[PATCH 6/7] Add wpa_supplicant_fork command.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Aug 17 08:22:19 UTC 2017
That's a great function for debugging but I'm not sure whether it would
be good as a command available to all. There should be at least some big
warning that it can't be started multiple times. In the ideal case, add
a lock so that it can only be started once.
A little more into the future, it most likely should be replaced by a
deamon similar to the dhcpcd. Or it should be started from the rc.conf
parser.
Am 17.08.2017 um 03:33 schrieb Sichen Zhao:
> Add fork command for wpa supplicant
> to start a new task.
>  freebsd/contrib/wpa/wpa_supplicant/main.c          | 67 +++++++++++++++++++++-
>  libbsd.py                                          |  1 +
>  libbsd_waf.py                                      |  1 +
>  rtemsbsd/include/machine/rtems-bsd-commands.h      |  2 +
>  rtemsbsd/include/rtems/netcmds-config.h            |  2 +
>  .../rtems/rtems-bsd-shell-wpa_supplicant_fork.c    | 36 ++++++++++++
>  6 files changed, 108 insertions(+), 1 deletion(-)
>  create mode 100644 rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c
> diff --git a/freebsd/contrib/wpa/wpa_supplicant/main.c b/freebsd/contrib/wpa/wpa_supplicant/main.c
> index 7347951..b2af31e 100644
> --- a/freebsd/contrib/wpa/wpa_supplicant/main.c
> +++ b/freebsd/contrib/wpa/wpa_supplicant/main.c
> @@ -18,7 +18,9 @@
>  #include "wpa_supplicant_i.h"
>  #include "driver_i.h"
>  #include "p2p_supplicant.h"
Again: Minus is bad.
> +#ifdef __rtems__
> +#include <assert.h>
> +#endif /* __rtems__ */
>  static void usage(void)
> @@ -168,6 +170,69 @@ int rtems_bsd_command_wpa_supplicant(int argc, char **argv)
>  	return exit_code;
> +struct myparams {
> +   int argc;
> +   char ** argv;
Use BSD-Style indentations. There are some more places in that file with
wrong indentation. Please fix them too.
> +static void
> +new_wpa_supplicant_task(rtems_task_argument arg)
> +   int argc;
> +   char ** argv;
> +   int i;
> +   struct myparams *params = (struct myparams *)arg;
> +   argc = params->argc;
> +   argv = params->argv;
> +   rtems_bsd_command_wpa_supplicant(argc, argv);
> +   for (i = 0; i < params->argc; i++) {
> +		free(params->argv[i]);
> +	free(params->argv);
> +	free(params);
> +	rtems_task_delete( RTEMS_SELF );
> +int rtems_bsd_command_wpa_supplicant_fork(int argc, char **argv)
> +    rtems_status_code sc;
> +	rtems_id id;
> +    int i;
> +    struct myparams *params = malloc(sizeof(struct myparams));
> +    if (params == NULL)
> +		return NULL;
> +	params->argc = argc;
> +	params->argv = malloc((argc + 1) * sizeof(argv[0]));
> +	if (params->argv == NULL)
> +		return NULL;
> +	for (i = 0; i < argc; i++) {
> +		params->argv[i] = strdup(argv[i]);
> +		if (params->argv[i] == NULL)
You should free params->argv[x] for all x < i in that case. After that
you should also free params->argv. Then you can return. Otherwise this
might be a memory leak.
> +			return NULL;
> +    params->argv[argc] = NULL;
> +	sc = rtems_task_create(
> +		rtems_build_name('W', 'P', 'A', 'S'),
> +		RTEMS_MAXIMUM_PRIORITY - 1,
> +		8 * RTEMS_MINIMUM_STACK_SIZE,
> +		RTEMS_DEFAULT_MODES,
> +		RTEMS_FLOATING_POINT,
> +		&id
> +	assert(sc == RTEMS_SUCCESSFUL);
> +    sc = rtems_task_start(id, new_wpa_supplicant_task, params);
>  int main(int argc, char *argv[])
> diff --git a/libbsd.py b/libbsd.py
> index a0b7f1a..9bb6f0b 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -4237,6 +4237,7 @@ def usr_sbin_wpa_supplicant(mm):
>      mod.addRTEMSSourceFiles(
>              'rtems/rtems-bsd-shell-wpa_supplicant.c',
> +            'rtems/rtems-bsd-shell-wpa_supplicant_fork.c',
>          mm.generator['source']()
> diff --git a/libbsd_waf.py b/libbsd_waf.py
> index 02b2cbd..28e3cf0 100644
> --- a/libbsd_waf.py
> +++ b/libbsd_waf.py
> @@ -2288,6 +2288,7 @@ def build(bld):
>                'rtemsbsd/rtems/rtems-bsd-shell-vmstat.c',
>                'rtemsbsd/rtems/rtems-bsd-shell-wlanstats.c',
>                'rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c',
> +              'rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c',
>                'rtemsbsd/rtems/rtems-bsd-syscall-api.c',
>                'rtemsbsd/rtems/rtems-kernel-assert.c',
>                'rtemsbsd/rtems/rtems-kernel-autoconf.c',
> diff --git a/rtemsbsd/include/machine/rtems-bsd-commands.h b/rtemsbsd/include/machine/rtems-bsd-commands.h
> index 03a09bc..32aba44 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-commands.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-commands.h
> @@ -64,6 +64,8 @@ int rtems_bsd_command_dhcpcd(int argc, char **argv);
>  int rtems_bsd_command_wpa_supplicant(int argc, char **argv);
> +int rtems_bsd_command_wpa_supplicant_fork(int argc, char **argv);
>  int rtems_bsd_command_tcpdump(int argc, char **argv);
>  int rtems_bsd_command_sysctl(int argc, char **argv);
> diff --git a/rtemsbsd/include/rtems/netcmds-config.h b/rtemsbsd/include/rtems/netcmds-config.h
> index 046c859..4af4323 100644
> --- a/rtemsbsd/include/rtems/netcmds-config.h
> +++ b/rtemsbsd/include/rtems/netcmds-config.h
> @@ -41,6 +41,8 @@ extern rtems_shell_cmd_t rtems_shell_TCPDUMP_Command;
>  extern rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_Command;
> +extern rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_FORK_Command;
>  extern rtems_shell_cmd_t rtems_shell_SYSCTL_Command;
>  extern rtems_shell_cmd_t rtems_shell_VMSTAT_Command;
> diff --git a/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c b/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c
> new file mode 100644
> index 0000000..046b611
> --- /dev/null
> +++ b/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant_fork.c
> @@ -0,0 +1,36 @@
> + * Copyright (c) 2017 Sichen Zhao.  All rights reserved.
> + *  <zsc19940506 at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#include <rtems/netcmds-config.h>
> +#include <machine/rtems-bsd-commands.h>
> +rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_FORK_Command = {
> +  .name = "wpa_supplicant_fork",
> +  .usage = "wpa_supplicant_fork [args]",
Like already said on top: Add at least a BIG FAT WARNING that the
process can not be restarted with that command. wpa_supplicant has to
terminate on itself before you can restart it again.
> +  .topic = "net",
> +  .command = rtems_bsd_command_wpa_supplicant_fork
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
