[PATCH v2 10/15] HiFive1: set up oscillators
Tue Aug 22 01:48:49 UTC 2017
On Mon, Aug 21, 2017 at 7:56 PM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
>  c/src/lib/libbsp/riscv32/hifive1/include/prci.h   |  9 +++++
>  c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c | 23 +++++++++++++
>  c/src/lib/libbsp/riscv32/hifive1/start/prci.c     | 40 +++++++++++++++++++++++
>  3 files changed, 72 insertions(+)
>  create mode 100644 c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/prci.h b/c/src/lib/libbsp/riscv32/hifive1/include/prci.h
> index c71edbc..3a4ea15 100644
> --- a/c/src/lib/libbsp/riscv32/hifive1/include/prci.h
> +++ b/c/src/lib/libbsp/riscv32/hifive1/include/prci.h
> @@ -56,6 +56,10 @@
>  #define HFROSC_TRIM_OFFSET 16
>  #define HFROSC_EN_OFFSET 30
>  #define HFROSC_RDY_OFFSET 31
> +#define HFROSC_DIV_MASK 0x2F
> +#define HFROSC_TRIM_MASK 0x1F
> +#define HFROSC_EN_MASK 0x1
>   * HFXOSCCFG configuration register values
> @@ -69,7 +73,12 @@
>   * PLLCFG configuration register
>  #define PLL_SEL_OFFSET 16
> +#define PLL_REF_SEL_OFFSET 17
> +#define PLL_BYPASS_OFFSET 18
> +#define PLL_LOCK_OFFSET 31
>  uint32_t hifive1_current_freq();
> +void initialize_oscills();
This function is in the application namespace. It should probably be
hifive1_initialize_oscillators() to be a bit more distinct.
>  #endif /* PRCI_H */
> diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> new file mode 100644
> index 0000000..bb04a22
> --- /dev/null
> +++ b/c/src/lib/libbsp/riscv32/hifive1/start/bspstart.c
> @@ -0,0 +1,23 @@
> + *  Copyright (c) 2017
> + *  Denis Obrezkov <denisobrezkov at gmail.com>
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#include <bsp.h>
> +#include <bsp/bootcard.h>
> +#include <bsp/prci.h>
> +#include <bsp/fe310.h>
> + * This routine make initialization of HiFive1 (FE310) counters.
> +void bsp_start( void )
> +  initialize_oscills();
> +  bsp_interrupt_initialize();
> diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/prci.c b/c/src/lib/libbsp/riscv32/hifive1/start/prci.c
> index bf3d288..1f3abb6 100644
> --- a/c/src/lib/libbsp/riscv32/hifive1/start/prci.c
> +++ b/c/src/lib/libbsp/riscv32/hifive1/start/prci.c
> @@ -26,7 +26,47 @@
>  uint32_t hifive1_current_freq() {
>    return hifive1_default_freq;
> +void initialize_oscills() {
> +  volatile uint32_t * pll_reg = (volatile uint32_t *) PRCI_PLLCFG;
> +  volatile uint32_t * high_freq_reg = (volatile uint32_t *) PRCI_HFROSCCFG;
> +#ifdef USE_HFROSC
> +  /* Setting up osc frequency */
> +  uint32_t tmp_reg = 0;
> +  /* Install divider in high frequency oscillator */
> +  tmp_reg |= (HFROSC_DIV_VAL & HFROSC_DIV_MASK) << HFROSC_DIV_OFFSET;
> +  tmp_reg |= (HFROSC_TRIM_VAL & HFROSC_TRIM_MASK) << HFROSC_TRIM_OFFSET;
> +  tmp_reg |= (HFROSC_EN_VAL & HFROSC_EN_MASK) << HFROSC_EN_OFFSET;
> +  (*high_freq_reg) = tmp_reg;
> +  while (( (*high_freq_reg) & ((HFROSC_RDY_VAL & 0x1) \
> +                  << HFROSC_RDY_OFFSET)) == 0 ) {
> +#endif /* USE_HFROSC */
> +#ifdef USE_HFXOSC
> +  volatile uint32_t * ext_freq_reg = (volatile uint32_t *) PRCI_HFXOSCCFG;
> +  (*ext_freq_reg) |= ((HFXOSC_EN_VAL & 0x1) << HFXOSC_EN_OFFSET);
> +  while (( (*ext_freq_reg) & ((HFXOSC_RDY_VAL & 0x1) \
> +                  << HFXOSC_RDY_OFFSET)) == 0 ) {
> +  (*pll_reg) |= (0x1 << PLL_BYPASS_OFFSET);
> +  (*pll_reg) |= (0x1 << PLL_REF_SEL_OFFSET);
> +  (*pll_reg) |= (0x1 << PLL_SEL_OFFSET);
> +  (*high_freq_reg) &= ~(0x1 << HFROSC_EN_OFFSET);
> +#endif /* USE_HFXOSC */
> +#ifndef USE_PLL
> +  /* Disable PLL */
> +  (*pll_reg) &= ~(0x1 << PLL_SEL_OFFSET);
> +#else
> +#endif
> 2.1.4
> devel mailing list
> devel at rtems.org
