problem building libbsd with waf
Jeff Mayes Jeff.Mayes at OARcorp.com
Thu Aug 31 18:47:21 UTC 2017
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Thursday, August 31, 2017 3:00 AM
> To: Jeff Mayes <Jeff.Mayes at OARcorp.com>; Christian Mauderer <list at c-
> mauderer.de>; devel at rtems.org
> Subject: Re: problem building libbsd with waf
> On 31/08/2017 07:32, Jeff Mayes wrote:
> > I'm using a CentOS 7 VM and I've built it successfully on previous occasions.
> Shared disk in the VM? I have found various issues when sharing disks with
> the host.
> Chris
No sir, not sharing disks.
I removed my rtems install (prefix) directory and started over with the build process.  The waf configure of i386/pc386 still fails.  But, the waf configure and build of the arm/zedboard both worked just fine.  So, I'm moving on...
Thanks for the help
Jeff
