Basic RISC-V 32-bit tool chain
Denis Obrezkov
denisobrezkov at gmail.com
Tue Aug 22 22:38:27 UTC 2017
2017-08-23 0:02 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-08-22 23:49 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> On Tue, Aug 22, 2017 at 4:25 PM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>>> 2017-08-22 22:09 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>> Sebastian,
>>>> Did you consciously not add riscv do rtems-all.bset? Or was it an
>>>> oversight?
>>>> Thanks for doing this. I was building on the master of the tools and
>>>> I haven't checked gdb for riscv but all targets did build.
>>>> --joel
>>>> On Tue, Aug 22, 2017 at 9:55 AM, Denis Obrezkov <
>>>> denisobrezkov at gmail.com> wrote:
>>>>> Ok, I will try today
>>>>> 2017-08-22 16:44 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
>>>>>> Denis,
>>>>>> Please confirm if this works for you.
>>>>>> On Tue, Aug 22, 2017 at 9:17 AM, Sebastian Huber
>>>>>> <sebastian.huber at embedded-brains.de> wrote:
>>>>>> > Hello,
>>>>>> > I added a basic RISC-V 32-bit tool chain to the RSB. It is based on
>>>>>> the
>>>>>> > latest Newlib snapshot and GCC 7.2. The GDB is not included. I
>>>>>> guess for
>>>>>> > this we have to update to GDB 8.0. I didn't test this tool chain.
>>>>>> > Sebastian Huber, embedded brains GmbH
>>>>>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>> > Phone : +49 89 189 47 41-16
>>>>>> > Fax : +49 89 189 47 41-09
>>>>>> > E-Mail : sebastian.huber at embedded-brains.de
>>>>>> > PGP : Public key available on request.
>>>>>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>>>>>> EHUG.
>>>>>> > _______________________________________________
>>>>>> > devel mailing list
>>>>>> > devel at rtems.org
>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>>> Regards, Denis Obrezkov
>>>>> devel mailing list
>>>>> devel at rtems.org
>>> I have the error:
>>> riscv32-rtems4.12-gcc --pipe -DHAVE_CONFIG_H -I..
>>> -I../../cpukit/../../../hifive1/lib/include -march=rv32imac
>>> -mabi=ilp32 -DFE3XX -Os -g -Wall -Wmissing-prototypes
>>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
>>> -MT src/libscore_a-kern_tc.o -MD -MP -MF src/.deps/libscore_a-kern_tc.Tpo
>>> -c -o src/libscore_a-kern_tc.o `test -f 'src/kern_tc.c' || echo
>>> '/home/reprofy/development/rtems/kernel/rtems-riscv/c/src/..
>>> /../cpukit/score/'`src/kern_tc.c
>>> In file included from /home/reprofy/development/rtem
>>> s/4.12/riscv32-rtems4.12/include/sys/_pthreadtypes.h:24:0,
>>> s/4.12/riscv32-rtems4.12/include/sys/types.h:239,
>>> s/4.12/riscv32-rtems4.12/include/sys/time.h:43,
>>> from ../../cpukit/../../../hifive1/
>>> lib/include/rtems/score/timecounter.h:26,
>>> lib/include/rtems/score/timecounterimpl.h:26,
>>> s/kernel/rtems-riscv/c/src/../../cpukit/score/src/kern_tc.c:36:
>>> /home/reprofy/development/rtems/4.12/riscv32-rtems4.12/include/sys/cpuset.h:227:10:
>>> fatal error: machine/_kernel_cpuset.h: No such file or directory
>>> #include <machine/_kernel_cpuset.h>
>>> compilation terminated.
>> Is this file in your RTEMS source tree? It is a shared file across all
>> ports and
>> should always be there.
>> --joel
>> No, I can't find it.
> Here are my build instructions:
> https://docs.google.com/document/d/13_qoWGmQ4N3Sqgb9dvaX27Dn_
> npZX6IkedyvImBcKfo/edit?usp=sharing
> in "Build instructions" section.
> Did I miss something?
I work with Hesham's git tree and may be it's a bit outdated.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170823/6324415a/attachment-0001.html>
