[PATCH v2 03/15] HiFive1: add start.S file with basic initialization
Denis Obrezkov denisobrezkov at gmail.com
Mon Aug 21 23:56:23 UTC 2017
 c/src/lib/libbsp/riscv32/hifive1/start/start.S | 256 +++++++++++++++++++++++++
 1 file changed, 256 insertions(+)
 create mode 100644 c/src/lib/libbsp/riscv32/hifive1/start/start.S
diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/start.S b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
new file mode 100644
index 0000000..5d0899c
--- /dev/null
+++ b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
@@ -0,0 +1,256 @@
+ * Copyright (c) 2015 University of York.
+ * Hesham ALMatary <hmka501 at york.ac.uk>
+ * Copyright (c) 2017 Denis Obrezkov <denisobrezkov at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <bsp/linker-symbols.h>
+#include <rtems/asm.h>
+# define LREG lw
+# define SREG sw
+#define CLINT_BASE 0x02000000
+#define MTIME_OFFSET 0xBFF8
+#define MTIMECMP_OFFSET 0x4000
+#define MTIME_REG CLINT_BASE+MTIME_OFFSET
+#define MTIMECMP CLINT_BASE+MTIMECMP_OFFSET
+#define MSTATUS_MIE 0x8
+#define MIE_ENABLE_ALL 0x888
+#define REGBYTES 4
+EXTERN(bsp_section_bss_begin)
+EXTERN(bsp_section_bss_end)
+EXTERN(ISR_Handler)
+EXTERN(bsp_start_vector_table_end)
+EXTERN(bsp_start_vector_table_size)
+EXTERN(bsp_vector_table_size)
+EXTERN(bsp_section_stack_begin)
+.balign 4
+PUBLIC(RISCV_Exception_default)
+/* PUBLIC(bsp_start_vector_table_begin) */
+PUBLIC(_start)
+.section .start, "wax"
+TYPE_FUNC(_start)
+SYM(_start):
+  li x1, 0
+  li x2, 0
+  li x3, 0
+  li x4, 0
+  li x5, 0
+  li x6, 0
+  li x7, 0
+  li x8, 0
+  li x9, 0
+  li x10,0
+  li x11,0
+  li x12,0
+  li x13,0
+  li x14,0
+  li x15,0
+  li x16,0
+  li x17,0
+  li x18,0
+  li x19,0
+  li x20,0
+  li x21,0
+  li x22,0
+  li x23,0
+  li x24,0
+  li x25,0
+  li x26,0
+  li x27,0
+  li x28,0
+  li x29,0
+  li x30,0
+  li x31,0
+  /* load stack and frame pointers */
+  la sp, bsp_section_stack_begin
+/* Clearing .bss */
+  la t0, bsp_section_bss_begin
+  la t1, bsp_section_bss_end
+_loop_clear_bss:
+  bge t0, t1, _end_clear_bss
+  addi  t0, t0, 4
+  sw    x0, 0(t0)
+  j     _loop_clear_bss
+_end_clear_bss:
+/* Copy data */
+  la t0, _copy_start
+  la t1, _copy_end
+  la t3, __data_start_rom
+_loop_copy_data:
+  bge t0, t1, _end_copy_data
+  lw  t4, 0(t3)
+  sw   t4, 0(t0)
+  addi t0, t0, 4
+  addi t3, t3, 4
+  j    _loop_copy_data
+_end_copy_data:
+ * Examples of generating clock and software interrupts.
+ * Interrupts won't be generated because they are turned off
+irq_gen:
+  li t2, MTIME_REG
+   * We want to place a big value in comparator to make timer interrupts
+   * be not generated right after turning them on
+  li t4, 0xfffff
+  lw t0, 0(t2)
+  add t0, t0, t4
+  li t3, MTIMECMP
+  sw t0, 0(t3)
+/* copy MSB of mtime */
+  addi t3, t3, 4
+  addi t2, t2, 4
+  lw t0, 0(t2)
+  sw t0, 0(t3)
+/* Enable interrupts in mie register (not enabled in mstatus yet) */
+  la t0, RISCV_Exception_default
+  csrw mtvec, t0
+  li t0, MIE_ENABLE_ALL
+  csrs mie, t0
+  csrci mstatus, MSTATUS_MIE
+  csrw mie, MIE_ENABLE_ALL
+  csrsi mstatus, MSTATUS_MIE
+  call boot_card
+  nop
+bsp_start_vector_table_begin:
+  .word RISCV_Exception_default /* bad_trap */
+#define TRAP_FROM_MACHINE_MODE_VECTOR 13
+bsp_start_vector_table_end:
+.section .start,"ax"
+.align  4
+.type   _external_start, %function
+.normal_start:
+.balign 4
+TYPE_FUNC(RISCV_Exception_default)
+SYM(RISCV_Exception_default):
+  nop
+trap_entry:
+  addi sp, sp, -34*REGBYTES
+  SREG x1, 1*REGBYTES(sp)
+  SREG x2, 2*REGBYTES(sp)
+  SREG x3, 3*REGBYTES(sp)
+  SREG x4, 4*REGBYTES(sp)
+  SREG x5, 5*REGBYTES(sp)
+  SREG x6, 6*REGBYTES(sp)
+  SREG x7, 7*REGBYTES(sp)
+  SREG x8, 8*REGBYTES(sp)
+  SREG x9, 9*REGBYTES(sp)
+  SREG x10, 10*REGBYTES(sp)
+  SREG x11, 11*REGBYTES(sp)
+  SREG x12, 12*REGBYTES(sp)
+  SREG x13, 13*REGBYTES(sp)
+  SREG x14, 14*REGBYTES(sp)
+  SREG x15, 15*REGBYTES(sp)
+  SREG x16, 16*REGBYTES(sp)
+  SREG x17, 17*REGBYTES(sp)
+  SREG x18, 18*REGBYTES(sp)
+  SREG x19, 19*REGBYTES(sp)
+  SREG x20, 20*REGBYTES(sp)
+  SREG x21, 21*REGBYTES(sp)
+  SREG x22, 22*REGBYTES(sp)
+  SREG x23, 23*REGBYTES(sp)
+  SREG x24, 24*REGBYTES(sp)
+  SREG x25, 25*REGBYTES(sp)
+  SREG x26, 26*REGBYTES(sp)
+  SREG x27, 27*REGBYTES(sp)
+  SREG x28, 28*REGBYTES(sp)
+  SREG x29, 29*REGBYTES(sp)
+  SREG x30, 30*REGBYTES(sp)
+  SREG x31, 31*REGBYTES(sp)
+  csrr t0, mepc
+  SREG t0, 32*REGBYTES(sp)
+  csrr t0, mcause
+  SREG t0, 33*REGBYTES(sp)
+  call handle_trap_new
+  LREG t0, 32*REGBYTES(sp)
+  csrw mepc, t0
+  LREG t0, 33*REGBYTES(sp)
+  csrw mcause, t0
+  LREG x1, 1*REGBYTES(sp)
+  LREG x2, 2*REGBYTES(sp)
+  LREG x3, 3*REGBYTES(sp)
+  LREG x4, 4*REGBYTES(sp)
+  LREG x5, 5*REGBYTES(sp)
+  LREG x6, 6*REGBYTES(sp)
+  LREG x7, 7*REGBYTES(sp)
+  LREG x8, 8*REGBYTES(sp)
+  LREG x9, 9*REGBYTES(sp)
+  LREG x10, 10*REGBYTES(sp)
+  LREG x11, 11*REGBYTES(sp)
+  LREG x12, 12*REGBYTES(sp)
+  LREG x13, 13*REGBYTES(sp)
+  LREG x14, 14*REGBYTES(sp)
+  LREG x15, 15*REGBYTES(sp)
+  LREG x16, 16*REGBYTES(sp)
+  LREG x17, 17*REGBYTES(sp)
+  LREG x18, 18*REGBYTES(sp)
+  LREG x19, 19*REGBYTES(sp)
+  LREG x20, 20*REGBYTES(sp)
+  LREG x21, 21*REGBYTES(sp)
+  LREG x22, 22*REGBYTES(sp)
+  LREG x23, 23*REGBYTES(sp)
+  LREG x24, 24*REGBYTES(sp)
+  LREG x25, 25*REGBYTES(sp)
+  LREG x26, 26*REGBYTES(sp)
+  LREG x27, 27*REGBYTES(sp)
+  LREG x28, 28*REGBYTES(sp)
+  LREG x29, 29*REGBYTES(sp)
+  LREG x30, 30*REGBYTES(sp)
+  LREG x31, 31*REGBYTES(sp)
+  addi sp, sp, 34*REGBYTES
+  mret
2.1.4
