[PATCH 3/7] Import strnstr.c from FreeBSD.
Thu Aug 17 15:01:57 UTC 2017
Aditya,
Can you help Sichen to put the file in the right place in newlib and
add to the build? Either help him understand how to do it, or do it
with/for him?
On Thu, Aug 17, 2017 at 10:58 AM, Aditya Upadhyay <aadit0402 at gmail.com> wrote:
> Yes.. Definitely i will do. Sichen can directly send the patch for strnstr
> to newlib ml.
> Thanks,
> Aditya Upadhyay
> On 17 Aug 2017 7:03 p.m., "Joel Sherrill" <joel at rtems.org> wrote:
>> On Aug 17, 2017 8:19 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
>> On Wed, Aug 16, 2017 at 8:14 PM, Sichen Zhao <1473996754 at qq.com> wrote:
>> >  freebsd/lib/libc/string/strnstr.c | 67
>> >  1 file changed, 67 insertions(+)
>> >  create mode 100644 freebsd/lib/libc/string/strnstr.c
>> > diff --git a/freebsd/lib/libc/string/strnstr.c
>> > b/freebsd/lib/libc/string/strnstr.c
>> > new file mode 100644
>> > index 0000000..247a2b5
>> > --- /dev/null
>> > +++ b/freebsd/lib/libc/string/strnstr.c
>> > @@ -0,0 +1,67 @@
>> > +#include <machine/rtems-bsd-user-space.h>
>> > + * Copyright (c) 2001 Mike Barcroft <mike at FreeBSD.org>
>> > + * Copyright (c) 1990, 1993
>> > + *     The Regents of the University of California.  All rights
>> > reserved.
>> > + * This code is derived from software contributed to Berkeley by
>> > + * Chris Torek.
>> > + * Redistribution and use in source and binary forms, with or without
>> > + * modification, are permitted provided that the following conditions
>> > + * are met:
>> > + * 1. Redistributions of source code must retain the above copyright
>> > + *    notice, this list of conditions and the following disclaimer.
>> > + * 2. Redistributions in binary form must reproduce the above copyright
>> > + *    notice, this list of conditions and the following disclaimer in
>> > the
>> > + *    documentation and/or other materials provided with the
>> > distribution.
>> > + * 3. Neither the name of the University nor the names of its
>> > contributors
>> > + *    may be used to endorse or promote products derived from this
>> > software
>> > + *    without specific prior written permission.
>> > + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS''
>> > AND
>> > + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> > THE
>> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> > PURPOSE
>> > + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE
>> > LIABLE
>> > + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > CONSEQUENTIAL
>> > + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
>> > GOODS
>> > + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> > INTERRUPTION)
>> > + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
>> > STRICT
>> > + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
>> > ANY WAY
>> > + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
>> > OF
>> > + * SUCH DAMAGE.
>> > +#if defined(LIBC_SCCS) && !defined(lint)
>> > +static char sccsid[] = "@(#)strstr.c   8.1 (Berkeley) 6/4/93";
>> > +#endif /* LIBC_SCCS and not lint */
>> > +#include <sys/cdefs.h>
>> > +__FBSDID("$FreeBSD$");
>> > +#include <string.h>
>> > + * Find the first occurrence of find in s, where the search is limited
>> > to the
>> > + * first slen characters of s.
>> > +char *
>> > +strnstr(const char *s, const char *find, size_t slen)
>> > +       char c, sc;
>> > +       size_t len;
>> > +       if ((c = *find++) != '\0') {
>> > +               len = strlen(find);
>> > +               do {
>> > +                       do {
>> > +                               if (slen-- < 1 || (sc = *s++) == '\0')
>> > +                                       return (NULL);
>> > +                       } while (sc != c);
>> > +                       if (len > slen)
>> > +                               return (NULL);
>> > +               } while (strncmp(s, find, len) != 0);
>> > +               s--;
>> > +       return ((char *)s);
>> This can definitely be added in newlib. Aditya may be able to assist
>> in the process?
>> Agreed. This should be as widely available to RTEMS applications as
>> possible.
>> > 2.7.4
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
