[PATCH v2] Testsuite for inttypes methods
Fri Aug 25 14:05:28 UTC 2017
Merge this with the previous commits to only provide 1 single commit
adding this new test.
On Wed, Aug 23, 2017 at 3:35 PM, Aditya Upadhyay <aadit0402 at gmail.com> wrote:
>  testsuites/psxtests/Makefile.am                    |  5 --
>  testsuites/psxtests/configure.ac                   |  5 --
>  testsuites/psxtests/psxinttypes01/init.c           | 66 +++++++++++++++++++---
>  .../psxtests/psxinttypes01/psxinttypes01.scn       |  8 +++
>  4 files changed, 66 insertions(+), 18 deletions(-)
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index cda0061..5d3d41d 100644
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -59,11 +59,6 @@ _SUBDIRS += psxintrcritical01
>  _SUBDIRS += psxitimer
>  endif
>  _SUBDIRS += psxinttypes01
> -_SUBDIRS += psxinttypes02
> -_SUBDIRS += psxinttypes03
> -_SUBDIRS += psxinttypes04
> -_SUBDIRS += psxinttypes05
> -_SUBDIRS += psxinttypes06
>  _SUBDIRS += psxkey01
>  _SUBDIRS += psxkey02
>  _SUBDIRS += psxkey03
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index dd5f23f..b2b00b7 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -163,11 +163,6 @@ psximfs01/Makefile
>  psximfs02/Makefile
>  psxintrcritical01/Makefile
>  psxinttypes01/Makefile
> -psxinttypes02/Makefile
> -psxinttypes03/Makefile
> -psxinttypes04/Makefile
> -psxinttypes05/Makefile
> -psxinttypes06/Makefile
>  psxitimer/Makefile
>  psxkey01/Makefile
>  psxkey02/Makefile
> diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
> index ad41a6d..72f036a 100644
> --- a/testsuites/psxtests/psxinttypes01/init.c
> +++ b/testsuites/psxtests/psxinttypes01/init.c
> @@ -1,5 +1,6 @@
> - *  This is the test for inttypes imaxabs method.
> + *  This is the test for inttypes library. It covers these functions :
> + *  imaxabs(), imaxdiv(), strtoimax(), strtoumax(), wcstoimax(), wcstoumax().
>  #ifdef HAVE_CONFIG_H
> @@ -11,8 +12,6 @@
>  #include <rtems/test.h>
>  #include <stdlib.h>
>  #include <stdio.h>
> -#include <bsp.h>
> -#include <stdint.h>
>  #include <errno.h>
>  #include <tmacros.h>
> @@ -32,11 +31,63 @@ rtems_task Init(
>    rtems_print_printer_printf(&rtems_test_printer);
>    rtems_test_begin();
> -  intmax_t a = -1234;
> -  intmax_t b = imaxabs(a);
> -  printf( "imaxabs_value = %jd\n", b);
> +  char* endptr, *nptr;
> +  uintmax_t j, k;
> +  int base = 10;
> +  rtems_test_assert (base == EINVAL);
I don't know why this is being asserted.
> +  wchar_t *nptr1, *endptr1;
> +  intmax_t m, n;
> +  nptr1 = L"10110134932";
> +  nptr  = "20690239864abc";
> +  /* Test for wcstoimax */
> +  m = wcstoimax(nptr1, &endptr1, base);
> +  rtems_test_assert (m == ERANGE);
> +  rtems_test_assert (m == EINVAL);
I don't understand these two asserts, Perhaps you meant to check errno?
Is it possible to check the correctness of the return value 'm' in an
rtems_test_assert() to automate verification of the return?
These same comments apply to the other tests below.
You should also add some other boundary condition tests, e.g., NULL
endptr, base != 10, and some invalid cases too.
> +  printf( "wcstoimax = %jd\n", m );
> +  /* test for strtoumax */
> +  j = strtoumax (nptr, &endptr, base);
> +  rtems_test_assert (j == ERANGE);
> +  rtems_test_assert (j == EINVAL);
> +  printf( "strtoumax = %ju ( base %d )\n", j, base );
> +  printf( "Stopped scan at %s\n\n", endptr );
> +  /*test for wcstoumax */
> +  k = wcstoumax (nptr1, &endptr1, base);
> +  rtems_test_assert (k == ERANGE);
> +  rtems_test_assert (k == EINVAL);
> +  printf( "wcstoumax = %ju\n", k );
> +  /*Test for imaxdiv */
> +  imaxdiv_t retrival = imaxdiv ( 27, 4 );
> +  printf( "imax div value = %jd\n", retrival.rem );
> +  /*Test for imaxabs  */
> +  printf( "imaxabs_value = %jd\n", imaxabs (-1234));
> +  /*Test for strtoimax */
> +  n = strtoimax ("11111111", &endptr, 2);
> +  rtems_test_assert (n == ERANGE);
> +  rtems_test_assert (n == EINVAL);
> +  printf( "strtoimax value = %jd\n", n);
>    rtems_test_end();
>    exit( 0 );
> @@ -55,4 +106,3 @@ rtems_task Init(
>  #define CONFIGURE_INIT
>  #include <rtems/confdefs.h>
> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> index 15051e1..47a5416 100644
> --- a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> @@ -1,3 +1,11 @@
>  *** BEGIN OF TEST PSXINTTYPE 01 ***
> +wcstoimax = 10110134932
> +strtoumax = 20690239864 ( base 10 )
> +Stopped scan at abc
> +wcstoumax = 10110134932
> +imax div value = 3
>  imaxabs_value = 1234
> +strtoimax value = 255
>  *** END OF TEST PSXINTTYPE 01 ***
> 2.7.4
