[PATCH 3/3] Port openssl to RTEMS.
Thu Aug 10 06:16:08 UTC 2017
On 10/08/2017 15:56, Christian Mauderer wrote:
> Am 10.08.2017 um 07:46 schrieb Chris Johns:
>> On 10/08/2017 15:42, Christian Mauderer wrote:
>>> The version here is likely to become out of sync with the sources. To be
>>> exact: It already is in your suggestion.
>>> freebsd-org/crypto/openssl/README states the version 1.0.2.k. Maybe we
>>> should refer to that file instead?
>> Sure with a specific reference to the section 'LEGALITIES'. We need to make sure
>> we are clear there is something users should review and look into.
>> Chris
> I mostly wanted to refer there for the version and copyright. The
> paragraph regarding crypto regulations should be unlikely to change in
> the near future. Even if it does it should be universal enough that it
> works even if something is changed in the original README.
Oh ok. I will leave this with you.
