[PATCH 4/7] Port strnstr.c to FreeBSD.
Thu Aug 17 13:17:42 UTC 2017
On Thu, Aug 17, 2017 at 4:12 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Two points regarding patch 3 and 4:
> First the easy one: I expect that you need it for wpa_supplicant to
> compile? In that case these two patches should be in front of 1 and 2.
> The second point is harder to resolve. I wouldn't even be sure myself
> what to do here: strnstr seems to be a function provided by the C
> library. In our case that would be newlib. I'm not sure whether it is a
> good idea to import some parts of the BSD C library. On the other hand,
> there are already some other function imported from there too.
> To our C-library experts: What would be the right way of handling this?
It is best to bring it in to newlib. It can temporarily come into the
libbsd if needed, but a note should be made to port it to newlib.
> Am 17.08.2017 um 02:23 schrieb Sichen Zhao:
>>  libbsd.py     | 1 +
>>  libbsd_waf.py | 1 +
>>  2 files changed, 2 insertions(+)
>> diff --git a/libbsd.py b/libbsd.py
>> index ea469d3..a0b7f1a 100644
>> --- a/libbsd.py
>> +++ b/libbsd.py
>> @@ -2534,6 +2534,7 @@ def user_space(mm):
>>              'lib/libc/stdlib/strtonum.c',
>>              'lib/libc/stdlib/strtoumax.c',
>>              'lib/libc/string/strsep.c',
>> +            'lib/libc/string/strnstr.c',
>>              'lib/libc/xdr/xdr_array.c',
>>              'lib/libc/xdr/xdr.c',
>>              'lib/libc/xdr/xdr_float.c',
>> diff --git a/libbsd_waf.py b/libbsd_waf.py
>> index 329a62a..02b2cbd 100644
>> --- a/libbsd_waf.py
>> +++ b/libbsd_waf.py
>> @@ -465,6 +465,7 @@ def build(bld):
>>                       'freebsd/lib/libc/stdlib/strtoimax.c',
>>                       'freebsd/lib/libc/stdlib/strtonum.c',
>>                       'freebsd/lib/libc/stdlib/strtoumax.c',
>> +                     'freebsd/lib/libc/string/strnstr.c',
>>                       'freebsd/lib/libc/string/strsep.c',
>>                       'freebsd/lib/libc/xdr/xdr.c',
>>                       'freebsd/lib/libc/xdr/xdr_array.c',
> embedded brains GmbH
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
> devel mailing list
> devel at rtems.org
