[PATCH] dosfs: Allow creating a file with similar name.
Joel Sherrill
joel at rtems.org
Wed Dec 6 15:00:59 UTC 2017
Should the test .doc file be updated to include this test case?
Is this a test case.worth running against other filesystems?
--joel
On Dec 6, 2017 9:57 AM, "Christian Mauderer" <
christian.mauderer at embedded-brains.de> wrote:
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
cpukit/libfs/src/dosfs/msdos_misc.c | 10 +++++++---
testsuites/fstests/fsdosfsname01/init.c | 25 +++++++++++++++++++++++++
2 files changed, 32 insertions(+), 3 deletions(-)
diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c b/cpukit/libfs/src/dosfs/
msdos_misc.c
index 79aaa36520..24eb2d11e0 100644
--- a/cpukit/libfs/src/dosfs/msdos_misc.c
+++ b/cpukit/libfs/src/dosfs/msdos_misc.c
@@ -1564,9 +1564,13 @@ msdos_find_file_in_directory (
if (entry_matched)
if (lfn_entry ||
- lfn_checksum != msdos_lfn_checksum(entry))
- entry_matched = false;
- else if (name_len_remaining == 0) {
+ name_len_remaining > 0 ||
+ lfn_checksum != msdos_lfn_checksum(entry)) {
+ msdos_prepare_for_next_entry(&lfn_start,
+ &entry_matched,
&name_len_remaining,
name_len_for_compare);
+ } else if (name_len_remaining == 0) {
filename_matched = true;
rc = msdos_on_entry_found (
fs_info,
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/
index d0c909877c..846faf28a3 100644
--- a/testsuites/fstests/fsdosfsname01/init.c
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -1097,6 +1097,30 @@ static void test_end_of_string_matches( void )
rtems_test_assert( rc == 0 );
+static void test_end_of_string_matches_2( void )
+ int rc;
+ int fd;
+ fd = open( MOUNT_DIR "/ets.beam", O_RDWR | O_CREAT,
+ S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH | S_IWOTH );
+ rtems_test_assert( fd >= 0 );
+ rc = close( fd );
+ rtems_test_assert( rc == 0 );
+ fd = open( MOUNT_DIR "/sets.beam", O_RDWR | O_CREAT,
+ rc = close( fd );
+ rc = unlink( MOUNT_DIR "/sets.beam" );
+ rc = unlink( MOUNT_DIR "/ets.beam" );
static void test_full_8_3_name( void )
int rc;
@@ -1151,6 +1175,7 @@ static void test_file_with_same_name_as_volume_label(
void )
static void test_special_cases( void )
test_end_of_string_matches();
+ test_end_of_string_matches_2();
test_full_8_3_name();
test_file_with_same_name_as_volume_label();
test_dir_with_same_name_as_volume_label();
2.12.3
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171206/190d0985/attachment-0001.html>
