[PATCH 0/9] *** Covoar Improvements v2 ***
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat Aug 26 08:15:49 UTC 2017
*** As the full coverage analysis tools integrated with RTEMS Tester
is not ready yet, I've cherry picked these standalone fixes to covoar.
This includes work from myself and the previous 2 students that worked
on the project in 2014 and 2015.
Thanks for the review Chris, formatting change implemented.***
Cillian O'Donnell (5):
rtemstoolkit/host.py: Change option to search parent directory in
Python3.
covoar/ObjdumpProcessor.cc: Remove jump tables from the end of
symbols.
covoar: Use rld tempfile and add signals to clean up in event of
crash.
covoar/CoverageReaderQEMU.cc: Remove trace block matching check.
covoar: Remove config file and test critical options are valid.
Fabien Chouteau (1):
covoar/qemu-traces.h: Change to match current couverture-qemu file.
Hermann Felbinger (2):
covoar: Fix buffer overflow and fix br tag in html report.
covoar: Add information to improve diagnostics.
Krzysztof Miesowicz (1):
covoar/wscript: Add paths to rtemstoolkit to build.
rtemstoolkit/host.py | 2 +-
tester/covoar/CoverageMap.cc | 7 +-
tester/covoar/CoverageMap.h | 5 +-
tester/covoar/CoverageMapBase.cc | 6 +-
tester/covoar/CoverageMapBase.h | 11 +-
tester/covoar/CoverageReaderQEMU.cc | 15 ---
tester/covoar/DesiredSymbols.cc | 25 +++--
tester/covoar/DesiredSymbols.h | 25 +++--
tester/covoar/ExecutableInfo.cc | 3 +-
tester/covoar/ExecutableInfo.h | 2 +
tester/covoar/ObjdumpProcessor.cc | 206 ++++++++++++++++++++----------------
tester/covoar/ObjdumpProcessor.h | 30 ++++--
tester/covoar/ReportsBase.cc | 11 +-
tester/covoar/ReportsHtml.cc | 46 ++++----
tester/covoar/TraceConverter.cc | 60 +++++++++--
tester/covoar/TraceReaderLogQEMU.cc | 9 +-
tester/covoar/TraceReaderLogQEMU.h | 2 +
tester/covoar/TraceWriterQEMU.cc | 10 +-
tester/covoar/TraceWriterQEMU.h | 2 +
tester/covoar/covoar.cc | 201 ++++++++++++++++++-----------------
tester/covoar/qemu-traces.h | 76 ++++++-------
tester/covoar/wscript | 19 ++--
22 files changed, 435 insertions(+), 338 deletions(-)
2.7.4
