Basic RISC-V 32-bit tool chain
Hesham Almatary heshamelmatary at gmail.com
Wed Aug 23 01:34:05 UTC 2017
Hi all,
I am reporting my efforts on this thread:
* RSB/master/vanilla: riscv32 tested and builds just fine with no
changes from my side.
* RTEMS/riscv32: priv-1.10 branch - rebased with rtems/master, fixed
errors, and pushed to GitHub [1].
* RTEMS/Spike: BSP builds sample tests and tested hello/ticker on
Spike simulator.
Thanks for your efforts all.
[1] https://github.com/heshamelmatary/rtems-riscv/tree/priv-1.10
Cheers,
Hesham
On Wed, Aug 23, 2017 at 9:12 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> I propose Hesham to rebase his tree so I can rebase my tree against his one
> and send a pull request till the end of GSoC.
> 2017-08-23 1:07 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> Definitely looks like that tree is out of date a bit.
>> Looks like Heshams's tree needs to be rebased. Even better would
>> be merging it to rtems.org if it is ready now. :)
>> --joel
>> On Tue, Aug 22, 2017 at 6:01 PM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>>> 2017-08-23 0:58 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>> I would guess that's the case:
>>>> $ cd rtems
>>>> [joel at localhost rtems]$ find . -name "_kernel*.h"
>>>> ./cpukit/libcsupport/include/machine/_kernel_time.h
>>>> ./cpukit/libcsupport/include/machine/_kernel_types.h
>>>> ./cpukit/libcsupport/include/machine/_kernel_cpuset.h
>>>> ./cpukit/libcsupport/include/machine/_kernel_param.h
>>>> ./cpukit/libnetworking/machine/_kernel_lock.h
>>>> On Tue, Aug 22, 2017 at 5:38 PM, Denis Obrezkov
>>>>> 2017-08-23 0:02 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>>>>> 2017-08-22 23:49 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>>>>> On Tue, Aug 22, 2017 at 4:25 PM, Denis Obrezkov
>>>>>>>> 2017-08-22 22:09 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>>>>>>> Sebastian,
>>>>>>>>> Did you consciously not add riscv do rtems-all.bset? Or was it an
>>>>>>>>> oversight?
>>>>>>>>> Thanks for doing this. I was building on the master of the tools
>>>>>>>>> and
>>>>>>>>> I haven't checked gdb for riscv but all targets did build.
>>>>>>>>> --joel
>>>>>>>>> On Tue, Aug 22, 2017 at 9:55 AM, Denis Obrezkov
>>>>>>>>>> Ok, I will try today
>>>>>>>>>> 2017-08-22 16:44 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
>>>>>>>>>>> Denis,
>>>>>>>>>>> Please confirm if this works for you.
>>>>>>>>>>> On Tue, Aug 22, 2017 at 9:17 AM, Sebastian Huber
>>>>>>>>>>> <sebastian.huber at embedded-brains.de> wrote:
>>>>>>>>>>> > Hello,
>>>>>>>>>>> > I added a basic RISC-V 32-bit tool chain to the RSB. It is
>>>>>>>>>>> > based on the
>>>>>>>>>>> > latest Newlib snapshot and GCC 7.2. The GDB is not included. I
>>>>>>>>>>> > guess for
>>>>>>>>>>> > this we have to update to GDB 8.0. I didn't test this tool
>>>>>>>>>>> > chain.
>>>>>>>>>>> > Sebastian Huber, embedded brains GmbH
>>>>>>>>>>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>>>>>>> > Phone   : +49 89 189 47 41-16
>>>>>>>>>>> > Fax     : +49 89 189 47 41-09
>>>>>>>>>>> > E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>>>>> > PGP     : Public key available on request.
>>>>>>>>>>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>>>>>>>>>>> > EHUG.
>>>>>>>>>>> > _______________________________________________
>>>>>>>>>>> > devel mailing list
>>>>>>>>>>> > devel at rtems.org
>>>>>>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>> Regards, Denis Obrezkov
>>>>>>>>>> devel mailing list
>>>>>>>>>> devel at rtems.org
>>>>>>>> I have the error:
>>>>>>>> riscv32-rtems4.12-gcc --pipe -DHAVE_CONFIG_H   -I..
>>>>>>>> -I../../cpukit/../../../hifive1/lib/include   -march=rv32imac -mabi=ilp32
>>>>>>>> -DFE3XX -Os -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration
>>>>>>>> -Wstrict-prototypes -Wnested-externs -MT src/libscore_a-kern_tc.o -MD -MP
>>>>>>>> -MF src/.deps/libscore_a-kern_tc.Tpo -c -o src/libscore_a-kern_tc.o `test -f
>>>>>>>> 'src/kern_tc.c' || echo
>>>>>>>> '/home/reprofy/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/'`src/kern_tc.c
>>>>>>>> In file included from
>>>>>>>> /home/reprofy/development/rtems/4.12/riscv32-rtems4.12/include/sys/_pthreadtypes.h:24:0,
>>>>>>>>                  from
>>>>>>>> /home/reprofy/development/rtems/4.12/riscv32-rtems4.12/include/sys/types.h:239,
>>>>>>>>                  from
>>>>>>>> /home/reprofy/development/rtems/4.12/riscv32-rtems4.12/include/sys/time.h:43,
>>>>>>>>                  from
>>>>>>>> ../../cpukit/../../../hifive1/lib/include/rtems/score/timecounter.h:26,
>>>>>>>>                  from
>>>>>>>> ../../cpukit/../../../hifive1/lib/include/rtems/score/timecounterimpl.h:26,
>>>>>>>>                  from
>>>>>>>> /home/reprofy/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/kern_tc.c:36:
>>>>>>>> /home/reprofy/development/rtems/4.12/riscv32-rtems4.12/include/sys/cpuset.h:227:10:
>>>>>>>> fatal error: machine/_kernel_cpuset.h: No such file or directory
>>>>>>>>  #include <machine/_kernel_cpuset.h>
>>>>>>>> compilation terminated.
>>>>>>> Is this file in your RTEMS source tree? It is a shared file across
>>>>>>> all ports and
>>>>>>> should always be there.
>>>>>>> --joel
>>>>>> No, I can't find it.
>>>>>> Here are my build instructions:
>>>>>> https://docs.google.com/document/d/13_qoWGmQ4N3Sqgb9dvaX27Dn_npZX6IkedyvImBcKfo/edit?usp=sharing
>>>>>> in "Build instructions" section.
>>>>>> Did I miss something?
>>>>> I work with Hesham's git tree and may be it's a bit outdated.
>>> My output:
>>> ./rtems-riscv/cpukit/libcsupport/include/machine/_kernel_time.h
>>> ./rtems-riscv/cpukit/libcsupport/include/machine/_kernel_types.h
>>> ./rtems-riscv/cpukit/libnetworking/machine/_kernel_lock.h
Hesham
