[PATCH 09/15] HiFive1: add timer support
Denis Obrezkov denisobrezkov at gmail.com
Wed Aug 16 15:13:00 UTC 2017
 c/src/lib/libbsp/riscv32/hifive1/timer/timer.c | 71 ++++++++++++++++++++++++++
 1 file changed, 71 insertions(+)
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/timer/timer.c
diff --git a/c/src/lib/libbsp/riscv32/hifive1/timer/timer.c b/c/src/lib/libbsp/riscv32/hifive1/timer/timer.c
new file mode 100644
index 0000000..afa3cc0
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/timer/timer.c
@@ -0,0 +1,71 @@
+ * Copyright (c) 2015 University of York.
+ * Hesham ALMatary <hmka501 at york.ac.uk>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <rtems.h>
+#include <bsp.h>
+#include <rtems/btimer.h>
+#include <rtems/score/riscv-utility.h>
+extern char bsp_start_vector_table_begin[];
+bool benchmark_timer_find_average_overhead;
+static void benchmark_timer1_interrupt_handler(void)
+/* Start eCore tiemr 1 usef for profiling and timing analysis */
+void benchmark_timer_initialize( void )
+  /* Install interrupt handler for timer 1 */
+ *  The following controls the behavior of benchmark_timer_read().
+ *  AVG_OVEREHAD is the overhead for starting and stopping the timer.  It
+ *  is usually deducted from the number returned.
+ *  LEAST_VALID is the lowest number this routine should trust.  Numbers
+ *  below this are "noise" and zero is returned.
+#define AVG_OVERHEAD      0  /* It typically takes X.X microseconds */
+                             /* (Y countdowns) to start/stop the timer. */
+                             /* This value is in microseconds. */
+#define LEAST_VALID       1  /* Don't trust a clicks value lower than this */
+benchmark_timer_t benchmark_timer_read( void )
+void benchmark_timer_disable_subtracting_average_overhead(
+  bool find_flag
+  benchmark_timer_find_average_overhead = find_flag;
2.1.4
