[PATCH 7/7] Add wpa_spplicant_fork command in test suite media01
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Aug 17 08:23:00 UTC 2017
I think you can integrate that one into Patch 6.
Am 17.08.2017 um 03:33 schrieb Sichen Zhao:
>  testsuite/media01/test_main.c | 3 ++-
>  1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/testsuite/media01/test_main.c b/testsuite/media01/test_main.c
> index 5ca88fb..acc24f2 100644
> --- a/testsuite/media01/test_main.c
> +++ b/testsuite/media01/test_main.c
> @@ -205,7 +205,8 @@ early_initialization(void)
>    &rtems_shell_SYSCTL_Command, \
>    &rtems_shell_IFCONFIG_Command, \
>    &rtems_shell_VMSTAT_Command, \
> -  &rtems_shell_WPA_SUPPLICANT_Command
> +  &rtems_shell_WPA_SUPPLICANT_Command, \
> +  &rtems_shell_WPA_SUPPLICANT_FORK_Command
>  #define CONFIGURE_SHELL_COMMAND_CPUINFO
>  #define CONFIGURE_SHELL_COMMAND_CPUUSE
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
