[PATCH] libpci: fix pci device allocation
Daniel Hellstrom
daniel at gaisler.com
Wed Aug 30 14:22:45 UTC 2017
The refactoring of pci_dev_create() was incorrect since the code relied on
different defines before including pci/cfg.h. This reverts back to the
original code having two pci_dev_create() one in auto and one in read library.
confdefs.h selectes between the two libraries so both there is no link
conflict.
Updates #3029
cpukit/libpci/Makefile.am | 1 -
cpukit/libpci/pci_cfg_auto.c | 16 ++++++++++++++++
cpukit/libpci/pci_cfg_read.c | 16 ++++++++++++++++
cpukit/libpci/pci_dev_create.c | 33 ---------------------------------
cpukit/libpci/pci_internal.h | 3 ---
5 files changed, 32 insertions(+), 37 deletions(-)
delete mode 100644 cpukit/libpci/pci_dev_create.c
diff --git a/cpukit/libpci/Makefile.am b/cpukit/libpci/Makefile.am
index cf336ed..cff25b3 100644
--- a/cpukit/libpci/Makefile.am
+++ b/cpukit/libpci/Makefile.am
@@ -28,7 +28,6 @@ libpci_a_SOURCES += pci_cfg_print_code.c
libpci_a_SOURCES += pci_cfg_read.c
libpci_a_SOURCES += pci_cfg_static.c
libpci_a_SOURCES += pci_cfg_peripheral.c
-libpci_a_SOURCES += pci_dev_create.c
libpci_a_SOURCES += pci_find.c
libpci_a_SOURCES += pci_find_dev.c
libpci_a_SOURCES += pci_for_each.c
diff --git a/cpukit/libpci/pci_cfg_auto.c b/cpukit/libpci/pci_cfg_auto.c
index 2f227b1..51e5765 100644
--- a/cpukit/libpci/pci_cfg_auto.c
+++ b/cpukit/libpci/pci_cfg_auto.c
@@ -267,6 +267,22 @@ static void pci_dev_free(struct pci_dev *dev)
#endif
+struct pci_dev *pci_dev_create(int isbus)
+ void *ptr;
+ int size;
+ if (isbus)
+ size = sizeof(struct pci_bus);
+ else
+ size = sizeof(struct pci_dev);
+ ptr = calloc(1, size);
+ if (!ptr)
+ rtems_fatal_error_occurred(RTEMS_NO_MEMORY);
+ return ptr;
static void pci_find_devs(struct pci_bus *bus)
uint32_t id, tmp;
diff --git a/cpukit/libpci/pci_cfg_read.c b/cpukit/libpci/pci_cfg_read.c
index 16c2928..f6cacfb 100644
--- a/cpukit/libpci/pci_cfg_read.c
+++ b/cpukit/libpci/pci_cfg_read.c
@@ -36,6 +36,22 @@
/* The Host Bridge bus is initialized here */
extern struct pci_bus pci_hb;
+ void *ptr;
+ int size;
+ if (isbus)
+ else
+ if (!ptr)
+ return ptr;
/* Check if address is accessible from host */
static int pci_read_addressable(struct pci_dev *dev, struct pci_res *res)
diff --git a/cpukit/libpci/pci_dev_create.c b/cpukit/libpci/pci_dev_create.c
deleted file mode 100644
index 4e84397..0000000
--- a/cpukit/libpci/pci_dev_create.c
+++ /dev/null
@@ -1,33 +0,0 @@
-/* Device allocator helper used by PCI Auto/Read Configuration Library
- * COPYRIGHT (c) 2010 Cobham Gaisler AB.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
-#include <stdlib.h>
-#include <rtems/bspIo.h>
-#include <pci.h>
-#include <pci/cfg.h>
-#include "pci_internal.h"
-struct pci_dev *pci_dev_create(int isbus)
- void *ptr;
- int size;
- if (isbus)
- size = sizeof(struct pci_bus);
- else
- size = sizeof(struct pci_dev);
- ptr = calloc(1, size);
- if (!ptr)
- rtems_fatal_error_occurred(RTEMS_NO_MEMORY);
- return ptr;
diff --git a/cpukit/libpci/pci_internal.h b/cpukit/libpci/pci_internal.h
index a89e8f1..d0bb83c 100644
--- a/cpukit/libpci/pci_internal.h
+++ b/cpukit/libpci/pci_internal.h
@@ -9,6 +9,3 @@
/* Number of buses */
extern int pci_bus_cnt;
-/* Allocate a PCI device for a standard device or a bridge device */
-struct pci_dev *pci_dev_create(int isbus);
2.7.4
