[PATCH] dev/i2c: Add Xilinx AXI I2C driver.
Chris Johns
chrisj at rtems.org
Wed Aug 16 04:50:56 UTC 2017
This is a generic driver for use with Xilinx AXI I2C controller IP.
Closes #3100.
cpukit/dev/Makefile.am | 2 +
cpukit/dev/i2c/xilinx-axi-i2c.c | 943 ++++++++++++++++++++++++++++
cpukit/dev/include/dev/i2c/xilinx-axi-i2c.h | 86 +++
cpukit/dev/preinstall.am | 4 +
4 files changed, 1035 insertions(+)
create mode 100644 cpukit/dev/i2c/xilinx-axi-i2c.c
create mode 100644 cpukit/dev/include/dev/i2c/xilinx-axi-i2c.h
diff --git a/cpukit/dev/Makefile.am b/cpukit/dev/Makefile.am
index fbd84fd639..f8428b7f32 100644
--- a/cpukit/dev/Makefile.am
+++ b/cpukit/dev/Makefile.am
@@ -10,6 +10,7 @@ include_dev_i2c_HEADERS += include/dev/i2c/eeprom.h
include_dev_i2c_HEADERS += include/dev/i2c/gpio-nxp-pca9535.h
include_dev_i2c_HEADERS += include/dev/i2c/i2c.h
include_dev_i2c_HEADERS += include/dev/i2c/switch-nxp-pca9548a.h
+include_dev_i2c_HEADERS += include/dev/i2c/xilinx-axi-i2c.h
include_dev_spidir = $(includedir)/dev/spi
include_dev_spi_HEADERS =
@@ -36,6 +37,7 @@ libdev_a_SOURCES += i2c/gpio-nxp-pca9535.c
libdev_a_SOURCES += i2c/i2c-bus.c
libdev_a_SOURCES += i2c/i2c-dev.c
libdev_a_SOURCES += i2c/switch-nxp-pca9548a.c
+libdev_a_SOURCES += i2c/xilinx-axi-i2c.c
libdev_a_SOURCES += spi/spi-bus.c
libdev_a_SOURCES += serial/sc16is752.c
libdev_a_SOURCES += serial/sc16is752-spi.c
diff --git a/cpukit/dev/i2c/xilinx-axi-i2c.c b/cpukit/dev/i2c/xilinx-axi-i2c.c
new file mode 100644
index 0000000000..0248958a53
--- /dev/null
+++ b/cpukit/dev/i2c/xilinx-axi-i2c.c
@@ -0,0 +1,943 @@
+ * Copyright (c) 2016-2017 Chris Johns <chrisj at rtems.org> All rights reserved.
+ * Xilinx AXI IIC Interface v2.0. See PG090.pdf.
+ * Note, only master support is provided and no dynamic mode by design.
+#include <stdarg.h>
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/irq-extension.h>
+#include <rtems/score/assert.h>
+#include <dev/i2c/i2c.h>
+#include <dev/i2c/xilinx-axi-i2c.h>
+ * Register map.
+#define REG_GIE 0x01c
+#define REG_ISR 0x020
+#define REG_IER 0x028
+#define REG_SOFTR 0x040
+#define REG_CR 0x100
+#define REG_SR 0x104
+#define REG_TX_FIFO 0x108
+#define REG_RX_FIFO 0x10c
+#define REG_ADR 0x110
+#define REG_TX_FIFO_OCY 0x114
+#define REG_RX_FIFO_OCY 0x118
+#define REG_TEN_ADR 0x11c
+#define REG_RX_FIFO_PIRQ 0x120
+#define REG_GPO 0x124
+#define REG_TSUSTA 0x128
+#define REG_TSUSTO 0x12c
+#define REG_THDSTA 0x130
+#define REG_TSUDAT 0x134
+#define REG_TBUF 0x138
+#define REG_THIGH 0x13c
+#define REG_TLOW 0x140
+#define REG_THDDAT 0x144
+ * Interrupts.
+#define INT_ARB_LOST (1 << 0)
+#define INT_TX_ERROR (1 << 1)
+#define INT_TX_FIFO_EMPTY (1 << 2)
+#define INT_RX_FIFO_FULL (1 << 3)
+#define INT_BUS_NOT_BUSY (1 << 4)
+#define INT_ADDRESSED_AS_SLAVE (1 << 5)
+#define INT_NOT_ADDRESSED_AS_SLAVE (1 << 6)
+#define INT_TX_FIFO_HALF_FULL (1 << 7)
+#define INT_ALL (0xff)
+ * Command register.
+#define CR_EN (1 << 0)
+#define CR_TX_FIFO_RESET (1 << 1)
+#define CR_MSMS (1 << 2)
+#define CR_TX (1 << 3)
+#define CR_TXAK (1 << 4)
+#define CR_RSTA (1 << 5)
+#define CR_GC_EN (1 << 6)
+ * Status register.
+#define SR_ABGC (1 << 0)
+#define SR_AAS (1 << 1)
+#define SR_BB (1 << 2)
+#define SR_SRW (1 << 3)
+#define SR_TX_FIFO_FULL (1 << 4)
+#define SR_RX_FIFO_FULL (1 << 5)
+#define SR_RX_FIFO_EMPTY (1 << 6)
+#define SR_TX_FIFO_EMPTY (1 << 7)
+ * FIFO Sizes.
+#define TX_FIFO_SIZE 16
+#define TX_FIFO_HALF_SIZE (TX_FIFO_SIZE / 2)
+#define RX_FIFO_SIZE 16
+ * Address flags.
+#define ADDR_TEN (1 << 31)
+#define ADDR_GPO (1 << 30)
+typedef struct {
+ i2c_bus base;
+ uint32_t regs;
+ i2c_msg* msgs;
+ uint32_t msgs_remaining;
+ i2c_msg* current_msg;
+ uint32_t current_msg_todo;
+ uint8_t* current_msg_byte;
+ uint32_t current_todo;
+ uint32_t irqstatus;
+ bool read;
+ uint32_t addr;
+ rtems_id task_id;
+ bool gpo_address;
+ xilinx_aix_i2c_timing timing;
+ rtems_vector_number irq;
+} xilinx_axi_i2c_bus;
+xilinx_axi_i2c_bus* axi_i2c_bus;
+ * Real-time trace buffering with a small overhead. The data can be dumped from
+ * gdb with:
+ * define axi-i2c
+ * set $i = 0
+ * while $i < axi_trace_in
+ * printf "%4d %08x %08x %08x : ", \
+ * $i, axi_trace[$i].vars[0], axi_trace[$i].vars[1], axi_trace[$i].vars[2]
+ * output axi_trace[$i].state
+ * printf "\n"
+ * set $i = $i + 1
+ * end
+ * end
+typedef enum
+ AXI_I2C_NOP,
+ AXI_I2C_BEGIN,
+ AXI_I2C_END,
+ AXI_I2C_TRANSFER,
+ AXI_I2C_ADDRESS,
+ AXI_I2C_START_TRANSFER,
+ AXI_I2C_WRITE,
+ AXI_I2C_READ,
+ AXI_I2C_TX_FIFO,
+ AXI_I2C_RX_FIFO,
+ AXI_I2C_RX_FIFO_LEVEL,
+ AXI_I2C_INT,
+ AXI_I2C_INT_DONE,
+ AXI_I2C_INT_ERROR,
+ AXI_I2C_BUS_NOT_BUSY,
+ AXI_I2C_REG_WRITE,
+ AXI_I2C_REG_READ,
+ AXI_I2C_TIMEOUT,
+ AXI_I2C_WAKE
+} axi_i2c_state;
+#define RTEMS_AXI_I2C_TRACE 0
+#if RTEMS_AXI_I2C_TRACE
+#define DRIVER_REG_TRACE 1
+typedef struct
+ axi_i2c_state state;
+ uint32_t vars[3];
+} axi_i2c_trace;
+#define AXI_I2C_TRACE 5000
+axi_i2c_trace axi_trace[AXI_I2C_TRACE];
+int axi_trace_in;
+static inline void axi_trace_reset(void)
+ axi_trace_in = 0;
+static inline void axi_trace_append(axi_i2c_state state,
+ uint32_t v1,
+ uint32_t v2,
+ uint32_t v3)
+ if (axi_trace_in < AXI_I2C_TRACE) {
+ axi_i2c_trace rec = { state, { v1, v2, v3 } };
+ axi_trace[axi_trace_in++] = rec;
+#else
+#define axi_trace_reset()
+#define axi_trace_append(s, v1, v2, v3)
+#endif
+#define DRIVER_DEBUG 0
+#define DRIVER_DEBUG_DEFAULT true
+#if DRIVER_DEBUG
+#ifndef RTEMS_PRINTFLIKE
+#define RTEMS_PRINTFLIKE( _format_pos, _ap_pos ) \
+__attribute__((__format__(__printf__, _format_pos, _ap_pos)))
+#endif
+static bool drv_printk_enable = DRIVER_DEBUG_DEFAULT;
+static void drv_printk(const char* format, ...) RTEMS_PRINTFLIKE(1, 2);
+static void
+drv_printk(const char* format, ...)
+ va_list ap;
+ va_start(ap, format);
+ if (drv_printk_enable)
+ vprintk(format, ap);
+ va_end(ap);
+#else
+#define drv_printk(_fmt, ...)
+#endif
+static inline void
+xilinx_axi_i2c_reg_write(const xilinx_axi_i2c_bus* bus, uint32_t reg, uint32_t value)
+ #if DRIVER_REG_TRACE
+ axi_trace_append(AXI_I2C_REG_WRITE, reg, value, 0);
+ #endif
+ *((volatile uint32_t*) (bus->regs + reg))= value;
+static inline uint32_t
+xilinx_axi_i2c_reg_read(const xilinx_axi_i2c_bus* bus, uint32_t reg)
+ uint32_t value = *((volatile uint32_t*) (bus->regs + reg));
+ axi_trace_append(AXI_I2C_REG_READ, reg, value, 0);
+ #endif
+ return value;
+static uint32_t
+xilinx_axi_i2c_read_irq_status(const xilinx_axi_i2c_bus* bus)
+ return xilinx_axi_i2c_reg_read(bus, REG_ISR);
+static uint32_t
+xilinx_axi_i2c_read_irq_enabled(const xilinx_axi_i2c_bus* bus)
+ return xilinx_axi_i2c_reg_read(bus, REG_IER);
+static void
+xilinx_axi_i2c_clear_irq(const xilinx_axi_i2c_bus* bus, uint32_t mask)
+ * The ISR bits can be toggled so only write a 1 if set.
+ xilinx_axi_i2c_reg_write(bus, REG_ISR,
+ xilinx_axi_i2c_reg_read(bus, REG_ISR) & mask);
+static inline void
+xilinx_axi_i2c_enable_irq(const xilinx_axi_i2c_bus* bus, uint32_t mask)
+ xilinx_axi_i2c_reg_write(bus, REG_IER,
+ xilinx_axi_i2c_reg_read(bus, REG_IER) | mask);
+static inline void
+xilinx_axi_i2c_disable_irq(const xilinx_axi_i2c_bus* bus, uint32_t mask)
+ xilinx_axi_i2c_reg_read(bus, REG_IER) & ~mask);
+static void
+xilinx_axi_i2c_clear_enable_irq(const xilinx_axi_i2c_bus* bus, uint32_t mask)
+ xilinx_axi_i2c_clear_irq(bus, mask);
+ xilinx_axi_i2c_enable_irq(bus, mask);
+static void
+xilinx_axi_i2c_disable_clear_irq(const xilinx_axi_i2c_bus* bus, uint32_t mask)
+ xilinx_axi_i2c_disable_irq(bus, mask);
+static inline void
+xilinx_axi_i2c_disable_all_irq(const xilinx_axi_i2c_bus* bus)
+ xilinx_axi_i2c_reg_write(bus, REG_GIE, 0);
+static void
+xilinx_axi_i2c_enable_interrupts(const xilinx_axi_i2c_bus* bus)
+ xilinx_axi_i2c_reg_write(bus, REG_GIE, 1 << 31);
+static void
+xilinx_axi_i2c_disable_interrupts(const xilinx_axi_i2c_bus* bus)
+ xilinx_axi_i2c_reg_write(bus, REG_IER, 0);
+static inline void
+xilinx_axi_i2c_write_cr(const xilinx_axi_i2c_bus* bus, uint32_t value)
+ xilinx_axi_i2c_reg_write(bus, REG_CR, value);
+xilinx_axi_i2c_read_cr(const xilinx_axi_i2c_bus* bus)
+ return xilinx_axi_i2c_reg_read(bus, REG_CR);
+static inline void
+xilinx_axi_i2c_set_cr(const xilinx_axi_i2c_bus* bus, uint32_t mask)
+ xilinx_axi_i2c_reg_read(bus, REG_CR) | mask);
+static inline void
+xilinx_axi_i2c_clear_cr(const xilinx_axi_i2c_bus* bus, uint32_t mask)
+ xilinx_axi_i2c_write_cr(bus, xilinx_axi_i2c_read_cr(bus) & ~mask);
+xilinx_axi_i2c_read_sr(const xilinx_axi_i2c_bus* bus)
+ return xilinx_axi_i2c_reg_read(bus, REG_SR);
+xilinx_axi_i2c_read_rx_level(const xilinx_axi_i2c_bus* bus)
+ if ((xilinx_axi_i2c_read_sr(bus) & SR_RX_FIFO_EMPTY) != 0)
+ return 0;
+ return xilinx_axi_i2c_reg_read(bus, REG_RX_FIFO_OCY) + 1;
+static inline void
+xilinx_axi_i2c_write_rx_pirq(const xilinx_axi_i2c_bus* bus, uint32_t level)
+ if (level != 0)
+ xilinx_axi_i2c_reg_write(bus, REG_RX_FIFO_PIRQ, level - 1);
+ else
+ xilinx_axi_i2c_reg_write(bus, REG_RX_FIFO_PIRQ, level);
+xilinx_axi_i2c_read_tx_space(const xilinx_axi_i2c_bus* bus)
+ if ((xilinx_axi_i2c_read_sr(bus) & SR_TX_FIFO_EMPTY) != 0)
+ return TX_FIFO_SIZE;
+ return TX_FIFO_SIZE - xilinx_axi_i2c_reg_read(bus, REG_TX_FIFO_OCY) - 1;
+static void
+xilinx_axi_i2c_write_tx_fifo_data(xilinx_axi_i2c_bus* bus, uint32_t data)
+ axi_trace_append(AXI_I2C_TX_FIFO, data, 0, 0);
+ xilinx_axi_i2c_reg_write(bus, REG_TX_FIFO, data);
+xilinx_axi_i2c_read_rx_fifo_data(xilinx_axi_i2c_bus* bus)
+ uint32_t data = xilinx_axi_i2c_reg_read(bus, REG_RX_FIFO);
+ axi_trace_append(AXI_I2C_RX_FIFO, data, 0, 0);
+ return data;
+static void
+xilinx_axi_i2c_reset(xilinx_axi_i2c_bus* bus)
+ xilinx_axi_i2c_reg_write(bus, REG_SOFTR, 0x0a);
+ if ((bus->timing.valid_mask & XILINX_AIX_I2C_ALL_REGS) != 0)
+ static const uint32_t r[8] = {
+ REG_TSUSTA,
+ REG_TSUSTO,
+ REG_THDSTA,
+ REG_TSUDAT,
+ REG_TBUF,
+ REG_THIGH,
+ REG_TLOW,
+ REG_THDDAT
+ static const uint32_t m[8] = {
+ XILINX_AIX_I2C_TSUSTA,
+ XILINX_AIX_I2C_TSUSTO,
+ XILINX_AIX_I2C_THDSTA,
+ XILINX_AIX_I2C_TSUDAT,
+ XILINX_AIX_I2C_TBUF,
+ XILINX_AIX_I2C_THIGH,
+ XILINX_AIX_I2C_TLOW,
+ XILINX_AIX_I2C_THDDAT
+ uint32_t vm = bus->timing.valid_mask;
+ const uint32_t* u = &bus->timing.TSUSTA;
+ size_t i;
+ for (i = 0; i < (sizeof(r) / sizeof(r[0])); ++i, ++u) {
+ if ((vm & m[i]) != 0) {
+ xilinx_axi_i2c_reg_write(bus, r[i], *u);
+static void
+xilinx_axi_i2c_reinit(xilinx_axi_i2c_bus* bus)
+ drv_printk("axi-i2c: reinit\n");
+ xilinx_axi_i2c_reset(bus);
+ xilinx_axi_i2c_write_rx_pirq(bus, RX_FIFO_SIZE);
+ xilinx_axi_i2c_write_cr(bus, CR_TX_FIFO_RESET);
+ xilinx_axi_i2c_write_cr(bus, CR_EN);
+ xilinx_axi_i2c_clear_enable_irq(bus, INT_ARB_LOST);
+static void
+xilinx_axi_i2c_wakeup(xilinx_axi_i2c_bus* bus)
+ axi_trace_append(AXI_I2C_WAKE, bus->task_id, bus->irqstatus, 0);
+ drv_printk("axi-i2c: wakeup: irqstatus: %08lx\n", bus->irqstatus);
+ rtems_status_code sc = rtems_event_transient_send(bus->task_id);
+ _Assert(sc == RTEMS_SUCCESSFUL);
+ (void) sc;
+static void
+xilinx_axi_i2c_next_byte(xilinx_axi_i2c_bus* bus)
+ --bus->current_todo;
+ --bus->current_msg_todo;
+ ++bus->current_msg_byte;
+ if (bus->current_msg_todo == 0) {
+ if (bus->msgs_remaining != 0 &&
+ (bus->msgs[0].flags & I2C_M_NOSTART) != 0) {
+ bus->current_msg_todo = bus->msgs[0].len;
+ bus->current_msg_byte = bus->msgs[0].buf;
+ ++bus->msgs;
+ --bus->msgs_remaining;
+static void
+xilinx_axi_i2c_read_rx_byte(xilinx_axi_i2c_bus* bus)
+ *bus->current_msg_byte = (uint8_t) xilinx_axi_i2c_read_rx_fifo_data(bus);
+ xilinx_axi_i2c_next_byte(bus);
+static void
+xilinx_axi_i2c_read_rx_bytes(xilinx_axi_i2c_bus* bus, uint32_t count)
+ while (count-- > 0)
+ xilinx_axi_i2c_read_rx_byte(bus);
+static void
+xilinx_axi_i2c_set_rx_fifo_level(xilinx_axi_i2c_bus* bus)
+ uint32_t size;
+ if (bus->current_todo > RX_FIFO_SIZE) {
+ size = RX_FIFO_SIZE;
+ } else {
+ size = bus->current_todo - 1;
+ axi_trace_append(AXI_I2C_RX_FIFO_LEVEL, size, 0, 0);
+ xilinx_axi_i2c_write_rx_pirq(bus, size);
+static bool xilinx_axi_i2c_start_transfer(xilinx_axi_i2c_bus* bus);
+static bool
+xilinx_axi_i2c_read_rx_fifo(xilinx_axi_i2c_bus* bus)
+ drv_printk("axi-i2c: read rx fifo: length:%lu\n", bus->current_todo);
+ if (bus->current_todo == 0) {
+ return false;
+ if ((xilinx_axi_i2c_read_sr(bus) & SR_RX_FIFO_EMPTY) == 0) {
+ uint32_t level = xilinx_axi_i2c_read_rx_level(bus);
+ bool active;
+ drv_printk("axi-i2c: read rx fifo: level:%lu\n", level);
+ if (level > bus->current_todo)
+ level = bus->current_todo;
+ switch (bus->current_todo - level) {
+ case 1:
+ drv_printk("axi-i2c: read rx fifo: one more\n");
+ * One more byte to be received. This is set up by programming the RX
+ * FIFO programmable depth interrupt register with a value that is 2
+ * less than the number we need (the register is minus 1). When we have
+ * one byte left disable the TX error interrupt because setting the NO
+ * ACK bit in the command register causes a TX error interrupt. Set the
+ * TXAK bit in the CR to not-acknowledge the next byte received telling
+ * the slave sender the master accepts no more data, then read the
+ * FIFO. If the FIFO is ready before the TXAK bit is set the slave will
+ * see a request for more data. We will come back to the next case
+ * statement for the last byte once it has been received.
+ xilinx_axi_i2c_disable_clear_irq(bus, INT_TX_ERROR);
+ xilinx_axi_i2c_set_cr(bus, CR_TXAK);
+ xilinx_axi_i2c_write_rx_pirq(bus, 0);
+ xilinx_axi_i2c_read_rx_bytes(bus, level);
+ break;
+ case 0:
+ drv_printk("axi-i2c: read rx fifo: no more\n");
+ * We should have 1 byte in the FIFO which is the last byte received
+ * with a NACK. If there are no more message we need to send a STOP by
+ * clearing he MSMS bit in the CR and then waiting for the bus to not
+ * be busy.
+ INT_RX_FIFO_FULL | INT_TX_ERROR);
+ if (bus->msgs_remaining == 0) {
+ xilinx_axi_i2c_clear_cr(bus, CR_MSMS);
+ xilinx_axi_i2c_clear_enable_irq(bus, INT_BUS_NOT_BUSY);
+ active = true;
+ if (bus->msgs_remaining != 0)
+ active = xilinx_axi_i2c_start_transfer(bus);
+ return active;
+ default:
+ drv_printk("axi-i2c: read rx fifo: more:%lu\n", bus->current_todo - level);
+ * All the requested data is in the FIFO so read it and update the PIRQ
+ * level. The PIRQ size is always one less than the maximum size.
+ } else {
+ xilinx_axi_i2c_write_rx_pirq(bus, bus->current_todo - 1);
+ break;
+ return true;
+static void
+xilinx_axi_i2c_write_tx_byte(xilinx_axi_i2c_bus* bus)
+ xilinx_axi_i2c_write_tx_fifo_data(bus, *bus->current_msg_byte);
+static void
+xilinx_axi_i2c_write_tx_bytes(xilinx_axi_i2c_bus* bus)
+ uint32_t space = xilinx_axi_i2c_read_tx_space(bus);
+ uint32_t level = bus->current_todo - 1;
+ uint32_t i;
+ drv_printk("axi-i2c: tx fifo load: space:%lu level:%lu\n", space, level);
+ if (level < space)
+ space = level;
+ for (i = 0; i < space; ++i)
+ xilinx_axi_i2c_write_tx_byte(bus);
+static bool
+xilinx_axi_i2c_write_tx_fifo(xilinx_axi_i2c_bus* bus)
+ bool more = true;
+ drv_printk("axi-i2c: write tx fifo: current_todo: %lu\n", bus->current_todo);
+ switch (bus->current_todo) {
+ case 0:
+ INT_TX_FIFO_EMPTY |
+ INT_TX_FIFO_HALF_FULL |
+ INT_TX_ERROR |
+ INT_BUS_NOT_BUSY);
+ more = xilinx_axi_i2c_start_transfer(bus);
+ break;
+ case 1:
+ * If transmitting and the last byte issue a stop and wait for the bus to
+ * not be busy.
+ if (!bus->read && bus->msgs_remaining == 0) {
+ break;
+ default:
+ xilinx_axi_i2c_write_tx_bytes(bus);
+ break;
+ return more;
+static void
+xilinx_axi_i2c_write_address(xilinx_axi_i2c_bus* bus)
+ if ((bus->addr & ADDR_GPO) != 0)
+ xilinx_axi_i2c_reg_write(bus, REG_GPO, (bus->addr >> 12) & 0xf);
+ if ((bus->addr & ADDR_TEN) != 0)
+ xilinx_axi_i2c_write_tx_fifo_data(bus, (bus->addr >> 8) & 0xff);
+ xilinx_axi_i2c_write_tx_fifo_data(bus, bus->addr & 0xff);
+static void
+xilinx_axi_i2c_start_read(xilinx_axi_i2c_bus* bus)
+ uint32_t cr;
+ uint32_t set = INT_RX_FIFO_FULL;
+ axi_trace_append(AXI_I2C_READ, bus->current_todo, 0, 0);
+ drv_printk("axi-i2c: start read: size: %lu\n", bus->current_todo);
+ * Is this a restart? If there is no active STOP it is a restart.
+ cr = xilinx_axi_i2c_read_cr(bus);
+ if ((cr & CR_MSMS) != 0) {
+ cr |= CR_RSTA;
+ xilinx_axi_i2c_write_cr(bus, cr);
+ xilinx_axi_i2c_write_address(bus);
+ xilinx_axi_i2c_set_rx_fifo_level(bus);
+ * We must NACK the last byte so if we are receiving a single byte issue a
+ * NACK.
+ cr &= ~(CR_TX | CR_TXAK);
+ if (bus->current_todo == 1) {
+ cr |= CR_TXAK;
+ } else {
+ set |= INT_TX_ERROR;
+ * Issue a start.
+ cr |= CR_MSMS;
+ xilinx_axi_i2c_clear_enable_irq(bus, set);
+static void
+xilinx_axi_i2c_start_write(xilinx_axi_i2c_bus* bus)
+ uint32_t space;
+ uint32_t enable;
+ uint32_t cr;
+ axi_trace_append(AXI_I2C_WRITE, bus->current_todo, 0, 0);
+ * If a master issue a restart if there is no active STOP on the bus.
+ cr |= CR_RSTA;
+ if (bus->current_todo > 1)
+ space = xilinx_axi_i2c_read_tx_space(bus);
+ enable = INT_TX_FIFO_EMPTY | INT_TX_ERROR;
+ if (space > TX_FIFO_HALF_SIZE && bus->current_todo > 1) {
+ enable |= INT_TX_FIFO_HALF_FULL;
+ xilinx_axi_i2c_clear_enable_irq(bus, enable);
+ cr &= ~CR_TXAK;
+ cr |= CR_MSMS | CR_TX;
+static bool
+xilinx_axi_i2c_start_transfer(xilinx_axi_i2c_bus* bus)
+ const i2c_msg* msgs = bus->msgs;
+ uint32_t msg_todo = bus->msgs_remaining;
+ uint32_t i;
+ axi_trace_append(AXI_I2C_START_TRANSFER, msg_todo, 0, 0);
+ drv_printk("axi-i2c: start transfer: messages: %lu\n", msg_todo);
+ if (msg_todo == 0) {
+ return false;
+ * Get the amount of data to transfer. It can span message buffers if the
+ * I2C_M_NOSTART flag is set.
+ bus->current_todo = msgs[0].len;
+ for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
+ bus->current_todo += msgs[i].len;
+ bus->read = (msgs->flags & I2C_M_RD) != 0;
+ if ((msgs->flags & I2C_M_TEN) != 0) {
+ bus->addr = (ADDR_TEN |
+ ((msgs->addr & (3 << 8)) << 1) |
+ ((bus->read ? 1 : 0) << 8) |
+ (msgs->addr & 0xff));
+ else {
+ bus->addr = (msgs->addr & 0x7f) << 1 | (bus->read ? 1 : 0);
+ if (bus->gpo_address)
+ bus->addr |= ADDR_GPO | (msgs->addr & 0xf000);
+ axi_trace_append(AXI_I2C_TRANSFER,
+ bus->msgs_remaining,
+ bus->current_todo, bus->addr);
+ * The bus->msgs is left pointing to the next message because we may need to
+ * start a new message while completing the current message.
+ bus->current_msg_todo = msgs[0].len;
+ bus->current_msg_byte = msgs[0].buf;
+ ++bus->msgs;
+ if (bus->read) {
+ xilinx_axi_i2c_start_read(bus);
+ } else {
+ xilinx_axi_i2c_start_write(bus);
+ return true;
+static void
+ xilinx_axi_i2c_interrupt(void* arg)
+ xilinx_axi_i2c_bus* bus = arg;
+ uint32_t status = xilinx_axi_i2c_read_irq_status(bus);
+ uint32_t enabled = xilinx_axi_i2c_read_irq_enabled(bus);
+ uint32_t active = status & enabled;
+ uint32_t clear = 0;
+ int done = 0;
+ axi_trace_append(AXI_I2C_INT, active, status, enabled);
+ drv_printk("axi-i2c: interrupt: active:%02lx isr:%02lx ier:%02lx\n",
+ active, status, enabled);
+ * An error or we lost arbitration. If transmitting and there is more data to
+ * send a INT_TX_ERROR means the slave issue a NOT ACK because there was not
+ * slave at the address or the addressed slave will not accept any more data.
+ * Clean up and wake the user.
+ if (((active & INT_ARB_LOST) != 0) ||
+ (!bus->read && (active & INT_TX_ERROR) != 0)) {
+ bus->irqstatus = active & (INT_ARB_LOST | INT_TX_ERROR);
+ axi_trace_append(AXI_I2C_INT_ERROR, bus->irqstatus, 0, 0);
+ xilinx_axi_i2c_reinit(bus);
+ xilinx_axi_i2c_clear_cr(bus, CR_EN);
+ xilinx_axi_i2c_wakeup(bus);
+ return;
+ * RX FIFO full?
+ if ((active & INT_RX_FIFO_FULL) != 0) {
+ clear |= INT_RX_FIFO_FULL;
+ if (bus->read && !xilinx_axi_i2c_read_rx_fifo(bus)) {
+ ++done;
+ axi_trace_append(AXI_I2C_INT_DONE, done, clear, 0);
+ clear |= status & INT_TX_ERROR;
+ * TX FIFO empty or half empty?
+ if ((active & (INT_TX_FIFO_EMPTY | INT_TX_FIFO_HALF_FULL)) != 0) {
+ clear |= active & (INT_TX_FIFO_EMPTY | INT_TX_FIFO_HALF_FULL);
+ if (!bus->read && !xilinx_axi_i2c_write_tx_fifo(bus)) {
+ ++done;
+ axi_trace_append(AXI_I2C_INT_DONE, done, clear, 1);
+ * Gate the bus not busy interrupt with the bus busy status to know the bus
+ * is really not busy. It could be an interrupt left over from starting the
+ * transmission.
+ if ((active & INT_BUS_NOT_BUSY) != 0) {
+ if ((xilinx_axi_i2c_read_sr(bus) & SR_BB) == 0) {
+ xilinx_axi_i2c_disable_clear_irq(bus, INT_BUS_NOT_BUSY);
+ ++done;
+ axi_trace_append(AXI_I2C_BUS_NOT_BUSY, done, clear, 0);
+ else if (!bus->read && !xilinx_axi_i2c_write_tx_fifo(bus)) {
+ ++done;
+ axi_trace_append(AXI_I2C_BUS_NOT_BUSY, done, clear, 1);
+ else {
+ clear |= INT_BUS_NOT_BUSY;
+ if (clear != 0)
+ xilinx_axi_i2c_clear_irq(bus, clear);
+ if (done != 0) {
+ xilinx_axi_i2c_disable_interrupts(bus);
+static int xilinx_axi_i2c_transfer(i2c_bus* base,
+ i2c_msg* msgs,
+ uint32_t msg_count)
+ xilinx_axi_i2c_bus* bus = (xilinx_axi_i2c_bus *) base;
+ rtems_status_code sc;
+ int r = 0;
+ axi_trace_reset();
+ axi_trace_append(AXI_I2C_BEGIN, msg_count, 0, 0);
+ drv_printk("axi-i2c: i2c transfer\n");
+ _Assert(msg_count > 0);
+ bus->msgs = &msgs[0];
+ bus->msgs_remaining = msg_count;
+ bus->irqstatus = 0;
+ bus->task_id = rtems_task_self();
+ xilinx_axi_i2c_start_transfer(bus);
+ xilinx_axi_i2c_enable_interrupts(bus);
+ sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
+ if (sc != RTEMS_SUCCESSFUL) {
+ axi_trace_append(AXI_I2C_TIMEOUT, 0, 0, 0);
+ rtems_event_transient_clear();
+ r = -ETIMEDOUT;
+ if (r == 0 && bus->irqstatus != 0)
+ r = -EIO;
+ axi_trace_append(AXI_I2C_END, bus->irqstatus, r, 0);
+ return r;
+static int xilinx_axi_i2c_set_clock(i2c_bus *base, unsigned long clock)
+ xilinx_axi_i2c_bus* bus = (xilinx_axi_i2c_bus*) base;
+ if ((bus->timing.valid_mask & XILINX_AIX_I2C_AXI_CLOCK) == 0)
+ return -EIO;
+ bus->timing.THIGH =
+ (bus->timing.AXI_CLOCK / (2 * clock)) - 7 - bus->timing.SCL_INERTIAL_DELAY;
+ bus->timing.TLOW = bus->timing.THIGH;
+ bus->timing.valid_mask |= XILINX_AIX_I2C_THIGH | XILINX_AIX_I2C_TLOW;
+ return 0;
+static void xilinx_axi_i2c_destroy(i2c_bus* base)
+ sc = rtems_interrupt_handler_remove(bus->irq, xilinx_axi_i2c_interrupt, bus);
+ (void) sc;
+ i2c_bus_destroy_and_free(&bus->base);
+int
+i2c_bus_register_xilinx_aix_i2c(const char* bus_path,
+ uintptr_t register_base,
+ rtems_vector_number irq,
+ bool gpo_address,
+ const xilinx_aix_i2c_timing* timing)
+ xilinx_axi_i2c_bus* bus;
+ bus = (xilinx_axi_i2c_bus*) i2c_bus_alloc_and_init(sizeof(*bus));
+ if (bus == NULL) {
+ return -1;
+ bus->regs = register_base;
+ bus->irq = irq;
+ bus->gpo_address = gpo_address;
+ bus->timing = *timing;
+ sc = rtems_interrupt_handler_install(irq,
+ "Xilinx AXI I2C",
+ RTEMS_INTERRUPT_UNIQUE,
+ xilinx_axi_i2c_interrupt,
+ bus);
+ drv_printk("axi-i2c: interrupt attach failed\n");
+ (*bus->base.destroy)(&bus->base);
+ rtems_set_errno_and_return_minus_one(EIO);
+ bus->base.transfer = xilinx_axi_i2c_transfer;
+ bus->base.set_clock = xilinx_axi_i2c_set_clock;
+ bus->base.destroy = xilinx_axi_i2c_destroy;
+ axi_i2c_bus = bus;
+ return i2c_bus_register(&bus->base, bus_path);
diff --git a/cpukit/dev/include/dev/i2c/xilinx-axi-i2c.h b/cpukit/dev/include/dev/i2c/xilinx-axi-i2c.h
index 0000000000..fafac346ec
--- /dev/null
+++ b/cpukit/dev/include/dev/i2c/xilinx-axi-i2c.h
@@ -0,0 +1,86 @@
+ * The clock set up is to be handled by the IP integrator. There are too many
+ * factors handling this in software.
+#ifndef XILINX_AXI_I2C_H
+#define XILINX_AXI_I2C_H
+ * The PL integrator controls the timing. This interface allows software to
+ * override those settings. It pays to check the timing with ChipScope.
+ * If you set the AXI bus frequency you can use the clock speed ioctl call to
+ * change the speed dymanically. The ioctl call overrides the defaults passed
+ * in.
+ * Set the valid mask to the values that are to be set.
+#define XILINX_AIX_I2C_AXI_CLOCK (1 << 0)
+#define XILINX_AIX_I2C_TSUSTA (1 << 1)
+#define XILINX_AIX_I2C_TSUSTO (1 << 2)
+#define XILINX_AIX_I2C_THDSTA (1 << 3)
+#define XILINX_AIX_I2C_TSUDAT (1 << 4)
+#define XILINX_AIX_I2C_TBUF (1 << 5)
+#define XILINX_AIX_I2C_THIGH (1 << 6)
+#define XILINX_AIX_I2C_TLOW (1 << 7)
+#define XILINX_AIX_I2C_THDDAT (1 << 8)
+#define XILINX_AIX_I2C_ALL_REGS (XILINX_AIX_I2C_TSUSTA | \
+ XILINX_AIX_I2C_TSUSTO | \
+ XILINX_AIX_I2C_THDSTA | \
+ XILINX_AIX_I2C_TSUDAT | \
+ XILINX_AIX_I2C_TBUF | \
+ XILINX_AIX_I2C_THIGH | \
+ XILINX_AIX_I2C_TLOW | \
+ XILINX_AIX_I2C_THDDAT)
+typedef struct
+ uint32_t valid_mask;
+ uint32_t AXI_CLOCK;
+ uint32_t SCL_INERTIAL_DELAY;
+ uint32_t TSUSTA;
+ uint32_t TSUSTO;
+ uint32_t THDSTA;
+ uint32_t TSUDAT;
+ uint32_t TBUF;
+ uint32_t THIGH;
+ uint32_t TLOW;
+ uint32_t THDDAT;
+} xilinx_aix_i2c_timing;
+ * Register the driver.
+ * The driver can multipex a number of I2C buses (in master mode only) using
+ * the GPO port. The PL designer can use the output pins to select a bus. This
+ * is useful if connecting a number of slave devices that have limit selectable
+ * addresses.
+ * @param bus_path The driver's device path.
+ * @param register_base AXI base address.
+ * @param irq AXI FPGA interrupt.
+ * @param gpio_address Bits 12:15 of a slave address it written to the GPO.
+ * @param timing Override the default timing. NULL means no changes.
+int i2c_bus_register_xilinx_aix_i2c(const char* bus_path,
+ bool ten_gpio,
+ const xilinx_aix_i2c_timing* timing);
+#endif
diff --git a/cpukit/dev/preinstall.am b/cpukit/dev/preinstall.am
index 307d0a4a6e..d86719aba3 100644
--- a/cpukit/dev/preinstall.am
+++ b/cpukit/dev/preinstall.am
@@ -39,6 +39,10 @@ $(PROJECT_INCLUDE)/dev/i2c/switch-nxp-pca9548a.h: include/dev/i2c/switch-nxp-pca
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/dev/i2c/switch-nxp-pca9548a.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/dev/i2c/switch-nxp-pca9548a.h
+$(PROJECT_INCLUDE)/dev/i2c/xilinx-axi-i2c.h: include/dev/i2c/xilinx-axi-i2c.h $(PROJECT_INCLUDE)/dev/i2c/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/dev/i2c/xilinx-axi-i2c.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/dev/i2c/xilinx-axi-i2c.h
$(PROJECT_INCLUDE)/dev/spi/$(dirstamp):
@$(MKDIR_P) $(PROJECT_INCLUDE)/dev/spi
@: > $(PROJECT_INCLUDE)/dev/spi/$(dirstamp)
2.13.2
