[PATCH v2 2/4] waf: Move glob operator ** to builder.py
Sichen Zhao
1473996754 at qq.com
Fri Aug 11 10:39:12 UTC 2017
This allows a finer decision which headers should be installed.
builder.py | 26 +++++++++++++-------------
libbsd_waf.py | 30 +++++++++++++++---------------
waf_generator.py | 4 ++--
3 files changed, 30 insertions(+), 30 deletions(-)
diff --git a/builder.py b/builder.py
index 1be1ced..04a5e49 100755
--- a/builder.py
+++ b/builder.py
@@ -220,20 +220,20 @@ def headerPaths():
normal installation path. """
# local path wildcard dest path
- return [('rtemsbsd/include', '*.h', ''),
+ return [('rtemsbsd/include', '**/*.h', ''),
('rtemsbsd/mghttpd', 'mongoose.h', 'mghttpd'),
- ('freebsd/include', '*.h', ''),
- ('freebsd/sys/bsm', '*.h', 'bsm'),
- ('freebsd/sys/cam', '*.h', 'cam'),
- ('freebsd/sys/net', '*.h', 'net'),
- ('freebsd/sys/net80211', '*.h', 'net80211'),
- ('freebsd/sys/netinet', '*.h', 'netinet'),
- ('freebsd/sys/netinet6', '*.h', 'netinet6'),
- ('freebsd/sys/netipsec', '*.h', 'netipsec'),
- ('freebsd/sys/rpc', '*.h', 'rpc'),
- ('freebsd/sys/sys', '*.h', 'sys'),
- ('freebsd/sys/vm', '*.h', 'vm'),
- ('freebsd/sys/dev/mii', '*.h', 'dev/mii'),
+ ('freebsd/include', '**/*.h', ''),
+ ('freebsd/sys/bsm', '**/*.h', 'bsm'),
+ ('freebsd/sys/cam', '**/*.h', 'cam'),
+ ('freebsd/sys/net', '**/*.h', 'net'),
+ ('freebsd/sys/net80211', '**/*.h', 'net80211'),
+ ('freebsd/sys/netinet', '**/*.h', 'netinet'),
+ ('freebsd/sys/netinet6', '**/*.h', 'netinet6'),
+ ('freebsd/sys/netipsec', '**/*.h', 'netipsec'),
+ ('freebsd/sys/rpc', '**/*.h', 'rpc'),
+ ('freebsd/sys/sys', '**/*.h', 'sys'),
+ ('freebsd/sys/vm', '**/*.h', 'vm'),
+ ('freebsd/sys/dev/mii', '**/*.h', 'dev/mii'),
('mDNSResponder/mDNSCore', 'mDNSDebug.h', ''),
('mDNSResponder/mDNSCore', 'mDNSEmbeddedAPI.h', ''),
('mDNSResponder/mDNSShared', 'dns_sd.h', ''),
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 8bc2b34..b681d7f 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -130,7 +130,7 @@ def build(bld):
for headers in header_build_copy_paths:
target = os.path.join("build-include", headers[2])
start_dir = bld.path.find_dir(headers[0])
- for header in start_dir.ant_glob(os.path.join("**/", headers[1])):
+ for header in start_dir.ant_glob(headers[1]):
relsourcepath = header.path_from(start_dir)
targetheader = os.path.join(target, relsourcepath)
bld(features = 'subst',
@@ -1481,20 +1481,20 @@ def build(bld):
# Installs.
bld.install_files("${PREFIX}/" + rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION, bld.env.RTEMS_ARCH_BSP), ["libbsd.a"])
- header_paths = [('rtemsbsd/include', '*.h', ''),
+ header_paths = [('rtemsbsd/include', '**/*.h', ''),
@@ -1503,7 +1503,7 @@ def build(bld):
ipath = os.path.join(rtems.arch_bsp_include_path(bld.env.RTEMS_VERSION, bld.env.RTEMS_ARCH_BSP), headers[2])
bld.install_files("${PREFIX}/" + ipath,
- start_dir.ant_glob("**/" + headers[1]),
+ start_dir.ant_glob(headers[1]),
cwd = start_dir,
relative_trick = True)
diff --git a/waf_generator.py b/waf_generator.py
index fdc2210..8aa2e29 100755
--- a/waf_generator.py
+++ b/waf_generator.py
@@ -457,7 +457,7 @@ class ModuleManager(builder.ModuleManager):
self.add(' for headers in header_build_copy_paths:')
self.add(' target = os.path.join("%s", headers[2])' % (builder.buildInclude()))
self.add(' start_dir = bld.path.find_dir(headers[0])')
- self.add(' for header in start_dir.ant_glob(os.path.join("**/", headers[1])):')
+ self.add(' for header in start_dir.ant_glob(headers[1]):')
self.add(' relsourcepath = header.path_from(start_dir)')
self.add(' targetheader = os.path.join(target, relsourcepath)')
self.add(' bld(features = \'subst\',')
@@ -648,7 +648,7 @@ class ModuleManager(builder.ModuleManager):
self.add(' ipath = os.path.join(rtems.arch_bsp_include_path(bld.env.RTEMS_VERSION, bld.env.RTEMS_ARCH_BSP), headers[2])')
self.add(' bld.install_files("${PREFIX}/" + ipath,')
- self.add(' start_dir.ant_glob("**/" + headers[1]),')
+ self.add(' start_dir.ant_glob(headers[1]),')
self.add(' cwd = start_dir,')
self.add(' relative_trick = True)')
self.add('')
2.7.4
