[PATCH 07/15] HiFive1: add PRCI support files
Denis Obrezkov denisobrezkov at gmail.com
Wed Aug 16 15:12:58 UTC 2017
 c/src/lib/libbsp/riscv32/hifive1/include/prci.h | 74 +++++++++++++++++++++++++
 c/src/lib/libbsp/riscv32/hifive1/start/prci.c   | 33 +++++++++++
 2 files changed, 107 insertions(+)
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/include/prci.h
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/start/prci.c
diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/prci.h b/c/src/lib/libbsp/riscv32/hifive1/include/prci.h
new file mode 100644
index 0000000..a3432a8
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/include/prci.h
@@ -0,0 +1,74 @@
+ * Copyright (c) 2017
+ * Denis Obrezkov <denisobrezkov at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef PRCI_H
+#define PRCI_H
+ * PRCI description for HiFive1 system
+#define PRCI_BASE 0x10008000
+#define PRCI_HFROSCCFG 0x10008000
+#define PRCI_HFXOSCCFG 0x10008004
+#define PRCI_PLLCFG 0x10008008
+#define PRCI_PLLOUTDIV 0x1000800C
+#define PRCI_CORECLKCFG 0x10008010
+//16 MHz from external crystall oscillator
+#define hifive1_default_freq 16000000
+ * HFROSCCFG configuration register values
+#define HFROSC_DIV_VAL 4
+#define HFROSC_TRIM_VAL 16
+#define HFROSC_EN_VAL 1
+#define HFROSC_RDY_VAL 1
+#define HFROSC_DIV_OFFSET 0
+#define HFROSC_TRIM_OFFSET 16
+#define HFROSC_EN_OFFSET 30
+#define HFROSC_RDY_OFFSET 31
+ * HFXOSCCFG configuration register values
+#define HFXOSC_EN_VAL 1
+#define HFXOSC_RDY_VAL 1
+#define HFXOSC_EN_OFFSET 30
+#define HFXOSC_RDY_OFFSET 31
+ * PLLCFG configuration register
+#define PLL_SEL_OFFSET 16
+static int hifive1_current_freq();
+#endif /* PRCI_H */
diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/prci.c b/c/src/lib/libbsp/riscv32/hifive1/start/prci.c
index 0000000..7e5237f
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/start/prci.c
@@ -0,0 +1,33 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <bsp/prci.h>
+static int hifive1_current_freq() {
+    return hifive1_default_freq;
2.1.4
