[PATCH 02/15] HiFive1: add linker file
Thu Aug 17 14:57:25 UTC 2017
On Wed, Aug 16, 2017 at 11:12 AM, Denis Obrezkov
<denisobrezkov at gmail.com> wrote:
>  c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds | 379 ++++++++++++++++++++++
>  1 file changed, 379 insertions(+)
>  create mode 100644 c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
> diff --git a/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds b/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
> new file mode 100644
> index 0000000..8bf56a0
> --- /dev/null
> +++ b/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
> @@ -0,0 +1,379 @@
> + * @file
> + * @ingroup bsp_linker
> + * @brief Memory map
> + * Copyright (c) 2015 University of York.
> + * Hesham ALMatary <hmka501 at york.ac.uk>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +OUTPUT_FORMAT("elf32-littleriscv", "elf32-littleriscv", "elf32-littleriscv")
> +OUTPUT_ARCH (riscv)
> +ENTRY (_start)
> +MEMORY
> +    ROM      : ORIGIN = 0x20400000, LENGTH = 16M
> +    RAM      : ORIGIN = 0x80000000, LENGTH = 16K /* 64KiB external RAM, but gdb knows only about 16 KiB */
Is there actually 64K ram?
I don't have the knowledge to review the rest of this for correctness.
It  would be good to have a shared linkcmds approach though, like ARM.
> +    ITIM     : ORIGIN = 0x08000000, LENGTH = 8K
> +REGION_ALIAS ("REGION_VECTOR", ROM);
> +REGION_ALIAS ("REGION_START", ROM);
> +REGION_ALIAS ("REGION_TEXT", ROM);
> +REGION_ALIAS ("REGION_TEXT_LOAD", ROM);
> +REGION_ALIAS ("REGION_RODATA", ROM);
> +REGION_ALIAS ("REGION_RODATA_LOAD", ROM);
> +REGION_ALIAS ("REGION_DATA", RAM);
> +REGION_ALIAS ("REGION_DATA_LOAD", ROM);
> +REGION_ALIAS ("REGION_FAST_DATA", RAM);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", ROM);
> +REGION_ALIAS ("REGION_BSS", RAM);
> +REGION_ALIAS ("REGION_WORK", RAM);
> +REGION_ALIAS ("REGION_STACK", RAM);
> +/* The following address is used for text output */
> +/* bsp_section_outbut_buffer = 0x8F800000; */
> + bsp_section_vector_begin  = 0x20400000;
> +STACK_LENGTH = 0;
> + * Global symbols that may be defined externally
> +bsp_vector_table_size = DEFINED (bsp_vector_table_size) ? bsp_vector_table_size : 64;
> +bsp_section_xbarrier_align  = DEFINED (bsp_section_xbarrier_align) ? bsp_section_xbarrier_align : 1;
> +bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
> +bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
> +bsp_stack_align = DEFINED (bsp_stack_align) ? bsp_stack_align : 8;
> +bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 1024;
> +bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
> +_bsp_processor_count = DEFINED (_bsp_processor_count) ? _bsp_processor_count : 1;
> +SECTIONS {
> +  .vector :
> +               . = 0x100;
> +    *(.vector)
> +    . = ALIGN(bsp_vector_table_size);
> +    bsp_section_vector_end = .;
> +  } > REGION_VECTOR AT > REGION_VECTOR
> +  bsp_section_vector_size = bsp_section_vector_end - bsp_section_vector_begin;
> +  bsp_vector_table_begin = bsp_section_vector_begin;
> +  bsp_vector_table_end = bsp_vector_table_begin + bsp_vector_table_size;
> +  .start :
> +    . = ALIGN(8);
> +    bsp_section_start_begin = .;
> +    KEEP (*(.bsp_start_text))
> +    KEEP (*(.bsp_start_data))
> +    bsp_section_start_end = .;
> +  } > REGION_START AT > REGION_START
> +  bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
> +.xbarrier :   {
> +    . = ALIGN (bsp_section_xbarrier_align);
> +.text :   {
> +    . = ALIGN(8);
> +    bsp_section_text_begin = .;
> +    *(.text.unlikely .text.*_unlikely)
> +    *(.text .stub .text.* .gnu.linkonce.t.*)
> +    /* .gnu.warning sections are handled specially by elf32.em.  */
> +    *(.gnu.warning)
> +    *(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
> +  } > REGION_TEXT AT > REGION_TEXT_LOAD
> +  .init :   {
> +    KEEP (*(.init))
> +  .fini :   {
> +    KEEP (*(.fini))
> +    . = ALIGN(8);
> +    bsp_section_text_end = .;
> +    PROVIDE (__etext = .);
> +    PROVIDE (_etext = .);
> +    PROVIDE (etext = .);
> +  bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
> +  bsp_section_text_load_begin = LOADADDR (.text);
> +  bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
> +.robarrier :   {
> +    . = ALIGN (bsp_section_robarrier_align);
> +  } > REGION_RODATA AT > REGION_RODATA
> +.rodata :   {
> +    . = ALIGN(8);
> +    bsp_section_rodata_begin = .;
> +    *(.rodata .rodata.* .gnu.linkonce.r.*)
> +  } > REGION_RODATA AT > REGION_RODATA_LOAD
> +.eh_frame :   {
> +               KEEP (*(.eh_frame))
> +       .gcc_except_table :   {
> +               *(.gcc_except_table .gcc_except_table.*)
> +       .tdata :   {
> +               _TLS_Data_begin = .;
> +               *(.tdata .tdata.* .gnu.linkonce.td.*)
> +               _TLS_Data_end = .;
> +       .tbss :   {
> +               _TLS_BSS_begin = .;
> +               *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
> +               _TLS_BSS_end = .;
> +       _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
> +       _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
> +       _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
> +       _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
> +       _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
> +       _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
> +       .preinit_array :   {
> +               PROVIDE_HIDDEN (__preinit_array_start = .);
> +               KEEP (*(.preinit_array))
> +               PROVIDE_HIDDEN (__preinit_array_end = .);
> +       .init_array :   {
> +               PROVIDE_HIDDEN (__init_array_start = .);
> +               KEEP (*(SORT(.init_array.*)))
> +               KEEP (*(.init_array))
> +               PROVIDE_HIDDEN (__init_array_end = .);
> +       .fini_array :   {
> +               PROVIDE_HIDDEN (__fini_array_start = .);
> +               KEEP (*(.fini_array))
> +               KEEP (*(SORT(.fini_array.*)))
> +               PROVIDE_HIDDEN (__fini_array_end = .);
> +       .ctors :   {
> +               /* gcc uses crtbegin.o to find the start of
> +                  the constructors, so we make sure it is
> +                  first.  Because this is a wildcard, it
> +                  doesn't matter if the user does not
> +                  actually link against crtbegin.o; the
> +                  linker won't look for a file to match a
> +                  wildcard.  The wildcard also means that it
> +                  doesn't matter which directory crtbegin.o
> +                  is in.  */
> +               KEEP (*crtbegin.o(.ctors))
> +               KEEP (*crtbegin?.o(.ctors))
> +               /* We don't want to include the .ctor section from
> +                  the crtend.o file until after the sorted ctors.
> +                  The .ctor section from the crtend file contains the
> +                  end of ctors marker and it must be last */
> +               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
> +               KEEP (*(SORT(.ctors.*)))
> +               KEEP (*(.ctors))
> +       .dtors :   {
> +               KEEP (*crtbegin.o(.dtors))
> +               KEEP (*crtbegin?.o(.dtors))
> +               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
> +               KEEP (*(SORT(.dtors.*)))
> +               KEEP (*(.dtors))
> +       .data.rel.ro :   {
> +               *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
> +               *(.data.rel.ro* .gnu.linkonce.d.rel.ro.*)
> +       .jcr :   {
> +               KEEP (*(.jcr))
> +       .interp :   {
> +               *(.interp)
> +       .note.gnu.build-id :   {
> +               *(.note.gnu.build-id)
> +       .hash :   {
> +               *(.hash)
> +       .gnu.hash :   {
> +               *(.gnu.hash)
> +       .dynsym :   {
> +               *(.dynsym)
> +       .dynstr :   {
> +               *(.dynstr)
> +       .gnu.version :   {
> +               *(.gnu.version)
> +       .gnu.version_d :   {
> +               *(.gnu.version_d)
> +       .gnu.version_r :   {
> +               *(.gnu.version_r)
> +       .rel.dyn :   {
> +               *(.rel.init)
> +               *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
> +               *(.rel.fini)
> +               *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
> +               *(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*)
> +               *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
> +               *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
> +               *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
> +               *(.rel.ctors)
> +               *(.rel.dtors)
> +               *(.rel.got)
> +               *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
> +               PROVIDE_HIDDEN (__rel_iplt_start = .);
> +               *(.rel.iplt)
> +               PROVIDE_HIDDEN (__rel_iplt_end = .);
> +               PROVIDE_HIDDEN (__rela_iplt_start = .);
> +               PROVIDE_HIDDEN (__rela_iplt_end = .);
> +       .rela.dyn :   {
> +               *(.rela.init)
> +               *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
> +               *(.rela.fini)
> +               *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
> +               *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
> +               *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
> +               *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
> +               *(.rela.ctors)
> +               *(.rela.dtors)
> +               *(.rela.got)
> +               *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
> +               *(.rela.iplt)
> +       .rel.plt :   {
> +               *(.rel.plt)
> +       .rela.plt :   {
> +               *(.rela.plt)
> +       .plt :   {
> +               *(.plt)
> +       .iplt :   {
> +               *(.iplt)
> +       .dynamic :   {
> +               *(.dynamic)
> +       .got :   {
> +               *(.got.plt) *(.igot.plt) *(.got) *(.igot)
> +       .rtemsroset :   {
> +               /* Special FreeBSD linker set sections */
> +               __start_set_sysctl_set = .;
> +               *(set_sysctl_*);
> +               __stop_set_sysctl_set = .;
> +               *(set_domain_*);
> +               *(set_pseudo_*);
> +               KEEP (*(SORT(.rtemsroset.*)))
> +               . = ALIGN(8);
> +               bsp_section_rodata_end = .;
> +               __data_start_rom = .;
> +  bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
> +  bsp_section_rodata_load_begin = LOADADDR (.rodata);
> +  bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
> +.data :  AT (__data_start_rom) {
> +    . = ALIGN(8);
> +    bsp_section_data_begin = .;
> +    PROVIDE (_copy_start = .);
> +    *(.data .data.* .gnu.linkonce.d.* .data1)
> +    SORT(CONSTRUCTORS)
> +  } > REGION_DATA
> +  .rtemsrwset : AT (__data_start_rom + SIZEOF (.data))  {
> +    KEEP (*(SORT(.rtemsrwset.*)))
> +    . = ALIGN(8);
> +  } > REGION_DATA
> +  bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
> +  bsp_section_data_load_begin = LOADADDR (.data);
> +  bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
> +.rwbarrier : AT (__data_start_rom + SIZEOF (.data) + SIZEOF (.rtemsrwset)) {
> +    . = ALIGN(8);
> +    . = ALIGN (bsp_section_rwbarrier_align);
> +    bsp_section_data_end = .;
> +    PROVIDE (_copy_end = .);
> +  } > REGION_DATA
> +  .bss :   {
> +    . = ALIGN(8);
> +    bsp_section_bss_begin = .;
> +    *(.dynbss)
> +    *(.bss .bss.* .gnu.linkonce.b.*)
> +    *(COMMON)
> +    . = ALIGN(8);
> +    bsp_section_bss_end = .;
> +  } > REGION_BSS AT > REGION_BSS
> +  bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
> +.work :   {
> +     * The work section will occupy the remaining REGION_WORK region and
> +     * contains the RTEMS work space and heap.
> +    . = ALIGN(8);
> +    bsp_section_work_begin = .;
> +    . += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.) - STACK_LENGTH;
> +    . = ALIGN(8);
> +    bsp_section_work_end = .;
> +  } > REGION_WORK AT > REGION_WORK
> +  bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
> +  .stack :   {
> +    . = ALIGN(8);
> +    bsp_section_stack_begin = .;
> +    . += ORIGIN (REGION_STACK) + LENGTH (REGION_STACK) - ABSOLUTE (.);
> +    . = ALIGN(8);
> +    bsp_section_stack_end = .;
> +  } > REGION_STACK AT > REGION_STACK
> +  bsp_section_stack_size = bsp_section_stack_end - bsp_section_stack_begin;
> +  RamBase = ORIGIN (REGION_WORK);
> +  RamSize = LENGTH (REGION_WORK);
> +  WorkAreaBase = bsp_section_work_begin;
> +  HeapSize = 0;
> 2.1.4
> devel mailing list
> devel at rtems.org
