problem building libbsd with waf
Jeff Mayes Jeff.Mayes at OARcorp.com
Wed Aug 30 14:16:47 UTC 2017
I've tried waf 1.9.13 and 1.8.20.  Same results with both.
There's probably something wrong with my environment.
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Wednesday, August 30, 2017 3:24 AM
> To: Jeff Mayes <Jeff.Mayes at OARcorp.com>; devel at rtems.org
> Subject: Re: problem building libbsd with waf
> On 30/8/17 1:39 am, Jeff Mayes wrote:
> > I'm trying to build rtems and rtems-libbsd.  It all goes fine until
> > the waf build fails with this:
> > /  Checking for RTEMS CPU options header   : no/
> > This occurs for both i386 and arm.  Part of the config.log is below.
> > Any ideas?
> What version of waf are you using? Maybe try a recent version, I know 1.9.3
> is works for me with a recent libbsd.
> Chris
