[PATCH] Account for non-preemption and interrupt level not supported on SMP
Tue Dec 5 16:16:25 UTC 2017
Closes #3000.
 c-user/directive_status_codes.rst | 2 +-
 c-user/task_manager.rst           | 8 ++++++++
 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/c-user/directive_status_codes.rst b/c-user/directive_status_codes.rst
index b74f190..41fc649 100644
--- a/c-user/directive_status_codes.rst
+++ b/c-user/directive_status_codes.rst
@@ -74,7 +74,7 @@ The directives are:
  * - ``RTEMS_NOT_OWNER_OF_RESOURCE``
    - not owner of resource
  * - ``RTEMS_NOT_IMPLEMENTED``
-   - directive not implemented
+   - directive not implemented or feature not available in configuration
  * - ``RTEMS_INTERNAL_ERROR``
    - RTEMS inconsistency detected
  * - ``RTEMS_NO_MEMORY``
diff --git a/c-user/task_manager.rst b/c-user/task_manager.rst
index 8917fba..aff9185 100644
--- a/c-user/task_manager.rst
+++ b/c-user/task_manager.rst
@@ -636,6 +636,10 @@ DIRECTIVE STATUS CODES:
         - too many tasks created
       * - ``RTEMS_UNSATISFIED``
         - not enough memory for stack/FP context
+      * - ``RTEMS_UNSATISFIED``
+        - non-preemption mode not supported on SMP system
+        - interrupt level mode not supported on SMP system
       * - ``RTEMS_TOO_MANY``
         - too many global objects
@@ -1279,6 +1283,10 @@ DIRECTIVE STATUS CODES:
         - task mode set successfully
       * - ``RTEMS_INVALID_ADDRESS``
         - ``previous_mode_set`` is NULL
+        - not enough memory for stack/FP context
+      * - ``RTEMS_NOT_IMPLEMENTED``
 DESCRIPTION:
     This directive manipulates the execution mode of the calling task.  A
1.8.3.1
