[PATCH v2 07/15] HiFive1: add irq dispatching function
Wed Aug 23 01:18:32 UTC 2017
If that is the 2-paragraph BSD, then it is the newly preferred license.
The RTEMS GPLv2 has an exception which allows linking and eliminates the
viral characteristic. In practice and intent, the two licenses are the same
but the 2-paragraph BSD is simpler and better recognized for our intent.
Thank you for trying to use the BSD style license.
Depending on the author(s) of the original code, it might be easy to get
their permission for this one file on the list.
--joel
On Tue, Aug 22, 2017 at 7:41 PM, Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> On Tue, Aug 22, 2017 at 9:56 AM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
> >  c/src/lib/libbsp/riscv32/hifive1/include/irq.h     | 12 +++
> >  c/src/lib/libbsp/riscv32/hifive1/irq/irq.c         | 86
> >  c/src/lib/libbsp/riscv32/hifive1/start/start.S     |  3 +-
> >  .../score/cpu/riscv32/rtems/score/riscv-utility.h  | 26 +++++++
> >  4 files changed, 126 insertions(+), 1 deletion(-)
> >  create mode 100644 c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
> > diff --git a/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
> b/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
> > index 67a781f..46d29c7 100644
> > --- a/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
> > +++ b/c/src/lib/libbsp/riscv32/hifive1/include/irq.h
> > @@ -11,6 +11,8 @@
> >   * Copyright (c) 2015 University of York.
> >   * Hesham ALMatary <hmka501 at york.ac.uk>
> > + * Copyright (c) 2017 Denis Obrezkov <denisobrezkov at gmail.com>
> >   * Redistribution and use in source and binary forms, with or without
> >   * modification, are permitted provided that the following conditions
> >   * are met:
> > @@ -52,6 +54,16 @@
> >  #define MCAUSE_MTIME 0x7
> >  #define MCAUSE_MEXT 0xB
> > +#define MIE_MSWI (1 << MCAUSE_MSWI)
> > +#define MIE_MTIME (1 << MCAUSE_MTIME)
> > +#define MIE_MEXT (1 << MCAUSE_MEXT)
> > + * Memory mapped timer, timer comparator and software interrupt
> registers.
> > +#define MTIMECMP  ((volatile uint64_t *)0x02004000)
> > +#define MTIME     ((volatile uint64_t *)0x0200bff8)
> > +#define MSIP_REG ((volatile uint32_t *) 0x02000000)
> >  #endif /* ASM */
> >  #endif /* LIBBSP_GENERIC_RISCV_IRQ_H */
> > diff --git a/c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
> b/c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
> > new file mode 100644
> > index 0000000..fadfdb7
> > --- /dev/null
> > +++ b/c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
> > @@ -0,0 +1,86 @@
> > + * @file
> > + * @ingroup riscv_interrupt
> > + * @brief Interrupt support.
> > + * RISCV CPU Dependent Source
> > + * Copyright (c) 2015 University of York.
> > + * Hesham ALMatary <hmka501 at york.ac.uk>
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS''
> AND
> > + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
> LIABLE
> > + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> > + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS
> > + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> > + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> > + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
> ANY WAY
> > + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> OF
> > + * SUCH DAMAGE.
> > +#include <bsp/fe310.h>
> > +#include <bsp/irq.h>
> > +#include <bsp/irq-generic.h>
> > +/* Almost all of the jobs that the following functions should
> > + * do are implemented in cpukit
> > +void bsp_interrupt_handler_default(rtems_vector_number vector)
> > +    printk("spurious interrupt: %u\n", vector);
> > +rtems_status_code bsp_interrupt_facility_initialize()
> > +  return 0;
> > +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number
> vector)
> > +  return 0;
> > +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number
> vector)
> > +  return 0;
> > + * FIXME: only timer intrrupt is handled
> > +void handle_trap (uint32_t cause)
> > +    if (cause & MCAUSE_INT) {
> > +      /* an interrupt occurred */
> > +      if ((cause & MCAUSE_MTIME) == MCAUSE_MTIME) {
> > +       /* Timer interrupt */
> > +        (*MTIMECMP) = (*MTIME) + FE310_CLOCK_PERIOD;
> > +        bsp_interrupt_handler_table[1].handler(bsp_interrupt_
> handler_table[1].arg);
> > +      } else if ((cause & MCAUSE_MEXT) == MCAUSE_MEXT) {
> > +             /*External interrupt */
> > +      } else if ((cause & MCAUSE_MSWI) == MCAUSE_MSWI) {
> > +             /* Software interrupt */
> > +             *MSIP_REG = 0;
> > +    } else {
> > +      /* an exception occurred */
> > diff --git a/c/src/lib/libbsp/riscv32/hifive1/start/start.S
> b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
> > index 5d0899c..b3fb3f3 100644
> > --- a/c/src/lib/libbsp/riscv32/hifive1/start/start.S
> > +++ b/c/src/lib/libbsp/riscv32/hifive1/start/start.S
> > @@ -209,7 +209,8 @@ trap_entry:
> >    csrr t0, mcause
> >    SREG t0, 33*REGBYTES(sp)
> > -  call handle_trap_new
> > +  mv   a0, t0
> > +  call handle_trap
> >    LREG t0, 32*REGBYTES(sp)
> >    csrw mepc, t0
> > diff --git a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
> b/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
> > index c45b05f..8abc0bd 100644
> > --- a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
> > +++ b/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
> > @@ -14,4 +14,30 @@
> >  #ifndef _RTEMS_SCORE_RISCV_UTILITY_H
> >  #define _RTEMS_SCORE_RISCV_UTILITY_H
> > +#define read_csr(reg) ({ unsigned long __tmp; \
> > +          asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \
> > +          __tmp; })
> > +#define write_csr(reg, val) \
> > +      asm volatile ("csrw " #reg ", %0" :: "r"(val))
> > +#define swap_csr(reg, val) ({ long __tmp; \
> > +          asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) :
> "r"(val)); \
> > +          __tmp; })
> > +#define set_csr(reg, bit) ({ unsigned long __tmp; \
> > +          if (__builtin_constant_p(bit) && (bit) < 32) \
> > +            asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) :
> "i"(bit)); \
> > +          else \
> "r"(bit)); \
> > +          __tmp; })
> > +#define clear_csr(reg, bit) ({ unsigned long __tmp; \
> > +            asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) :
> "i"(bit)); \
> > +          else \
> "r"(bit)); \
> > +          __tmp; })
> Would you add the license/comment for the file/code this is originally
> copied from? Similarally for all of the other patches. In RTEMS, GPLv2
> is used, it might conflict with other types of licenses.
> >  #endif /* _RTEMS_SCORE_RISCV_UTILITY_H */
> > 2.1.4
> > devel mailing list
> > devel at rtems.org
> Hesham
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170822/de0b78c1/attachment-0002.html>
