[PATCH 1/3] waf_generator: Copy headers if necessary.
Christian Mauderer list at c-mauderer.de
Thu Aug 10 18:14:33 UTC 2017
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
There are some cases, where a header is installed into a directory with
a different name then it's source directory. In that case, the build
might fail because the header is not found. One example would be the
<openssl/opensslv.h>. The source for this file is in
freebsd/crypto/openssl/crypto/opensslv.h.
To allow the build to work in such cases too, copy such files into a
temporary location in the build tree.
 builder.py       | 14 ++++++++++++++
 libbsd_waf.py    | 15 +++++++++++++++
 waf_generator.py | 24 +++++++++++++++++++++++-
 3 files changed, 52 insertions(+), 1 deletion(-)
diff --git a/builder.py b/builder.py
index bb633cb2..1be1ced1 100755
--- a/builder.py
+++ b/builder.py
@@ -194,6 +194,10 @@ def includes():
             '-ImDNSResponder/mDNSPosix',
             '-Itestsuite/include']
+def buildInclude():
+    """ Returns the path where headers will be copied during build. """
+    return 'build-include'
 def cpuIncludes():
     return ['-Irtemsbsd/@CPU@/include',
             '-Ifreebsd/sys/@CPU@/include']
@@ -205,6 +209,16 @@ def cxxflags():
     return []
 def headerPaths():
+    """ Returns a list of information about what header files should be
+    installed.
+    The list is also used to find headers with a local path that doesn't match
+    it's dest path. Due to the difference in the path name such files are
+    problematic during the build if they are included using their later
+    installation path (dest path) name. Therefore they are copied into a
+    sub-directory of the build path so that they can be included with their
+    normal installation path. """
     #         local path                      wildcard             dest path
     return [('rtemsbsd/include',              '*.h',               ''),
             ('rtemsbsd/mghttpd',              'mongoose.h',        'mghttpd'),
diff --git a/libbsd_waf.py b/libbsd_waf.py
index aee2e7ad..cbb0ae23 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -83,6 +83,7 @@ def build(bld):
     includes += ["mDNSResponder/mDNSShared"]
     includes += ["mDNSResponder/mDNSPosix"]
     includes += ["testsuite/include"]
+    includes += ["build-include"]
     # Collect the libbsd uses
     libbsd_use = []
@@ -123,6 +124,20 @@ def build(bld):
         rule = "sed -e 's/@NET_CFG_SELF_IP@/%s/' -e 's/@NET_CFG_NETMASK@/%s/' -e 's/@NET_CFG_PEER_IP@/%s/' -e 's/@NET_CFG_GATEWAY_IP@/%s/' < ${SRC} > ${TGT}" % (net_cfg_self_ip, net_cfg_netmask, net_cfg_peer_ip, net_cfg_gateway_ip),
         update_outputs = True)
+    # copy headers if necessary
+    header_build_copy_paths = [
+    for headers in header_build_copy_paths:
+        target = os.path.join("build-include", headers[2])
+        start_dir = bld.path.find_dir(headers[0])
+        for header in start_dir.ant_glob("**/" + headers[1]):
+            relsourcepath = header.path_from(start_dir)
+            targetheader = os.path.join(target, relsourcepath)
+            bld(features = 'subst',
+                target = targetheader,
+                source = header,
+                is_copy = True)
     # KVM Symbols
     bld(target = "rtemsbsd/rtems/rtems-kernel-kvm-symbols.c",
         source = "rtemsbsd/rtems/generate_kvm_symbols",
diff --git a/waf_generator.py b/waf_generator.py
index 35fe35f4..271aed96 100755
--- a/waf_generator.py
+++ b/waf_generator.py
@@ -392,7 +392,7 @@ class ModuleManager(builder.ModuleManager):
         self.add('    if bld.get_env()["RTEMS_ARCH"] == "i386":')
         self.add('        for i in %r:' % (builder.cpuIncludes()))
         self.add('            includes += ["%s" % (i[2:].replace("@CPU@", "x86"))]')
-        for i in builder.includes():
+        for i in builder.includes() + ['-I' + builder.buildInclude()]:
             self.add('    includes += ["%s"]' % (i[2:]))
         self.add('')
         self.add('    # Collect the libbsd uses')
@@ -445,6 +445,28 @@ class ModuleManager(builder.ModuleManager):
         self.add('')
+        # Add a copy rule for all headers where the install path and the source
+        # path are not the same.
+        self.add('    # copy headers if necessary')
+        self.add('    header_build_copy_paths = [')
+        for hp in builder.headerPaths():
+            if hp[2] != '' and not hp[0].endswith(hp[2]):
+                self.add('                               %s,' % (str(hp)))
+        self.add('                              ]')
+        self.add('    for headers in header_build_copy_paths:')
+        self.add('        target = os.path.join("%s", headers[2])' % (builder.buildInclude()))
+        self.add('        start_dir = bld.path.find_dir(headers[0])')
+        self.add('        for header in start_dir.ant_glob("**/" + headers[1]):')
+        self.add('            relsourcepath = header.path_from(start_dir)')
+        self.add('            targetheader = os.path.join(target, relsourcepath)')
+        self.add('            bld(features = \'subst\',')
+        self.add('                target = targetheader,')
+        self.add('                source = header,')
+        self.add('                is_copy = True)')
+        self.add('')
         # Add the specific rule based builders for generating files.
         if 'KVMSymbols' in data:
2.13.4
