[PATCH 1/2] taskmode.c: Ensure all error checking is done before modifying executing
Joel Sherrill
joel at rtems.org
Wed Dec 6 18:37:07 UTC 2017
On Wed, Dec 6, 2017 at 12:25 AM, Sebastian Huber <
> On 05/12/17 17:13, Joel Sherrill wrote:
>> Also use single conditional expressions to simplify error checking.
>> Combined, this all resulted in a block of SMP enabled error checking.
>> Updates #3000.
>> cpukit/rtems/src/taskmode.c | 33 +++++++++++++++++++++++++++++++--
>> 1 file changed, 31 insertions(+), 2 deletions(-)
>> diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
>> index a345409..49648ac 100644
>> --- a/cpukit/rtems/src/taskmode.c
>> +++ b/cpukit/rtems/src/taskmode.c
>> @@ -43,6 +43,33 @@ rtems_status_code rtems_task_mode(
>> if ( !previous_mode_set )
>> return RTEMS_INVALID_ADDRESS;
>> +#if defined( RTEMS_SMP )
>> + * When in SMP, you cannot disable preemption for a thread or
>> + * alter its interrupt level. It must be fully preemptible with
>> + * all interrupts enabled.
>> + if ( rtems_configuration_is_smp_enabled() ) {
>> + if ( mask & RTEMS_PREEMPT_MASK ) {
>> + if ( !_Modes_Is_preempt( mode_set ) ) {
>> + return RTEMS_NOT_IMPLEMENTED;
>> + if ( mask & RTEMS_INTERRUPT_MASK ) {
>> + if (_Modes_Get_interrupt_level( mode_set ) != 0 ) {
> if ( _Modes...
> There should be a test case for the new else path
> _Modes_Get_interrupt_level( mode_set ) == 0.
Looking at this again, I think adding a test case is OK but we should also
given
an error anytime RTEMS_INTERRUPT_MASK is specified. A user thinking they
are changing the level to 0 (all enabled) is just as wrong as setting it to
non-zero.
The error we are catching is use of RTEMS_INTERRUPT_MASK in SMP mode.
Thanks for catching this.
--joel
>> +#endif
>> + * Complete all error checking before doing any operations which
>> + * impact the executing thread. There should be no errors returned
>> + * past this point.
>> executing = _Thread_Get_executing();
>> api = executing->API_Extensions[ THREAD_API_RTEMS ];
>> asr = &api->Signal;
>> @@ -63,18 +90,18 @@ rtems_status_code rtems_task_mode(
>> * These are generic thread scheduling characteristics.
>> preempt_enabled = false;
>> +#if !defined( RTEMS_SMP )
>> -#if defined( RTEMS_SMP )
>> if ( rtems_configuration_is_smp_enabled() &&
>> -#endif
>> bool is_preempt_enabled = _Modes_Is_preempt( mode_set );
>> preempt_enabled = !executing->is_preemptible &&
>> is_preempt_enabled;
>> executing->is_preemptible = is_preempt_enabled;
>> +#endif
>> if ( mask & RTEMS_TIMESLICE_MASK ) {
>> if ( _Modes_Is_timeslice(mode_set) ) {
>> @@ -88,8 +115,10 @@ rtems_status_code rtems_task_mode(
>> * Set the new interrupt level
>> _Modes_Set_interrupt_level( mode_set );
>> +#endif
>> * This is specific to the RTEMS API
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171206/a1ff71ee/attachment.html>
