssl/crypto/s390xcap.c',
>> +                     'freebsd/crypto/openssl/crypto/seed/seed.c',
>> +                     'freebsd/crypto/openssl/crypto/seed/seed_cbc.c',
>> +                     'freebsd/crypto/openssl/crypto/seed/seed_cfb.c',
>> +                     'freebsd/crypto/openssl/crypto/seed/seed_ecb.c',
>> +                     'freebsd/crypto/openssl/crypto/seed/seed_ofb.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha1.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha1_one.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha1dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha1test.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha256.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha256t.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha512.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha512t.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha_dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/sha_one.c',
>> +                     'freebsd/crypto/openssl/crypto/sha/shatest.c',
>> +                     'freebsd/crypto/openssl/crypto/sparcv9cap.c',
>> +                     'freebsd/crypto/openssl/crypto/srp/srp_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/srp/srp_vfy.c',
>> +                     'freebsd/crypto/openssl/crypto/srp/srptest.c',
>> +                     'freebsd/crypto/openssl/crypto/stack/stack.c',
>> +                     'freebsd/crypto/openssl/crypto/threads/mttest.c',
>> +                     'freebsd/crypto/openssl/crypto/threads/th-lock.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_asn1.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_conf.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_err.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_req_print.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_req_utils.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_rsp_print.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_rsp_sign.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_rsp_utils.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_rsp_verify.c',
>> +                     'freebsd/crypto/openssl/crypto/ts/ts_verify_ctx.c',
>> +                     'freebsd/crypto/openssl/crypto/txt_db/txt_db.c',
>> +                     'freebsd/crypto/openssl/crypto/ui/ui_compat.c',
>> +                     'freebsd/crypto/openssl/crypto/ui/ui_err.c',
>> +                     'freebsd/crypto/openssl/crypto/ui/ui_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/ui/ui_openssl.c',
>> +                     'freebsd/crypto/openssl/crypto/ui/ui_util.c',
>> +                     'freebsd/crypto/openssl/crypto/uid.c',
>> +                     'freebsd/crypto/openssl/crypto/whrlpool/wp_block.c',
>> +                     'freebsd/crypto/openssl/crypto/whrlpool/wp_dgst.c',
>> +                     'freebsd/crypto/openssl/crypto/whrlpool/wp_test.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/by_dir.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/by_file.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/verify_extra_test.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_att.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_cmp.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_d2.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_def.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_err.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_ext.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_lu.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_obj.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_r2x.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_req.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_set.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_trs.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_txt.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_v3.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_vfy.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509_vpm.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509cset.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509name.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509rset.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509spki.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x509type.c',
>> +                     'freebsd/crypto/openssl/crypto/x509/x_all.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/pcy_cache.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/pcy_data.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/pcy_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/pcy_map.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/pcy_node.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/pcy_tree.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/tabtest.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_addr.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_akey.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_akeya.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_alt.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_asid.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_bcons.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_bitst.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_conf.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_cpols.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_crld.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_enum.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_extku.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_genn.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_ia5.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_info.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_int.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_lib.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_ncons.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_ocsp.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_pci.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_pcia.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_pcons.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_pku.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_pmaps.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_prn.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_purp.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_scts.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_skey.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_sxnet.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3_utl.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3err.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3nametest.c',
>> +                     'freebsd/crypto/openssl/crypto/x509v3/v3prin.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/e_gost_err.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost2001.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost2001_keyx.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost89.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost94_keyx.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_ameth.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_asn1.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_crypt.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_ctl.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_eng.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_keywrap.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_md.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_params.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_pmeth.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gost_sign.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gosthash.c',
>> +                     'freebsd/crypto/openssl/engines/ccgost/gostsum.c',
>> +                     'freebsd/crypto/openssl/engines/e_4758cca.c',
>> +                     'freebsd/crypto/openssl/engines/e_4758cca_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_aep.c',
>> +                     'freebsd/crypto/openssl/engines/e_aep_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_atalla.c',
>> +                     'freebsd/crypto/openssl/engines/e_atalla_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_capi.c',
>> +                     'freebsd/crypto/openssl/engines/e_capi_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_chil.c',
>> +                     'freebsd/crypto/openssl/engines/e_chil_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_cswift.c',
>> +                     'freebsd/crypto/openssl/engines/e_cswift_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_gmp.c',
>> +                     'freebsd/crypto/openssl/engines/e_gmp_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_nuron.c',
>> +                     'freebsd/crypto/openssl/engines/e_nuron_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_padlock.c',
>> +                     'freebsd/crypto/openssl/engines/e_sureware.c',
>> +                     'freebsd/crypto/openssl/engines/e_sureware_err.c',
>> +                     'freebsd/crypto/openssl/engines/e_ubsec.c',
>> +                     'freebsd/crypto/openssl/engines/e_ubsec_err.c',
>> +                     'freebsd/crypto/openssl/ssl/bad_dtls_test.c',
>> +                     'freebsd/crypto/openssl/ssl/bio_ssl.c',
>> +                     'freebsd/crypto/openssl/ssl/clienthellotest.c',
>> +                     'freebsd/crypto/openssl/ssl/d1_both.c',
>> +                     'freebsd/crypto/openssl/ssl/d1_clnt.c',
>> +                     'freebsd/crypto/openssl/ssl/d1_lib.c',
>> +                     'freebsd/crypto/openssl/ssl/d1_meth.c',
>> +                     'freebsd/crypto/openssl/ssl/d1_pkt.c',
>> +                     'freebsd/crypto/openssl/ssl/d1_srtp.c',
>> +                     'freebsd/crypto/openssl/ssl/d1_srvr.c',
>> +                     'freebsd/crypto/openssl/ssl/kssl.c',
>> +                     'freebsd/crypto/openssl/ssl/s23_clnt.c',
>> +                     'freebsd/crypto/openssl/ssl/s23_lib.c',
>> +                     'freebsd/crypto/openssl/ssl/s23_meth.c',
>> +                     'freebsd/crypto/openssl/ssl/s23_pkt.c',
>> +                     'freebsd/crypto/openssl/ssl/s23_srvr.c',
>> +                     'freebsd/crypto/openssl/ssl/s2_clnt.c',
>> +                     'freebsd/crypto/openssl/ssl/s2_enc.c',
>> +                     'freebsd/crypto/openssl/ssl/s2_lib.c',
>> +                     'freebsd/crypto/openssl/ssl/s2_meth.c',
>> +                     'freebsd/crypto/openssl/ssl/s2_pkt.c',
>> +                     'freebsd/crypto/openssl/ssl/s2_srvr.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_both.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_cbc.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_clnt.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_enc.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_lib.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_meth.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_pkt.c',
>> +                     'freebsd/crypto/openssl/ssl/s3_srvr.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_algs.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_asn1.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_cert.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_ciph.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_conf.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_err.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_err2.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_lib.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_rsa.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_sess.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_stat.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_txt.c',
>> +                     'freebsd/crypto/openssl/ssl/ssl_utst.c',
>> +                     'freebsd/crypto/openssl/ssl/ssltest.c',
>> +                     'freebsd/crypto/openssl/ssl/sslv2conftest.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_clnt.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_enc.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_ext.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_lib.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_meth.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_reneg.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_srvr.c',
>> +                     'freebsd/crypto/openssl/ssl/t1_trce.c',
>> +                     'freebsd/crypto/openssl/ssl/tls_srp.c']
>> +    bld.objects(target = "objs04",
>> +                features = "c",
>> +                cflags = cflags,
>> +                includes = ['freebsd/crypto', 'freebsd/crypto/openssl', 'freebsd/crypto/openssl/crypto', 'freebsd/crypto/openssl/crypto/asn1', 'freebsd/crypto/openssl/crypto/evp', 'freebsd/crypto/openssl/crypto/modes'] + includes,
>> +                defines = defines + ['NO_WINDOWS_BRAINDEATH=1', 'OPENSSL_DISABLE_OLD_DES_SUPPORT=1', 'OPENSSL_NO_DEPRECATED=1', 'OPENSSL_NO_EC_NISTP_64_GCC_128=1', 'OPENSSL_NO_GMP=1', 'OPENSSL_NO_JPAKE=1', 'OPENSSL_NO_LIBUNBOUND=1', 'OPENSSL_NO_MD2=1', 'OPENSSL_NO_RC5=1', 'OPENSSL_NO_RFC3779=1', 'OPENSSL_NO_SCTP=1', 'OPENSSL_NO_SSL2=1', 'OPENSSL_NO_SSL_TRACE=1', 'OPENSSL_NO_STORE=1', 'OPENSSL_NO_UNIT_TEST=1', 'OPENSSL_NO_WEAK_SSL_CIPHERS=1'],
>> +                source = objs04_source)
>> +    libbsd_use += ["objs04"]
>> +    objs05_source = ['freebsd/lib/libc/db/btree/bt_close.c',
>>                       'freebsd/lib/libc/db/btree/bt_conv.c',
>>                       'freebsd/lib/libc/db/btree/bt_debug.c',
>>                       'freebsd/lib/libc/db/btree/bt_delete.c',
>> @@ -534,15 +1345,15 @@ def build(bld):
>>                       'freebsd/lib/libc/db/recno/rec_search.c',
>>                       'freebsd/lib/libc/db/recno/rec_seq.c',
>>                       'freebsd/lib/libc/db/recno/rec_utils.c']
>> -    bld.objects(target = "objs04",
>> +    bld.objects(target = "objs05",
>>                  features = "c",
>>                  cflags = cflags,
>>                  includes = [] + includes,
>>                  defines = defines + ['INET6', '__DBINTERFACE_PRIVATE'],
>> -                source = objs04_source)
>> -    libbsd_use += ["objs04"]
>> +                source = objs05_source)
>> +    libbsd_use += ["objs05"]
>> -    objs05_source = ['dhcpcd/arp.c',
>> +    objs06_source = ['dhcpcd/arp.c',
>>                       'dhcpcd/auth.c',
>>                       'dhcpcd/bpf.c',
>>                       'dhcpcd/common.c',
>> @@ -564,15 +1375,15 @@ def build(bld):
>>                       'dhcpcd/ipv6nd.c',
>>                       'dhcpcd/net.c',
>>                       'dhcpcd/platform-bsd.c']
>> -    bld.objects(target = "objs05",
>> +    bld.objects(target = "objs06",
>>                  features = "c",
>>                  cflags = cflags,
>>                  defines = defines + ['INET', 'INET6', 'MASTER_ONLY', 'THERE_IS_NO_FORK', '__FreeBSD__'],
>> -                source = objs05_source)
>> -    libbsd_use += ["objs05"]
>> +                source = objs06_source)
>> +    libbsd_use += ["objs06"]
>> -    objs06_source = ['freebsd/contrib/libpcap/bpf_image.c',
>> +    objs07_source = ['freebsd/contrib/libpcap/bpf_image.c',
>>                       'freebsd/contrib/libpcap/etherent.c',
>>                       'freebsd/contrib/libpcap/fad-getad.c',
>>                       'freebsd/contrib/libpcap/gencode.c',
>> @@ -585,15 +1396,15 @@ def build(bld):
>>                       'freebsd/contrib/libpcap/savefile.c',
>>                       'freebsd/contrib/libpcap/sf-pcap-ng.c',
>>                       'freebsd/contrib/libpcap/sf-pcap.c']
>> -    bld.objects(target = "objs06",
>> +    bld.objects(target = "objs07",
>>                  features = "c",
>>                  cflags = cflags,
>>                  defines = defines + ['BSD=1', 'HAVE_INTTYPES=1', 'HAVE_LIMITS_H=1', 'HAVE_NET_IF_MEDIA_H=1', 'HAVE_SNPRINTF=1', 'HAVE_SOCKADDR_SA_LEN=1', 'HAVE_STDINT=1', 'HAVE_STRERROR=1', 'HAVE_STRLCPY=1', 'HAVE_SYS_IOCCOM_H=1', 'HAVE_VSNPRINTF=1', 'INET6', '_U_=__attribute__((unused))', '__FreeBSD__=1'],
>> -                source = objs06_source)
>> -    libbsd_use += ["objs06"]
>> +                source = objs07_source)
>> +    libbsd_use += ["objs07"]
>> -    objs07_source = ['freebsd/contrib/tcpdump/addrtoname.c',
>> +    objs08_source = ['freebsd/contrib/tcpdump/addrtoname.c',
>>                       'freebsd/contrib/tcpdump/af.c',
>>                       'freebsd/contrib/tcpdump/bpf_dump.c',
>>                       'freebsd/contrib/tcpdump/checksum.c',
>> @@ -736,13 +1547,13 @@ def build(bld):
>>                       'freebsd/contrib/tcpdump/smbutil.c',
>>                       'freebsd/contrib/tcpdump/tcpdump.c',
>>                       'freebsd/contrib/tcpdump/util.c']
>> -    bld.objects(target = "objs07",
>> +    bld.objects(target = "objs08",
>>                  features = "c",
>>                  cflags = cflags,
>>                  includes = ['freebsd/contrib/tcpdump', 'freebsd/usr.sbin/tcpdump/tcpdump'] + includes,
>>                  defines = defines + ['HAVE_CONFIG_H=1', 'HAVE_NET_PFVAR_H=1', 'INET6', '_U_=__attribute__((unused))', '__FreeBSD__=1'],
>> -                source = objs07_source)
>> -    libbsd_use += ["objs07"]
>> +                source = objs08_source)
>> +    libbsd_use += ["objs08"]
>>      source = ['freebsd/sys/arm/lpc/if_lpe.c',
>>                'freebsd/sys/arm/lpc/lpc_pwr.c',
>> @@ -1491,6 +2302,64 @@ def build(bld):
>>                       ('freebsd/sys/netinet', '*.h', 'netinet'),
>>                       ('freebsd/sys/netinet6', '*.h', 'netinet6'),
>>                       ('freebsd/sys/netipsec', '*.h', 'netipsec'),
>> +                     ('freebsd/crypto/openssl', '*.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto', '*.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto', '(opensslconf|opensslv|crypto).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/aes', 'aes.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/err', 'err.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/bio', '*.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/dsa', '*.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/lhash', 'lhash.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/asn1', '(asn1|asn1t).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/x509', 'x509.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/bn', 'bn.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/camellia', 'camellia.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/cast', 'cast.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/objects', '(objects|obj_mac).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/conf', '(conf|conf_api).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/des', '(des|des_old).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/ecdh', 'ecdh.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/ecdsa', 'ecdsa.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/idea', 'idea.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/mdc2', 'mdc2.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/md4', 'md4.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/md5', 'md5.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/rc2', 'rc2.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/rc4', 'rc4.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/ripemd', 'ripemd.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/seed', 'seed.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/sha', 'sha.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/ui', '(ui_compat|ui).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/whrlpool', 'whrlpool.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/x509v3', 'x509v3.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/x509', 'x509_vfy.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/buffer', 'buffer.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/comp', 'comp.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/stack', '(stack|safestack).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/asn1', 'asn1_mac.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/pem', '(pem|pem2).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/rsa', 'rsa.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/evp', 'evp.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/ec', 'ec.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/engine', 'engine.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/pkcs7', 'pkcs7.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/hmac', 'hmac.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/pqueue', 'pqueue.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/ocsp', 'ocsp.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/rand', 'rand.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/srp', 'srp.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/dh', 'dh.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/dso', 'dso.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/krb5', 'krb5_asn.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/cms', 'cms.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/txt_db', 'txt_db.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/ts', 'ts.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/modes', 'modes.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/pkcs12', 'pkcs12.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/bf', 'blowfish.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/crypto/cmac', 'cmac.h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/ssl', '(ssl|kssl|ssl2).h', 'openssl'),
>> +                     ('freebsd/crypto/openssl/ssl', '*.h', 'openssl'),
>>                       ('freebsd/sys/rpc', '*.h', 'rpc'),
>>                       ('freebsd/sys/sys', '*.h', 'sys'),
>>                       ('freebsd/sys/vm', '*.h', 'vm'),
>> diff --git a/waf_generator.py b/waf_generator.py
>> index fb52250..81cba52 100755
>> --- a/waf_generator.py
>> +++ b/waf_generator.py
>> @@ -198,6 +198,9 @@ class ModuleManager(builder.ModuleManager):
>>      def setGenerators(self):
>>          self.generator['convert'] = builder.Converter
>>          self.generator['no-convert'] = builder.NoConverter
>> +        self.generator['from-FreeBSD-to-RTEMS-UserSpaceSourceConverter'] = builder.FromFreeBSDToRTEMSUserSpaceSourceConverter
>> +        self.generator['from-RTEMS-To-FreeBSD-SourceConverter'] = builder.FromRTEMSToFreeBSDSourceConverter
>> +        self.generator['buildSystemFragmentComposer'] = builder.BuildSystemFragmentComposer
>>          self.generator['file'] = builder.File
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
