RISC-V interrupts in HiFive1
Denis Obrezkov
denisobrezkov at gmail.com
Tue Aug 15 18:38:35 UTC 2017
2017-08-15 19:03 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-08-15 14:57 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> On Aug 15, 2017 4:32 AM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> wrote:
>> 2017-08-15 5:44 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
>>> Hi Denis,
>>> You just need to modify riscv_interrupt_disable(). Read the priv-spec
>>> manual for your RISC-V version, and determine which bit should be
>>> cleared (it's called MIE in priv-1.10, but you mentioned you work with
>>> priv-1.9).
>> Is the bit set correctly for the idle thread?
>> I assume this is with a real clock driver so is it maintained properly
>> across an ISR?
>> It is either screwed up by the thread context initialization, context
>> switch, or ISR code. ISR code has two exit paths. It could be the
>> preemption path. That would occur about 5 seconds into the execution of
>> ticker and TA1 will preemption idle.
>> I understand this but still can find a mistake.
> This is what I get:
> *** LOW MEMORY CLOCK TICK TEST ***
> TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
> TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
> TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
> TA1 - rtems_clock_get_tod - 09:00:04 12/31/1988
> TA2 - rtems_clock_get_tod - 09:00:09 12/31/1988
> TA1 - rtems_clock_get_tod - 09:00:09 12/31/1988
> After that I can examine: p Clock_driver_ticks
> $8 = 1001
> mstatus value is 0x0001800 (interrupts disabled)
> Instruction for enabling global interrupts is:
> csrsi mstatus, 0x8
> for disabling:
> csrci mstatus, 0x8
> it atomically changes the fourth bit of mstatus (ie bit).
> I think that something wrong happens in context switches between TA1, TA2
> and Idle.
> This is my context switch file:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/cpukit/score/cpu/
> riscv32/riscv-context-switch.S
> Interrupt disabling:
> riscv32/rtems/score/cpu.h#L542
> Context initialize:
> riscv32/riscv-context-initialize.c
> Interrupt context save:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/
> riscv32/hifive1/start/start.S#L200
> Could have a look?
> Regards, Denis Obrezkov
can't find the mistake*
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170815/d02100f3/attachment-0002.html>
