[PATCH v2 1/4] waf_generator: Copy headers if necessary.
Sichen Zhao zsc19940506 at outlook.com
Sat Aug 12 09:24:37 UTC 2017
Ok, the branch  with only these four patches is here:
https://github.com/hahchenchen/rtems-libbsd/tree/usb_wpa_openssl
Best Regards
Sichen Zhao
________________________________________
Sent: Saturday, August 12, 2017 17:05
To: Chris Johns; Sichen Zhao; Sichen Zhao; devel at rtems.org
Cc: Christian Mauderer
Subject: Re: [PATCH v2 1/4] waf_generator: Copy headers if necessary.
Am 12.08.2017 um 05:57 schrieb Chris Johns:
> On 12/08/2017 13:30, Sichen Zhao wrote:
>>>> +    for headers in header_build_copy_paths:
>>>> +        target = os.path.join("build-include", headers[2])
>>>> +        start_dir = bld.path.find_dir(headers[0])
>>>> +        for header in start_dir.ant_glob(os.path.join("**/", headers[1])):
>>> Remove the '/':
>>>         for header in start_dir.ant_glob(os.path.join("**", headers[1])):
>>> OK to push once fixed.
>>> Chris
>> This already done in the PATCH v2 2/4.
>> -        self.add('        for header in
>> start_dir.ant_glob(os.path.join("**/", headers[1])):')
>> +        self.add('        for header in start_dir.ant_glob(headers[1]):')
> Excellent. These patches look good. Christian let me know if you want me to do this?
> Thanks for your hard work.
> Chris
Hello Chris,
yes, I think the patches are ready for merge. The little nitpick in the
os.path.join is something that is replaced in the second patch anyway
(like Sichen already mentioned) so I don't think it's worth the effort
to change it.
@Sichen: The patch 2/4 has been posted two times and the patch
containing the raw import is missing (most likely due to the size).
Could you post a link to a branch on your github repo with only these
four patches applied to the current master so Chris can make the merge?
Kind regards
Christian
