RISC-V interrupts in HiFive1
Denis Obrezkov
denisobrezkov at gmail.com
Tue Aug 15 23:27:12 UTC 2017
2017-08-15 22:46 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-08-15 20:38 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> 2017-08-15 19:03 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>> 2017-08-15 14:57 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>> On Aug 15, 2017 4:32 AM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>>>> wrote:
>>>> 2017-08-15 5:44 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
>>>>> Hi Denis,
>>>>> You just need to modify riscv_interrupt_disable(). Read the priv-spec
>>>>> manual for your RISC-V version, and determine which bit should be
>>>>> cleared (it's called MIE in priv-1.10, but you mentioned you work with
>>>>> priv-1.9).
>>>> Is the bit set correctly for the idle thread?
>>>> I assume this is with a real clock driver so is it maintained properly
>>>> across an ISR?
>>>> It is either screwed up by the thread context initialization, context
>>>> switch, or ISR code. ISR code has two exit paths. It could be the
>>>> preemption path. That would occur about 5 seconds into the execution of
>>>> ticker and TA1 will preemption idle.
>>>> I understand this but still can find a mistake.
>>> This is what I get:
>>> *** LOW MEMORY CLOCK TICK TEST ***
>>> TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
>>> TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
>>> TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
>>> TA1 - rtems_clock_get_tod - 09:00:04 12/31/1988
>>> TA2 - rtems_clock_get_tod - 09:00:09 12/31/1988
>>> TA1 - rtems_clock_get_tod - 09:00:09 12/31/1988
>>> After that I can examine: p Clock_driver_ticks
>>> $8 = 1001
>>> mstatus value is 0x0001800 (interrupts disabled)
>>> Instruction for enabling global interrupts is:
>>> csrsi mstatus, 0x8
>>> for disabling:
>>> csrci mstatus, 0x8
>>> it atomically changes the fourth bit of mstatus (ie bit).
>>> I think that something wrong happens in context switches between TA1,
>>> TA2 and Idle.
>>> This is my context switch file:
>>> https://github.com/embeddedden/rtems-riscv/blob/hifive1/cpuk
>>> it/score/cpu/riscv32/riscv-context-switch.S
>>> Interrupt disabling:
>>> it/score/cpu/riscv32/rtems/score/cpu.h#L542
>>> Context initialize:
>>> it/score/cpu/riscv32/riscv-context-initialize.c
>>> Interrupt context save:
>>> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/sr
>>> c/lib/libbsp/riscv32/hifive1/start/start.S#L200
>>> Could have a look?
>>> Regards, Denis Obrezkov
>> can't find the mistake*
> Also, I found out new strange issue, when I set:
> #define FE310_CLOCK_PERIOD 313
> #define CONFIGURE_MICROSECONDS_PER_TICK 9552
> clock ticks till the 09:00:09 and stops ticking, but with
> #define FE310_CLOCK_PERIOD 626
> #define CONFIGURE_MICROSECONDS_PER_TICK 9552*2
> clock ticks till the end (35 s.) but the duration of a virtual second is
> more than a second (appr. 2 s.).
> I use onboard 32.768 oscillator as a source of ticks (it is the only
> available source).
> Also, when I have
> #define FE310_CLOCK_PERIOD 512
> #define CONFIGURE_MICROSECONDS_PER_TICK 15625
> virtual 5 seconds last for about 7-8 real seconds.
> Are there any suggestions on this?
I think that CONFIGURE_MICROSECONDS_PER_TICK wasn't installed.
I've tried to push it via -DCONFIGURE_MICROSECONDS_PER_TICK=15625
but it doesn't work either.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170816/ab46edf2/attachment-0002.html>
