[rtems commit] taskmode.c: Ensure all error checking is done before modifying executing
Thu Dec 7 12:15:58 UTC 2017
On 07/12/17 12:42, Joel Sherrill wrote:
> Other than fixing those tests for smp, is it bad to just say the
> interrupt disable part of task mode isn't supported in smp?
Here the RTEMS_PREEMPT_MASK and RTEMS_INTERRUPT_MASK are not treated
equally:
   if ( rtems_configuration_is_smp_enabled() ) {
     if ( mask & RTEMS_PREEMPT_MASK ) {
       if ( !_Modes_Is_preempt( mode_set ) ) {
         return RTEMS_NOT_IMPLEMENTED;
     if ( mask & RTEMS_INTERRUPT_MASK ) {
rtems_task_mode(RTEMS_PREEMPT_MASK, RTEMS_PREEMPT, ...) is ok, but
rtems_task_mode(RTEMS_INTERRUPT_MASK, RTEMS_INTERRUPT_LEVEL(0), ...) is
not ok?
The rtems_task_mode() looks pretty broken now. There should be no:
#if !defined( RTEMS_SMP )
A rtems_configuration_is_smp_enabled() inside a #if !defined( RTEMS_SMP)
block makes no sense.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
