[PATCH 3/3] waf: Move glob operator ** to builder.py
Thu Aug 10 23:31:22 UTC 2017
OK.
On 11/08/2017 04:14, Christian Mauderer wrote:
> From: Christian Mauderer <oss at c-mauderer.de>
> This allows a finer decision which headers should be installed.
>  builder.py       | 26 +++++++++++++-------------
>  libbsd_waf.py    | 30 +++++++++++++++---------------
>  waf_generator.py |  4 ++--
>  3 files changed, 30 insertions(+), 30 deletions(-)
> diff --git a/builder.py b/builder.py
> index 92a83dd8..21173992 100755
> --- a/builder.py
> +++ b/builder.py
> @@ -220,16 +220,16 @@ def headerPaths():
>      normal installation path. """
>      #         local path                      wildcard             dest path
> -    return [('rtemsbsd/include',              '*.h',               ''),
> +    return [('rtemsbsd/include',              '**/*.h',            ''),
>              ('rtemsbsd/mghttpd',              'mongoose.h',        'mghttpd'),
> -            ('freebsd/include',               '*.h',               ''),
> -            ('freebsd/sys/bsm',               '*.h',               'bsm'),
> -            ('freebsd/sys/cam',               '*.h',               'cam'),
> -            ('freebsd/sys/net',               '*.h',               'net'),
> -            ('freebsd/sys/net80211',          '*.h',               'net80211'),
> -            ('freebsd/sys/netinet',           '*.h',               'netinet'),
> -            ('freebsd/sys/netinet6',          '*.h',               'netinet6'),
> -            ('freebsd/sys/netipsec',          '*.h',               'netipsec'),
> +            ('freebsd/include',               '**/*.h',            ''),
> +            ('freebsd/sys/bsm',               '**/*.h',            'bsm'),
> +            ('freebsd/sys/cam',               '**/*.h',            'cam'),
> +            ('freebsd/sys/net',               '**/*.h',            'net'),
> +            ('freebsd/sys/net80211',          '**/*.h',            'net80211'),
> +            ('freebsd/sys/netinet',           '**/*.h',            'netinet'),
> +            ('freebsd/sys/netinet6',          '**/*.h',            'netinet6'),
> +            ('freebsd/sys/netipsec',          '**/*.h',            'netipsec'),
>              ('freebsd/crypto/openssl', '*.h', 'openssl'),
>              ('freebsd/crypto/openssl/crypto', '*.h', 'openssl'),
>              ('freebsd/crypto/openssl/crypto', '(opensslconf|opensslv|crypto).h', 'openssl'),
> @@ -288,10 +288,10 @@ def headerPaths():
>              ('freebsd/crypto/openssl/crypto/cmac', 'cmac.h',               'openssl'),
>              ('freebsd/crypto/openssl/ssl', '(ssl|kssl|ssl2).h', 'openssl'),
>              ('freebsd/crypto/openssl/ssl', '*.h', 'openssl'),
> -            ('freebsd/sys/rpc',               '*.h',               'rpc'),
> -            ('freebsd/sys/sys',               '*.h',               'sys'),
> -            ('freebsd/sys/vm',                '*.h',               'vm'),
> -            ('freebsd/sys/dev/mii',           '*.h',               'dev/mii'),
> +            ('freebsd/sys/rpc',               '**/*.h',            'rpc'),
> +            ('freebsd/sys/sys',               '**/*.h',            'sys'),
> +            ('freebsd/sys/vm',                '**/*.h',            'vm'),
> +            ('freebsd/sys/dev/mii',           '**/*.h',            'dev/mii'),
>              ('mDNSResponder/mDNSCore',        'mDNSDebug.h',       ''),
>              ('mDNSResponder/mDNSCore',        'mDNSEmbeddedAPI.h', ''),
>              ('mDNSResponder/mDNSShared',      'dns_sd.h',          ''),
> diff --git a/libbsd_waf.py b/libbsd_waf.py
> index 4d69e628..499a85ad 100644
> --- a/libbsd_waf.py
> +++ b/libbsd_waf.py
> @@ -187,7 +187,7 @@ def build(bld):
>      for headers in header_build_copy_paths:
>          target = os.path.join("build-include", headers[2])
>          start_dir = bld.path.find_dir(headers[0])
> -        for header in start_dir.ant_glob("**/" + headers[1]):
> +        for header in start_dir.ant_glob(headers[1]):
>              relsourcepath = header.path_from(start_dir)
>              targetheader = os.path.join(target, relsourcepath)
>              bld(features = 'subst',
> @@ -2292,16 +2292,16 @@ def build(bld):
>      # Installs.
>      bld.install_files("${PREFIX}/" + rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION, bld.env.RTEMS_ARCH_BSP), ["libbsd.a"])
> -    header_paths = [('rtemsbsd/include', '*.h', ''),
> +    header_paths = [('rtemsbsd/include', '**/*.h', ''),
> @@ -2360,10 +2360,10 @@ def build(bld):
> @@ -2372,7 +2372,7 @@ def build(bld):
>          ipath = os.path.join(rtems.arch_bsp_include_path(bld.env.RTEMS_VERSION, bld.env.RTEMS_ARCH_BSP), headers[2])
>          bld.install_files("${PREFIX}/" + ipath,
> -                          start_dir.ant_glob("**/" + headers[1]),
> +                          start_dir.ant_glob(headers[1]),
>                            cwd = start_dir,
>                            relative_trick = True)
> diff --git a/waf_generator.py b/waf_generator.py
> index add4938c..a482623a 100755
> --- a/waf_generator.py
> +++ b/waf_generator.py
> @@ -460,7 +460,7 @@ class ModuleManager(builder.ModuleManager):
>          self.add('    for headers in header_build_copy_paths:')
>          self.add('        target = os.path.join("%s", headers[2])' % (builder.buildInclude()))
>          self.add('        start_dir = bld.path.find_dir(headers[0])')
> -        self.add('        for header in start_dir.ant_glob("**/" + headers[1]):')
> +        self.add('        for header in start_dir.ant_glob(headers[1]):')
>          self.add('            relsourcepath = header.path_from(start_dir)')
>          self.add('            targetheader = os.path.join(target, relsourcepath)')
>          self.add('            bld(features = \'subst\',')
> @@ -651,7 +651,7 @@ class ModuleManager(builder.ModuleManager):
>          self.add('        ipath = os.path.join(rtems.arch_bsp_include_path(bld.env.RTEMS_VERSION, bld.env.RTEMS_ARCH_BSP), headers[2])')
>          self.add('        bld.install_files("${PREFIX}/" + ipath,')
> -        self.add('                          start_dir.ant_glob("**/" + headers[1]),')
> +        self.add('                          start_dir.ant_glob(headers[1]),')
>          self.add('                          cwd = start_dir,')
>          self.add('                          relative_trick = True)')
>          self.add('')
