problem building libbsd with waf
Joel Sherrill
joel at rtems.org
Wed Aug 30 15:20:04 UTC 2017
I managed to build with waf 1.9.5 on rtbf64c whic is CentOS 7.
I am using a waf in my home directory.
I wonder why we don't bundle waf like with rtems-docs?
On Wed, Aug 30, 2017 at 9:16 AM, Jeff Mayes <Jeff.Mayes at oarcorp.com> wrote:
> I've tried waf 1.9.13 and 1.8.20. Same results with both.
> There's probably something wrong with my environment.
> > -----Original Message-----
> > From: Chris Johns [mailto:chrisj at rtems.org]
> > Sent: Wednesday, August 30, 2017 3:24 AM
> > To: Jeff Mayes <Jeff.Mayes at OARcorp.com>; devel at rtems.org
> > Subject: Re: problem building libbsd with waf
> > On 30/8/17 1:39 am, Jeff Mayes wrote:
> > > I'm trying to build rtems and rtems-libbsd. It all goes fine until
> > > the waf build fails with this:
> > > / Checking for RTEMS CPU options header : no/
> > > This occurs for both i386 and arm. Part of the config.log is below.
> > > Any ideas?
> > What version of waf are you using? Maybe try a recent version, I know
> 1.9.3
> > is works for me with a recent libbsd.
> > Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170830/e20ed058/attachment-0002.html>
