[PATCH 6/7] Add wpa_supplicant_fork command.
Sichen Zhao 1473996754 at qq.com
Thu Aug 17 01:33:56 UTC 2017
Add fork command for wpa supplicant
to start a new task.
 freebsd/contrib/wpa/wpa_supplicant/main.c          | 67 +++++++++++++++++++++-
 libbsd.py                                          |  1 +
 libbsd_waf.py                                      |  1 +
 rtemsbsd/include/machine/rtems-bsd-commands.h      |  2 +
 rtemsbsd/include/rtems/netcmds-config.h            |  2 +
 .../rtems/rtems-bsd-shell-wpa_supplicant_fork.c    | 36 ++++++++++++
 6 files changed, 108 insertions(+), 1 deletion(-)
 create mode 100644 rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c
diff --git a/freebsd/contrib/wpa/wpa_supplicant/main.c b/freebsd/contrib/wpa/wpa_supplicant/main.c
index 7347951..b2af31e 100644
--- a/freebsd/contrib/wpa/wpa_supplicant/main.c
+++ b/freebsd/contrib/wpa/wpa_supplicant/main.c
@@ -18,7 +18,9 @@
 #include "wpa_supplicant_i.h"
 #include "driver_i.h"
 #include "p2p_supplicant.h"
+#ifdef __rtems__
+#include <assert.h>
+#endif /* __rtems__ */
 static void usage(void)
@@ -168,6 +170,69 @@ int rtems_bsd_command_wpa_supplicant(int argc, char **argv)
 	return exit_code;
+struct myparams {
+   int argc;
+   char ** argv;
+static void
+new_wpa_supplicant_task(rtems_task_argument arg)
+   int argc;
+   char ** argv;
+   int i;
+   struct myparams *params = (struct myparams *)arg;
+   argc = params->argc;
+   argv = params->argv;
+   rtems_bsd_command_wpa_supplicant(argc, argv);
+   for (i = 0; i < params->argc; i++) {
+		free(params->argv[i]);
+	free(params->argv);
+	free(params);
+	rtems_task_delete( RTEMS_SELF );
+int rtems_bsd_command_wpa_supplicant_fork(int argc, char **argv)
+    rtems_status_code sc;
+	rtems_id id;
+    int i;
+    struct myparams *params = malloc(sizeof(struct myparams));
+    if (params == NULL)
+		return NULL;
+	params->argc = argc;
+	params->argv = malloc((argc + 1) * sizeof(argv[0]));
+	if (params->argv == NULL)
+		return NULL;
+	for (i = 0; i < argc; i++) {
+		params->argv[i] = strdup(argv[i]);
+		if (params->argv[i] == NULL)
+			return NULL;
+    params->argv[argc] = NULL;
+	sc = rtems_task_create(
+		rtems_build_name('W', 'P', 'A', 'S'),
+		RTEMS_MAXIMUM_PRIORITY - 1,
+		8 * RTEMS_MINIMUM_STACK_SIZE,
+		RTEMS_DEFAULT_MODES,
+		RTEMS_FLOATING_POINT,
+		&id
+	assert(sc == RTEMS_SUCCESSFUL);
+    sc = rtems_task_start(id, new_wpa_supplicant_task, params);
 int main(int argc, char *argv[])
diff --git a/libbsd.py b/libbsd.py
index a0b7f1a..9bb6f0b 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -4237,6 +4237,7 @@ def usr_sbin_wpa_supplicant(mm):
     mod.addRTEMSSourceFiles(
             'rtems/rtems-bsd-shell-wpa_supplicant.c',
+            'rtems/rtems-bsd-shell-wpa_supplicant_fork.c',
         mm.generator['source']()
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 02b2cbd..28e3cf0 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -2288,6 +2288,7 @@ def build(bld):
               'rtemsbsd/rtems/rtems-bsd-shell-vmstat.c',
               'rtemsbsd/rtems/rtems-bsd-shell-wlanstats.c',
               'rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c',
+              'rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c',
               'rtemsbsd/rtems/rtems-bsd-syscall-api.c',
               'rtemsbsd/rtems/rtems-kernel-assert.c',
               'rtemsbsd/rtems/rtems-kernel-autoconf.c',
diff --git a/rtemsbsd/include/machine/rtems-bsd-commands.h b/rtemsbsd/include/machine/rtems-bsd-commands.h
index 03a09bc..32aba44 100644
--- a/rtemsbsd/include/machine/rtems-bsd-commands.h
+++ b/rtemsbsd/include/machine/rtems-bsd-commands.h
@@ -64,6 +64,8 @@ int rtems_bsd_command_dhcpcd(int argc, char **argv);
 int rtems_bsd_command_wpa_supplicant(int argc, char **argv);
+int rtems_bsd_command_wpa_supplicant_fork(int argc, char **argv);
 int rtems_bsd_command_tcpdump(int argc, char **argv);
 int rtems_bsd_command_sysctl(int argc, char **argv);
diff --git a/rtemsbsd/include/rtems/netcmds-config.h b/rtemsbsd/include/rtems/netcmds-config.h
index 046c859..4af4323 100644
--- a/rtemsbsd/include/rtems/netcmds-config.h
+++ b/rtemsbsd/include/rtems/netcmds-config.h
@@ -41,6 +41,8 @@ extern rtems_shell_cmd_t rtems_shell_TCPDUMP_Command;
 extern rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_Command;
+extern rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_FORK_Command;
 extern rtems_shell_cmd_t rtems_shell_SYSCTL_Command;
 extern rtems_shell_cmd_t rtems_shell_VMSTAT_Command;
diff --git a/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c b/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c
new file mode 100644
index 0000000..046b611
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c
@@ -0,0 +1,36 @@
+ * Copyright (c) 2017 Sichen Zhao.  All rights reserved.
+ *  <zsc19940506 at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <rtems/netcmds-config.h>
+#include <machine/rtems-bsd-commands.h>
+rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_FORK_Command = {
+  .name = "wpa_supplicant_fork",
+  .usage = "wpa_supplicant_fork [args]",
+  .topic = "net",
+  .command = rtems_bsd_command_wpa_supplicant_fork
2.7.4
