[PATCH v2 3/9] covoar: Fix buffer overflow and fix br tag in html report.
Cillian O'Donnell cpodonnell8 at gmail.com
Sat Aug 26 08:15:52 UTC 2017
From: Hermann Felbinger <hermann19829 at gmail.com>
Co-Author: Krzysztof Miesowicz <krzysztof.miesowicz at gmail.com>
 tester/covoar/ReportsBase.cc | 11 ++++++-----
 tester/covoar/ReportsHtml.cc | 46 ++++++++++++++++++++++----------------------
 2 files changed, 29 insertions(+), 28 deletions(-)
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index b61fc76..01950d0 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -210,10 +210,11 @@ void ReportsBase::WriteAnnotatedReport(
          itr != theInstructions->end();
          itr++ ) {
-      uint32_t     id = 0;
-      std::string  annotation = "";
-      std::string  line;
-      char         textLine[150];
+      uint32_t           id = 0;
+      std::string        annotation = "";
+      std::string        line;
+      const std::size_t  LINE_LENGTH = 150;
+      char               textLine[LINE_LENGTH];
       state = A_SOURCE;
@@ -236,7 +237,7 @@ void ReportsBase::WriteAnnotatedReport(
-      sprintf( textLine, "%-70s", itr->line.c_str() );
+      snprintf( textLine, LINE_LENGTH, "%-70s", itr->line.c_str() );
       line = textLine + annotation;
       PutAnnotatedLine( aFile, state, line, id);
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index 101c76b..247253c 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -52,7 +52,7 @@ namespace Coverage {
     #define PRINT_TEXT_ITEM( _t, _n ) \
        fprintf( \
          aFile, \
-         "<li>%s (<a href=\"%s\">text</a>)\n", \
+         "<li>%s (<a href=\"%s\">text</a>)</li>\n", \
         _t, _n );
     FILE*  aFile;
@@ -69,7 +69,7 @@ namespace Coverage {
     if (projectName)
       fprintf(
         aFile,
-         "%s</br>",
+         "%s<br>",
          projectName
@@ -93,7 +93,7 @@ namespace Coverage {
     fprintf(
       aFile,
-      "</li>\n"
+      "</ul>\n"
       "<!-- INSERT PROJECT SPECIFIC ITEMS HERE -->\n"
       "</html>\n"
@@ -144,7 +144,7 @@ namespace Coverage {
     if (projectName)
       fprintf(
         aFile,
-         "%s</br>",
+         "%s<br>",
          projectName
@@ -181,7 +181,7 @@ namespace Coverage {
       if (projectName)
         fprintf(
           aFile,
-          "%s</br>",
+          "%s<br>",
           projectName
@@ -197,7 +197,7 @@ namespace Coverage {
         "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
         "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
         "<th class=\"table-filterable table-sortable:default\" align=\"left\">File</th>\n"
-        "<th class=\"table-sortable:numeric\" align=\"left\">Size </br>Bytes</th>\n"
+        "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Bytes</th>\n"
         "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
         "<th class=\"table-filterable table-sortable:default\" align=\"left\">Taken</th>\n"
 	"<th class=\"table-filterable table-sortable:default\" align=\"left\">Not Taken</th>\n"
@@ -232,7 +232,7 @@ namespace Coverage {
     if (projectName)
       fprintf(
         aFile,
-        "%s</br>",
+        "%s<br>",
         projectName
@@ -248,8 +248,8 @@ namespace Coverage {
       "<th class=\"table-sortable:default\" align=\"left\">Range</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"left\">Size </br>Instructions</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Instructions</th>\n"
       "<th class=\"table-filterable table-sortable:default\" align=\"left\">Classification</th>\n"
       "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
       "</tr>\n"
@@ -281,7 +281,7 @@ namespace Coverage {
     if (projectName)
       fprintf(
         aFile,
-        "%s</br>",
+        "%s<br>",
         projectName
@@ -326,7 +326,7 @@ namespace Coverage {
     if (projectName)
       fprintf(
         aFile,
-        "%s</br>",
+        "%s<br>",
         projectName
@@ -371,7 +371,7 @@ namespace Coverage {
     if (projectName)
       fprintf(
         aFile,
-        "%s</br>",
+        "%s<br>",
         projectName
@@ -385,16 +385,16 @@ namespace Coverage {
       "<thead>\n"
       "<tr>\n"
       "<th class=\"table-sortable:default\" align=\"center\">Symbol</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Total</br>Size</br>Bytes</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Total</br>Size</br>Instr</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#</br>Ranges</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered</br>Size</br>Bytes</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered</br>Size</br>Instr</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#</br>Branches</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#</br>Always</br>Taken</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">#</br>Never</br>Taken</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Percent</br>Uncovered</br>Instructions</th>\n"
-      "<th class=\"table-sortable:numeric\" align=\"center\">Percent</br>Uncovered</br>Bytes</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Bytes</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Instr</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Ranges</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Bytes</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Instr</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Branches</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Always<br>Taken</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Never<br>Taken</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Instructions</th>\n"
+      "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Bytes</th>\n"
       "</tr>\n"
       "</thead>\n"
       "<tbody>\n",
@@ -728,7 +728,7 @@ namespace Coverage {
     // Range
     fprintf(
       report,
-      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s </br>%s</td>\n",
+      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s <br>%s</td>\n",
       rangePtr->id,
       rangePtr->lowSourceLine.c_str(),
       rangePtr->highSourceLine.c_str()
2.7.4
