[RTEMS Project] #3240: cpukit/libmisc/stackchk/check.c stack addresses formatted incorrectly.
groups at chichak.ca groups at chichak.ca
Wed Dec 6 05:06:16 UTC 2017
Joel,
I followed all of Chris’ instructions as much as I understood:
> On 2017-November-16, at 21:21, Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>> wrote:
> On 17/11/2017 15:05, groups at chichak.ca <mailto:groups at chichak.ca> wrote:
>> (I don’t know how to proceed with getting this reported/fixed.)
> Please head to the wiki (https://devel.rtems.org/ <https://devel.rtems.org/>) and select the link in the
> "Reporting a bug" column of the Releases Table for the release you are reporting
> the bug against. You will need an account.
> - Clone the git repo and select the branch.
> - Make the change and test.
> - Commit the change with a summary as the first line and then if
> you need more detail add a body. End the commit message with
> "Close #12345." with the ticket number.
>   eg git commit
>    libmisc: Fix formatting in Stack_check_Dump_threads_usage
>    Close #12345.
> - Enter 'git format-patch -1'
> - Attach the patch to the ticket.
I guess I didn’t understand. I thought I needed to attach the diff to the ticket and some god-like person would do the final vet and push into the repo. No?
A
> Reporter:  Andrei Chichak                    |       Owner:  (none)
>     Type:  defect                            |      Status:  new
> Priority:  normal                            |   Milestone:  5.1
> Component:  lib                               |     Version:  5
> Severity:  normal                            |  Resolution:
> Keywords:  rtems_stack_checker_report_usage  |
> Comment (by Joel Sherrill):
> Wasn't a fix for this committed? Is there work left to do? Either close or
> state actions left. Please
> Ticket URL: <http://devel.rtems.org/ticket/3240#comment:2>
> RTEMS Project <http://www.rtems.org/>
> RTEMS Project
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171205/41a85aa8/attachment.html>
