[PATCH 1/2] libmisc/shell: Make some internal shell functions public.
Tue Aug 22 04:48:07 UTC 2017
- Add 'rtems_shell_init_environment()' so a user can create the
  shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
  and 'rtems_shell_execute_cmd' from the internal interface to
  the public interface.
Closes #3104.
 cpukit/libmisc/shell/internal.h | 15 ---------------
 cpukit/libmisc/shell/shell.c    | 11 +++++++----
 cpukit/libmisc/shell/shell.h    | 28 ++++++++++++++++++++++++++++
 3 files changed, 35 insertions(+), 19 deletions(-)
diff --git a/cpukit/libmisc/shell/internal.h b/cpukit/libmisc/shell/internal.h
index 56b1bb6077..31df89da05 100644
--- a/cpukit/libmisc/shell/internal.h
+++ b/cpukit/libmisc/shell/internal.h
@@ -11,24 +11,9 @@
 #include "shell.h"
-struct rtems_shell_topic_tt;
-typedef struct rtems_shell_topic_tt rtems_shell_topic_t;
-struct rtems_shell_topic_tt {
-  const char          *topic;
-  rtems_shell_topic_t *next;
 extern rtems_shell_cmd_t   * rtems_shell_first_cmd;
 extern rtems_shell_topic_t * rtems_shell_first_topic;
-rtems_shell_topic_t * rtems_shell_lookup_topic(const char *topic);
-bool rtems_shell_can_see_cmd(const rtems_shell_cmd_t *shell_cmd);
-int rtems_shell_execute_cmd(const char *cmd, int argc, char *argv[]);
 extern void rtems_shell_register_monitor_commands(void);
 extern void rtems_shell_print_heap_info(
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index e7e57933a0..5f042f5855 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -147,6 +147,12 @@ static void rtems_shell_init_once(void)
                           "running on %m\n");
   rtems_shell_init_commands();
+  rtems_shell_register_monitor_commands();
+void rtems_shell_init_environment(void)
+  assert(pthread_once(&rtems_shell_once, rtems_shell_init_once) == 0);
@@ -721,10 +727,7 @@ bool rtems_shell_main_loop(
   FILE              *stdinToClose = NULL;
   FILE              *stdoutToClose = NULL;
-  eno = pthread_once(&rtems_shell_once, rtems_shell_init_once);
-  assert(eno == 0);
-  rtems_shell_register_monitor_commands();
+  rtems_shell_init_environment();
   shell_env = rtems_shell_init_env(shell_env_arg);
   if (shell_env == NULL) {
diff --git a/cpukit/libmisc/shell/shell.h b/cpukit/libmisc/shell/shell.h
index ea8532d332..2ab8266f27 100644
--- a/cpukit/libmisc/shell/shell.h
+++ b/cpukit/libmisc/shell/shell.h
@@ -94,6 +94,14 @@ typedef struct {
   const char *alias;
 } rtems_shell_alias_t;
+struct rtems_shell_topic_tt;
+typedef struct rtems_shell_topic_tt rtems_shell_topic_t;
+struct rtems_shell_topic_tt {
+  const char          *topic;
+  rtems_shell_topic_t *next;
  * The return value has RTEMS_SHELL_KEYS_EXTENDED set if the key
  * is extended, ie a special key.
@@ -125,6 +133,26 @@ extern int rtems_shell_make_args(
   int    max_args
+extern rtems_shell_topic_t * rtems_shell_lookup_topic(
+  const char *topic
+extern bool rtems_shell_can_see_cmd(
+  const rtems_shell_cmd_t *shell_cmd
+extern int rtems_shell_execute_cmd(
+  const char *cmd, int argc, char *argv[]
+ * Call to set up the shell environment if you need to execute commands before
+ * running a shell.
+extern void rtems_shell_init_environment(
+  void
 extern int rtems_shell_cat_file(
   FILE *out,
   const char *name
2.13.2
