Adding confstr() to rtems
Aditya Upadhyay aadit0402 at gmail.com
Sun Aug 20 18:52:09 UTC 2017
On Sun, Aug 20, 2017 at 11:13 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Aug 20, 2017 at 12:31 PM, Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
>> On Sun, Aug 20, 2017 at 10:07 PM, Joel Sherrill <joel.sherrill at gmail.com>
>> wrote:
>> > I agree those constants should be visible to all configurations when
>> > the POSIX level is set correctly.
>> > Are the V7 (current POSIX 2008/2013) constants in that file?
>> Yes, V7 Constants are defined in that file but these v7 constants are
>> guarded by __CYGWIN.
> I think they should be guarded by the POSIX level only. But ask on
> newlib at . It may be that they want it to be POSIX level plus cygwin or rtems.
But in newlib, confstr () implementation contain only V6 constants. Do
i need to add V7 constants there in newlib ? or Can we add confstr to
rtems itself ?
> I suspect POSIX level alone is correct though.
If POSIX level alone is correct, in that case we need to remove the
__CYGWIN_ guard.
> --joel
>> > On Sun, Aug 20, 2017 at 11:27 AM, Aditya Upadhyay <aadit0402 at gmail.com>
>> > wrote:
>> >> Hello All,
>> >> I was trying to port confstr support in rtems from freebsd. In file
>> >> unistd.h resided at location :
>> >> /development/rtems/4.12/sparc-rtems4.12/include/sys
>> >> has contains the name values only for cygwin guard.
>> >> I have added the following names values guarded by __POSIX_VISIBLE >=
>> >> 200112
>> >> #if __POSIX_VISIBLE >= 199209
>> >> #define    _CS_PATH        1    /* default value of PATH */
>> >> #endif
>> >> #if __POSIX_VISIBLE >= 200112
>> >> #define    _CS_POSIX_V6_ILP32_OFF32_CFLAGS        2
>> >> #define    _CS_POSIX_V6_ILP32_OFF32_LDFLAGS    3
>> >> #define    _CS_POSIX_V6_ILP32_OFF32_LIBS        4
>> >> #define    _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS    5
>> >> #define    _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS    6
>> >> #define    _CS_POSIX_V6_ILP32_OFFBIG_LIBS        7
>> >> #define    _CS_POSIX_V6_LP64_OFF64_CFLAGS        8
>> >> #define    _CS_POSIX_V6_LP64_OFF64_LDFLAGS        9
>> >> #define    _CS_POSIX_V6_LP64_OFF64_LIBS        10
>> >> #define    _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS    11
>> >> #define    _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS    12
>> >> #define    _CS_POSIX_V6_LPBIG_OFFBIG_LIBS        13
>> >> #define    _CS_POSIX_V6_WIDTH_RESTRICTED_ENVS    14
>> >> #endif
>> >> It is working. Please correct me if i am not going in right direction.
>> >> Thanks & Regards,
>> >> Aditya Upadhyay
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
