[PATCH 15/15] HiFive1: disable/enable interrupts during context switch
Denis Obrezkov denisobrezkov at gmail.com
Sat Aug 19 12:56:43 UTC 2017
2017-08-19 14:33 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> On Fri, Aug 18, 2017 at 11:30 AM, Denis Obrezkov
> <denisobrezkov at gmail.com> wrote:
> > 2017-08-17 23:58 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> >> On Thu, Aug 17, 2017 at 4:17 PM, Denis Obrezkov <
> >> wrote:
> >> > 2017-08-17 22:07 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> >> >> On Thu, Aug 17, 2017 at 1:48 PM, Denis Obrezkov
> >> >> wrote:
> >> >> > 2017-08-17 17:25 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> >> >> >> On Wed, Aug 16, 2017 at 11:13 AM, Denis Obrezkov
> >> >> >> >  cpukit/score/cpu/riscv32/riscv-context-switch.S | 12
> >> >> >> >  1 file changed, 10 insertions(+), 2 deletions(-)
> >> >> >> > diff --git a/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> >> > b/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> >> > index a199596..bcdfe0e 100644
> >> >> >> > --- a/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> >> > +++ b/cpukit/score/cpu/riscv32/riscv-context-switch.S
> >> >> >> > @@ -46,6 +46,7 @@ PUBLIC(restore)
> >> >> >> >  SYM(_CPU_Context_switch):
> >> >> >> >    /* Disable interrupts and store all registers */
> >> >> >> > +  csrci mstatus, 0x8
> >> >> >> Why is this necessary?
> >> >> >> >    SREG x1, 4(a0)
> >> >> >> >    SREG x2, 8(a0)
> >> >> >> >    SREG x3, 12(a0)
> >> >> >> > @@ -78,8 +79,9 @@ SYM(_CPU_Context_switch):
> >> >> >> >    SREG x30, 120(a0)
> >> >> >> >    SREG x31, 124(a0)
> >> >> >> > -SYM(restore):
> >> >> >> > +SYM(restore):
> >> >> >> >    LREG x1, 4(a1)
> >> >> >> >    LREG x2, 8(a1)
> >> >> >> >    LREG x3, 12(a1)
> >> >> >> > @@ -111,9 +113,15 @@ SYM(restore):
> >> >> >> >    LREG x29, 116(a1)
> >> >> >> >    LREG x30, 120(a1)
> >> >> >> >    LREG x31, 124(a1)
> >> >> >> > -       ret
> >> >> >> > +  csrsi mstatus, 0x8
> >> >> >> > +  nop
> >> >> >> > +  nop
> >> >> >> Why the nops?
> >> >> >> > +  ret
> >> >> >> >  SYM(_CPU_Context_restore):
> >> >> >> >    mv     a1, a0
> >> >> >> >    j       restore
> >> >> >> >    nop
> >> >> >> > 2.1.4
> >> >> >> > _______________________________________________
> >> >> >> > devel mailing list
> >> >> >> > devel at rtems.org
> >> >> >> > http://lists.rtems.org/mailman/listinfo/devel
> >> >> > So, don't we turn off interrupts during the context switch?
> >> >> Nope, and turning them back on unconditionally is wrong too.
> >> >> > Yes, nops are unnecessary.
> >> >> > Regards, Denis Obrezkov
> >> > Ok, I was confused by this obsolete comment:
> >> > Will remove all that enabling/disabling.
> >> > Is the same true for start.S file with interrupted task's stack
> saving?
> >> I'm not sure exactly what you're referring to, but usually start.S
> >> will, among other things, turn off and ack pending interrupts to
> >> quiesce the hardware before handing off the rest of system init to
> >> boot_card. Eventually RTEMS will enable interrupts again using the
> >> cpukit's interrupt_enable layer.
> > I mean when an interrupt occurs, the execution flow jumps to the trap
> > address.
> > Then, in my case all process'es registers are saved in a common stack
> > (I know that dedicated interrupt stack should be implemented, but I
> haven't
> > time to do that)
> > and then we jump to IRQ dispatching routine. After interrupt handling we
> > restore saved
> > registers. So, my question is - should we disable/enable interrupts
> during
> > interrupt handling?
> > Disabling:
> > https://github.com/embeddedden/rtems-riscv/blob/
> hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L201
> > Jump to dispatching routine:
> hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L241
> > Enabling interrupts back:
> hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L285
> This interrupt handling is incomplete/broken I think. Keeping the
> interrupts turned off for the duration of RTEMS + User ISR handling is
> not "real-time". What other CPU did you look at to understand how to
> deal with interrupts?
I'v kept Hasham's RISC-V generic interrupt code. I thought that we don't
want to have nested interrupts. I also tried to turn off interrupts only
during
register saving/restoring.
> Usually, the BSP will support installing interrupt handlers that jump
> to ISR_Handler(), which then sets up a safe "C" environment for the
> user handler to use. The ISR_Handler() should enable interrupts before
> invoking the user code. From what I can tell, your implementation of
> ISR_Handler doesn't do anything.
Ok, I am going to figure out how to implement it better.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170819/25418039/attachment-0002.html>
