[PATCH] leon,gr1553b: improve init check
Daniel Hellstrom daniel at gaisler.com
Fri Aug 25 11:51:23 UTC 2017
Check in init3 not needed since same data is already checked in init2
stage. Adds an extra check that the APB register space is available before
accessing it.
Updates #2331 but needs to be applied to 4.11 according to ticket.
 c/src/lib/libbsp/sparc/shared/1553/gr1553b.c | 11 ++++++++---
 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c b/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c
index 2e77860..c05d53a 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c
@@ -191,6 +191,8 @@ static int gr1553_init2(struct drvmgr_dev *dev)
 		return DRVMGR_FAIL;
 	pnpinfo = &ambadev->info;
+	if ( pnpinfo->apb_slv == NULL )
+		return DRVMGR_EIO;
 	regs = (struct gr1553b_regs *)pnpinfo->apb_slv->start;
 	/* Stop IRQ */
@@ -227,9 +229,6 @@ static int gr1553_init3(struct drvmgr_dev *dev)
 	/* Get device information from AMBA PnP information */
 	ambadev = (struct amba_dev_info *)dev->businfo;
-	if ( ambadev == NULL ) {
-		return DRVMGR_FAIL;
@@ -257,6 +256,12 @@ static int gr1553_init3(struct drvmgr_dev *dev)
 		gr1553_list_add(&gr1553_rt_root, feat);
+	if ( priv->features == 0 ) {
+		/* no features in HW should never happen.. an I/O error? */
+		free(priv);
 	return DRVMGR_OK;
2.7.4
