[PATCH 1/3] waf_generator: Copy headers if necessary.
Thu Aug 10 07:02:24 UTC 2017
On 10/08/2017 16:41, Christian Mauderer wrote:
> I was more concerned that the include list in builder.py has grown
> significantly. If you don't have a problem with that, it's OK.
I will fix this after the merge.
>> I could look at making libbsd.py into libbsd/__init__.py with a file per module
>> and the top level just sees the imports. I still see no need for us to have
>> module build control, we always build all modules.
> Currently I wouldn't see a big advantage in splitting up libbsd.py
> except that the files are smaller.
Easier to review changes.
> It might would be nice to have some more control over the modules that
> get build with some kind of configuration or BSP-config file in the
> future. If it would be possibility to set custom defines depending on
> the configuration that would even add some more flexibility. With that
> it would for example be possible to exclude IPv6 support on small
> targets or add a BSP specific driver. But that's a problem that can be
> solved some when in the future when someone in the community has time or
> budget to do that.
Yes this would be nice.
