Patch preparation for GSoC evaluation
Tue Aug 15 12:42:18 UTC 2017
On Fri, Aug 11, 2017 at 12:21 PM, Denis Obrezkov
<denisobrezkov at gmail.com> wrote:
> 2017-08-11 17:34 GMT+02:00 Christian Mauderer <list at c-mauderer.de>:
>> Am 11.08.2017 um 17:24 schrieb Denis Obrezkov:
>> > 2017-08-11 17:17 GMT+02:00 Christian Mauderer <list at c-mauderer.de
>> > <mailto:list at c-mauderer.de>>:
>> >     Am 11.08.2017 um 12:14 schrieb Denis Obrezkov:
>> >     > 2017-08-11 11:53 GMT+02:00 Sebastian Huber
>> >     > <sebastian.huber at embedded-brains.de
>> >     <mailto:sebastian.huber at embedded-brains.de>
>> >     <mailto:sebastian.huber at embedded-brains.de>>>:
>> >     >     On 11/08/17 11:44, Denis Obrezkov wrote:
>> >     >         during our last meeting I didn't completely understand
>> > what to do
>> >     >         with my commits.
>> >     >         I have a set of commits made during the GSoC, they are, of
>> > course,
>> >     >         a bit chaotic. And the only last few commits make my code
>> > look
>> >     >         better.
>> >     >         So, I have a question: should I take all my commits,
>> >     >         merge them into one big commit which changes the state of
>> > the code
>> >     >         from the initial to the current state? Or how should I
>> > clean my
>> >     >         commit history?
>> >     >     Ideally, there should be a patch set, that can be integrated
>> > into
>> >     >     RTEMS with clean, self-contained, well described and easy to
>> > review
>> >     >     patches.
>> >     >     Sebastian Huber, embedded brains GmbH
>> >     >     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> >     >     Phone   : +49 89 189 47 41-16
>> >     <tel:%2B49%2089%20189%2047%2041-16>
>> >     >     Fax     : +49 89 189 47 41-09
>> >     <tel:%2B49%2089%20189%2047%2041-09>
>> >     >     E-Mail  : sebastian.huber at embedded-brains.de
>> >     >     PGP     : Public key available on request.
>> >     >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>> > des EHUG.
>> >     > Would it be appropriate to provide a set of patches, for example,
>> >     > for uart, clock and linkcmd related code, but without saving a
>> > commit
>> >     > history?
>> >     > I mean - to make a git reset --mixed and then make new commits
>> > with
>> >     > relatively
>> >     > clean code.
>> >     > Regards, Denis Obrezkov
>> >     Hello Denis,
>> >     if I understood you correct, that would be the right form for your
>> >     patches. Just remember that you must never change a commit that is
>> >     already in the public master branch. So as long as you are in your
>> > own
>> >     development repository you can merge patches. Like Sebastian said,
>> > the
>> >     final patches should be compilable, readable and contain only one
>> >     feature.
>> >     It's good practice to do the rework of the patches on an extra
>> > branch or
>> >     rename the old branch so that it is still there for reference.
>> >     Let me shortly describe my typical workflow. Maybe that makes it
>> > clear:
>> >     If I implement a new feature, the first for me is to create a
>> > branch. If
>> >     you haven't done that, that is no problem. Then your branch is just
>> > your
>> >     local "master".
>> >     I then make a lot of intermediate commits. Most of the time, the
>> > commit
>> >     message is just a rough note for myself, what I have done. Often
>> > it's
>> >     quite short. Something like "FIXME: Partial function xyz()." If you
>> >     would check out any of them, a lot wouldn't even compile.
>> >     As soon as my feature is done, I create a new branch from that (so I
>> > can
>> >     keep the old for backup) and then I start to reorder and squash the
>> >     commits on this new branch together. My preferred method for that is
>> > a
>> >     "git rebase origin/master" (or on top of the commit before I
>> > branched
>> >     the feature). If something goes wrong during the rebase (which
>> > happens
>> >     more often then I would like) I just check out my old backup branch
>> > and
>> >     do the rebase again.
>> >     Most of the time, I check the result of the rebase with a "git diff
>> >     my-old-branch" to make sure I didn't loose any changes.
>> >     After the rebase, I have only very few (often only one or two)
>> > commits
>> >     left. All of these commits should be compilable. Every commit
>> > contains a
>> >     set of changes that belongs together. It's quite possible that it is
>> >     only one patch that adds exactly one driver without the whole
>> > history
>> >     how I developed that driver. That patch will be sent to the mailing
>> >     list.
>> >     That works quite well for a feature that is developed by a single
>> >     person. There are some other cases too:
>> >     If you imported some files from other sources, you should check in
>> > these
>> >     sources unchanged in one commit (ideally don't add them to a
>> > Makefile or
>> >     similar so that the whole tree is still compilable) and then add
>> > your
>> >     changes and enable the compile process in a separate one. So it is
>> > easy
>> >     to see what has been changed and maybe update to a more recent
>> > version
>> >     of the original sources.
>> >     If someone provided parts of the development, you should handle the
>> >     commits of that person in a way that the author is still clearly
>> > stated.
>> >     I'm sure there are a lot of other edge cases. But these two are the
>> > most
>> >     common ones for me.
>> >     Please don't hesitate to ask if something isn't clear.
>> >     Kind regards
>> >     Christian Mauderer
>> > Thanks, I am pretty familiar with the workflow, I just wanted to know,
>> > should I keep
>> > my commits history (may be there is such a requirement for GSoC)?
>> Hello Denis,
>> sorry, I didn't wanted to offend you with the detailed description. I
>> just thought it would be better to offer some details.
>> The patches that you send to the mailing list for integration into main
>> RTEMS should be small ones with only one feature per patch. I would
>> suggest to keep the original history on a branch on github (or wherever
>> you hosted your GSoC-repo) for at least a few weeks. As far as I know
>> there is no such requirement by Google. But it might is possible that
>> your mentor wants the full history during evaluation or that it is
>> useful if someone continues to work on that or a similar project. Please
>> ask your mentor regarding that.
Denis,
You should both prepare the clean commits for submission to
review/merge into RTEMS, and also retain a copy of all the code you
wrote this summer for your final report.
Gedare
>> Kind regards
>> Christian Mauderer
> I am not offended, I wanted only to make my question as clear as possible :)
> devel mailing list
> devel at rtems.org
