[PATCH 2/2] libio: Use API mutex
Tue Dec 5 07:01:59 UTC 2017
 cpukit/libcsupport/include/rtems/libio_.h | 19 ++-----------
 cpukit/libcsupport/src/libio_init.c       | 44 ++++++++++---------------------
 cpukit/sapi/include/confdefs.h            |  7 +----
 cpukit/score/include/rtems/score/interr.h |  2 +-
 testsuites/sptests/spsysinit01/init.c     |  4 +--
 5 files changed, 20 insertions(+), 56 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
index 5cc31eed64..414e8a20fc 100644
--- a/cpukit/libcsupport/include/rtems/libio_.h
+++ b/cpukit/libcsupport/include/rtems/libio_.h
@@ -53,15 +53,6 @@ extern "C" {
 #define F_DUP2FD 20
- *  Semaphore to protect the io table
-#define RTEMS_LIBIO_SEM         rtems_build_name('L', 'B', 'I', 'O')
-#define RTEMS_LIBIO_IOP_SEM(n)  rtems_build_name('L', 'B', 'I', n)
-extern rtems_id                          rtems_libio_semaphore;
  *  File descriptor Table Information
@@ -347,15 +338,9 @@ void rtems_libio_free_user_env( void *env );
 extern pthread_key_t rtems_current_user_env_key;
-static inline void rtems_libio_lock( void )
-  rtems_semaphore_obtain( rtems_libio_semaphore, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
+void rtems_libio_lock( void );
-static inline void rtems_libio_unlock( void )
-  rtems_semaphore_release( rtems_libio_semaphore );
+void rtems_libio_unlock( void );
 static inline void rtems_filesystem_mt_lock( void )
diff --git a/cpukit/libcsupport/src/libio_init.c b/cpukit/libcsupport/src/libio_init.c
index 9c24b146ea..5b951ef2be 100644
--- a/cpukit/libcsupport/src/libio_init.c
+++ b/cpukit/libcsupport/src/libio_init.c
@@ -18,27 +18,28 @@
 #include "config.h"
 #endif
-#include <rtems/libio_.h>               /* libio_.h pulls in rtems */
-#include <rtems.h>
-#include <rtems/assoc.h>                /* assoc.h not included by rtems.h */
+#include <rtems/libio_.h>
-#include <stdio.h>                      /* O_RDONLY, et.al. */
-#include <fcntl.h>                      /* O_RDONLY, et.al. */
-#include <errno.h>
+#include <pthread.h>
-#include <errno.h>
-#include <string.h>                     /* strcmp */
-#include <unistd.h>
-#include <stdlib.h>                     /* calloc() */
-#include <rtems/libio.h>                /* libio.h not pulled in by rtems */
 #include <rtems/sysinit.h>
+#include <rtems/score/apimutex.h>
-rtems_id rtems_libio_semaphore;
+static API_Mutex_Control rtems_libio_mutex = API_MUTEX_INITIALIZER( "_Libio" );
+  _API_Mutex_Lock( &rtems_libio_mutex );
+  _API_Mutex_Unlock( &rtems_libio_mutex );
 void *rtems_libio_iop_free_head;
@@ -46,7 +47,6 @@ void **rtems_libio_iop_free_tail = &rtems_libio_iop_free_head;
 static void rtems_libio_init( void )
-    rtems_status_code rc;
     uint32_t i;
     rtems_libio_t *iop;
     int eno;
@@ -70,22 +70,6 @@ static void rtems_libio_init( void )
   if (eno != 0) {
     _Internal_error( INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED );
-   *  Create the binary semaphore used to provide mutual exclusion
-   *  on the IOP Table.
-  rc = rtems_semaphore_create(
-    RTEMS_LIBIO_SEM,
-    1,
-    RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY,
-    RTEMS_NO_PRIORITY,
-    &rtems_libio_semaphore
-  if ( rc != RTEMS_SUCCESSFUL ) {
-    _Internal_error( INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED );
 RTEMS_SYSINIT_ITEM(
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 8204f0559f..e94752294b 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -141,11 +141,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
 #endif
- * Semaphore count used by the IO library.
-#define _CONFIGURE_LIBIO_SEMAPHORES 1
  * POSIX key count used by the IO library.
 #define _CONFIGURE_LIBIO_POSIX_KEYS 1
@@ -2120,7 +2115,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
    * capabilities.
   #define _CONFIGURE_SEMAPHORES \
-    (CONFIGURE_MAXIMUM_SEMAPHORES + _CONFIGURE_LIBIO_SEMAPHORES + \
+    (CONFIGURE_MAXIMUM_SEMAPHORES + \
       _CONFIGURE_TERMIOS_SEMAPHORES + _CONFIGURE_LIBBLOCK_SEMAPHORES + \
       _CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \
       _CONFIGURE_NETWORKING_SEMAPHORES)
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index a93eaf659c..3144952716 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -182,7 +182,7 @@ typedef enum {
   INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED = 32,
   INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED = 33,
   INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED = 34,
-  INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED = 35,
+  /* INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED = 35, */
   INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED = 36,
   INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED = 37,
   INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT = 38,
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index dc09e71e2c..ff6feb066a 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -516,13 +516,13 @@ LAST(RTEMS_SYSINIT_IDLE_THREADS)
 FIRST(RTEMS_SYSINIT_LIBIO)
-  assert(rtems_libio_semaphore == 0);
+  assert(rtems_libio_iop_free_tail == &rtems_libio_iop_free_head);
   next_step(LIBIO_PRE);
 LAST(RTEMS_SYSINIT_LIBIO)
-  assert(rtems_libio_semaphore != 0);
+  assert(rtems_libio_iop_free_tail != &rtems_libio_iop[0]);
   next_step(LIBIO_POST);
2.12.3
